  • May 23, 2024, 10:07:14 AM
Author Topic: Sig Banshee CG?  (Read 2964 times)
Offline Chris Lambdin
Sig Banshee CG?
« on: July 27, 2021, 05:05:04 PM »
Pulled out a Banshee I built 30 years ago only flew it once, where should the CG be on this plane? Right now it’s about half an inch in front of the spar or right on the spar without the muffler. Thanks
Re: Sig Banshee CG?
« Reply #1 on: July 27, 2021, 08:19:00 PM »
   Anywhere between the spar and leading edge should be safe territory for balance. If you are a rank beginner, leave the muffler on and add a bit of nose weight. If you can competently fly the model without crashing and do simple tricks, try it where it is after a few flight with some extra nose weight.  Doc example is the old school method like he said, but it works, just keep any weight additions or removals a little at a time.
Re: Sig Banshee CG?
« Reply #2 on: August 09, 2021, 04:23:39 PM »
Thanks for all the good advice!
Online Tim Wescott
Re: Sig Banshee CG?
« Reply #3 on: August 09, 2021, 04:27:55 PM »
What Doc said if you're learning.  If you really want to trim for performance then you want to get a handle with adjustable leadout spacing -- then you adjust the CG to get the plane to do the right things, and you adjust your handle so that you get the right amount of turn when you ask for it.
Online Colin McRae
  • Are we having fun yet??
Re: Sig Banshee CG?
« Reply #4 on: August 23, 2022, 09:14:32 AM »
The design SIG Banshee CG point is right at the wing spar. I balanced mine there and it flies quite well.
Re: Sig Banshee CG?
« Reply #5 on: August 23, 2022, 11:26:19 AM »
   Might run better ad ne a bit more easy to tune if you swapped the needle valve assembly around, put the needle at the top. Will shorten the fuel line run and be lots easier to adjust the needle. You can shorten the spring a bit also, just unscrew the knob, cut the spring in hall, screw the knob back on, put a touch of CA on it to help hold it.. You will notice that it doesn't shake like a tuning fork that way, and that can affect the needle setting and how the engine runs. If you see the spring shaking all over the place, the pointy end can also. They are connected.
