  • July 07, 2025, 03:36:37 AM
Author Topic: Smoothie do over question  (Read 5217 times)
Offline Brian Stas
« on: October 10, 2009, 07:51:50 PM »
A friend passed along a hanger queen Smoothie to me and I'm going to have to replace the hinges, covering etc.  My question is did they make more than one version of the Smoothie ?  I've seen some with an upright engine, my is inverted.
thanks
Brian
Offline Jim Oliver
Re: Smoothie do over question
« Reply #1 on: October 11, 2009, 08:59:48 AM »
Ty,
That's the way I remembered my Veco Smoothie kit, but didn't want to say since it was a memory form long, long ago and far, far away.......
Jim
Jim Oliver
AMA 18475
Offline Jim Oliver
« Reply #2 on: October 11, 2009, 07:32:45 PM »
Ty,
The "planes" look great.......... VD~
Hope you're feeling better.
Jim
Jim Oliver
AMA 18475
Offline Brian Stas
« Reply #3 on: October 11, 2009, 08:39:01 PM »
Thanks for your input guys.  The Smoothie was my Dad's favorite and I want to do this one justice by refinishing it the right way.
Offline Mike Scholtes
« Reply #4 on: October 11, 2009, 09:27:14 PM »
There is loads of information about the history and various versions of the Smoothie. Check the archives here and on Stuka Stunt. The quick answer is that it can be built with upright engine or inverted cowled engine. I have built a Brodak kit Smoothie and currently fly an ARF Smoothie. Both are excellent flyers. I also have an unbuilt Dumas (same as Veco) kit from the 1950s that is a very different airplane, especially in the odd pointy airfoil. The Dumas/Veco plans show three versions of engine mounting, including an inverted mounting that removes through a hatch in the top of the nose. That one didn't catch on, apparently. The Brodak Smoothie reportedly flys much better than the Veco/Dumas version.
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: October 12, 2009, 08:42:46 AM »
This pic has been posted before but this plane was kit bashed from a Brodak Smoothie kit to the inverted/cowled engine version of the Smoothie. The Veco plans actually show 3 styles, upright pointy nose, inverted pointy nose, and inverted cowled. I built this one because there is a famous pic of Mr. Palmer posing with a similar painted Smoothie w/ cowled nose. BTW, the Brodak kit is excellent.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline bob branch
« Reply #6 on: October 12, 2009, 05:17:54 PM »
I fly an electric powered version of the Brodak Smoothie arc. At the Signal Seekers Stunt Contest (Michigan) in August I was comparing mine with a Veco inverted engine kit Smoothie. As the pic in the last post shows, the fuselage is considerably wider than the one on the current Brodak version.
bob branch
« Reply #7 on: October 12, 2009, 06:11:47 PM »
Ha! I knew Pete would spot this post. Pete and I have had the upright/inverted arguement several times. I got to admit his inverted version does look sharp. (I think it would look even better if the engine was pointed the right direction LL~)
Sadly, I've never had the chance to *sniff* fly it myself. *sniff sniff*
« Reply #8 on: October 12, 2009, 09:32:36 PM »
Hi Pete & Clint:
How can there be an "argument?" First off, Pete's Smoothie is the prettiest seen anywhere. Second, the photo on the cover of the Veco kit shows a cowled, inverted engine, while the plans show three varieties (though calling the paper that comes with the kit "plans" is very questionable; "guidelines" at best). Most early pictures in the 1952 period show Palmer with the inverted engine version.
The comment about width sent me to the garage with a caliper. The Veco/Dumas fuse is 2 5/8 at the widest part; the ARF Brodak fuse is 2 3/8. I sold the kit Smoothie so I could not measure that one, but the ARF may be a little narrower as it takes a special tank.
As far as the differences between the Veco and "Original Smoothie" certified by Bob Palmer, they are really different airplanes. The Veco is 51" span and 501 inches, while the Brodak is 52" and 540 area. Length is different, tail section is different. And rather famously the airfoil is wildly different, almost a supercritical airfoil on the Veco kit. Palmer worked for Lockheed in the early 50s as a model maker and was familiar with the supercritical airfoil. The story is that Palmer used the rear high point airfoil on the first Smoothie, but found it flew badly and he abandoned it. The familiar normal airfoil was used in all succeeding Smoothies and then the T-Bird. Veco perversely kitted the first version, over Palmer's objections apparently.
Pete, have you got that ceramic gila monster yet? I was in Half Moon Bay today and walked by the Cunha store, a local legend. Told my daughter, "I know somebody named Pete Cunha!"
  • High Desert Flier
« Reply #9 on: October 12, 2009, 10:10:51 PM »
Clint: Say, meet me in Albuquerque next weekend and you can fly the Smoothie to your heart's content...oh wait, you will be in Clovis at the Golden State (hopefully), so never mind. Mike, yup, found a nice Gila Monster replica, very realistic, named him Rocky, he can usually be found at various locations around the front of my house.  Cunha store, never visited there but lotsa Portagees around Half Moon Bay, probably a distant relative. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #10 on: October 12, 2009, 10:11:20 PM »
Mike, don't worry. It's only a friendly "argument" anyway. It's just that the first Smoothie I was familiar with was my dads built in about '63 from a Veco kit and had the engine upright. Or as I like to say, "mounted correctly".
« Reply #11 on: October 13, 2009, 08:58:01 AM »
Hey Clint, dem's fightin words!!! (not really)  010!
Personally I like the inverted version better, and until recently only ever saw the cowled version, but no one has mentioned the reall drop-dead feature - EXHAUST STACKS!  Yup those 12 outlet pipes on either side that made the Smoothie cool as a Mustang, or the street rod you used to carry it to the field!!!  8)
Heck you leave the stacks off it may as well be... a Ruffy!  ;D
  • High Desert Flier
« Reply #12 on: October 13, 2009, 12:29:20 PM »
You know, I made some of those but never did put them on....my bad!   :-\
« Last Edit: October 13, 2009, 01:04:29 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #13 on: October 13, 2009, 08:38:21 PM »
Sorry Clint, I have to side with Pete on this one. All the photos I have been able to locate of Mr Palmer with a Smoothie in his hands show the inverted cowl. That said, I built both of mine with the upright engine and boy is it easy to access and start! But the next one will be inverted. So I play no favorites as long as it has eliptical tips.
Pete, would that ceramic venomous lizard be Heloderma Suspectus Suspectus (reticulated), or Heloderma Suspectus Cinctum (banded)?
  • High Desert Flier
« Reply #14 on: October 13, 2009, 09:41:30 PM »
Mike, wow, them's some words, but I think Rocky is the banded type. I'll post a pic along with my latest project if I can get my digital camera to work, in the meantime I think I had better make another set of exhaust stacks.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline dave shirley jr
« Reply #15 on: October 13, 2009, 11:22:24 PM »
"heloderma suspectus"
HMMMM. I might have to use that for my next airplane name.
Since Jim Aron allready used systrema
Dave jr.
« Reply #16 on: October 14, 2009, 10:03:30 PM »
Since we all have a love for this curvaceous design and its history, I pulled out a biography of Bob Palmer by Steve Sobel (an L.A. modeler I met at the 2007 Palmer meet in England). He recites that the first Smoothie had the odd airfoil, which Palmer had discussed with a designer at Lockheed. This was 1952. It did not fly well, as we could have predicted with another 57 years of hindsight, and Palmer redesigned it with a conventional airfoil. According to Steve (who I believe had access to Bob Palmer for the story) Palmer argued with Veco but over his objections they went forward with the weird airfoiled smaller prototype rather than the better flying successors. (I don't know what the 1952 magazine published but that would be interesting to see.) Palmer took second at the 1952 Nats with the redesigned larger version, missing first place by only a third of a point! Thus, the Veco version is not a winner in Palmers hands, but the one Brodak (and Palmer) call the "original Smoothie" is a winner, even though it plainly is not the "original" version. The article has a 1952 photo of Palmer holding an inverted, cowled Smoothie that looks like a photo negative of Pete's (the Palmer is mostly dark with light trim). By 1953 Palmer was working on the Thunderbird and development of the Smoothie stopped, or more accurately continued as the T-Bird. If anybody wants a copy of Steve's article send me a pm.
  • High Desert Flier
« Reply #17 on: October 14, 2009, 10:30:29 PM »
Thanks Mike, that's the pic I based my model on. The photo negative analogy was appropriate as I intentionally used the actual trim scheme but substituted light (Sig Diana Cream) where Bob's was dark and vice versa. As to the actual colors, I had to use my imagination as I have only seen the B &W photo you mention. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline John Miller
« Reply #18 on: October 15, 2009, 11:09:56 AM »
Just to add my own comments regarding Bob and his Smoothie.
When I was asked to draw the plans to be used for the Brodak version, I was put in touch with Bob via mail and phone. We spent a lot of time talking about the design, and it's variations. He relayed to me his reservations over the Veco and the M.A.N. versions.
He told me that he got the airfoil from asking the Lockeed engineers what, "in their opinion", was a good airfoil for windy weather. The showed him the airfoil they were using for the Hercules horizontal stab, and assured him that it was a good airfoil for turbulence.
He built the first Smoothie using that airfoil, and in normal weather he felt it was lacking in some of the areas we need, like cornering. He did say it flew fairly well in the wind though.
Since he wanted a better flying design for normal weather, he built his second one using the standard 4 diget NACA airfoil. Now, he had a plane that flew in most conditions the way he wanted it to.
He told me that he had finished them with identical trim schemes, and would go to a contest with both of them in his trunk. If it was windy, he would fly the first one, but that he most often flew the second version.
He wanted the second version as the one to be kitted, and published, but as he was traveling at the time, Henery at Veco submitted the first version to be published and kitted. He was pretty upset about that, and you could tell that even in later years, it upset him.
So I could have as accurate as possible information to use for drawing the kit plans, Bob sent me the original drawings, on "Butcher" paper for his preferred version.
I returned the originals to him after I finished the plans, but not before I made a copy for my records. The kit sold by Brodak is as accurate as I could make it to the original.
I did do a modification a year ago, that showed the changes needed to make the Brodak version into an inverted engine version. It's a jpeg and is down loadable from my web site. www.cadclassics.net   H^^
« Reply #19 on: October 15, 2009, 02:33:48 PM »
Wow, can't ask for anything more authoritative than that! Thanks John for adding this to the lore of the Smoothie. It would be cool to include a blurb like this either on the plans or in the kit box (and that goes for the ARFs too); chances are good that anyone who buys a Smoothie would appreciate knowing more about its history. This is something that would be good in Stunt News if not previously published, or as a reminder if it was published years ago. I will hunt down the issue that featured Bob Palmer on the cover after he passed away.
Offline Dave Wenzel
« Reply #20 on: December 11, 2009, 04:41:38 PM »
Santa's little Elf, Mailman, just delivered a new Dumas Smoothie kit. Pic is one I built about 1975. Anyway, My old one flew good as best as I can remember, and am flying a Brodak ARF right now that is great. My question is about the airfoil. Should I use the ribs as they come in the kit, or try to shift the high point back by cutting new set of ribs? Other pic is arf Smoothie and RSM Ringmaster if they go thru. Being a C/L retread I am enjoying C/L much more than when I was younger.
Thanks for your opinions in advance.
DAVE
AMA 39847
BPA 6X
Offline Dave Wenzel
« Reply #21 on: December 11, 2009, 04:44:36 PM »
First pic did not go thru, so here it is.
DAVE
Offline John Miller
« Reply #22 on: December 12, 2009, 12:53:33 PM »
Hello Dave
You may want to consider hanging onto that Dumas kit as a collectable. If, on the other hand, you decide to build it, it should be built IMNHO as it was kitted.
Changing the airfoil on the kit model could be done, and Brodak will sell you a wing kit for the Original Smoothie, but there were a few other changes in moments that you might not want to over look.
If I was to be wanting to build a Smoothie, I'd start with the Brodak kit myself.
Offline Dave Wenzel
« Reply #23 on: December 12, 2009, 04:40:51 PM »
Thanks John;
I think my path will be to trace out a new "kit" and build that and keep the original in the box. Will use the original airfoil as you suggest. In reality, I couldn't tell a good corner from a wobbly one, and I'm not that good at making either. Lazy eights and when I get a good engine run, I jump up and down in joy when I do a really bad wing-over. Will plunge on, and continue to enjoy. Am finishing up a Top Flight ARF Nobler, OS46LA-S up front. Don't really cherish ARF's, but don't want a figure 9 to tamp down my flying opportunities.
DAVE
