  • July 07, 2025, 11:20:46 AM
Author Topic: Shark 35 - finished at last  (Read 2959 times)
Offline Balsa Butcher
  • High Desert Flier
« on: October 26, 2012, 04:36:36 PM »
Shark 35 from RSM kit. Power: Enya 40 XCS. Finish: Dope over silkspan. Weight: 47.5 ounces. Still some trimming out to do but flew complete pattern on third flight. Any tips from other users of this engine would be appreciated. A search shows 11x4 to 11x5 props on a 4-2-4 run seem to be the preferred setup. Best prop so far a Bolly Clubman 10.5x5 but still experimenting. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Dan Bregar
  • Field Marshall
Re: Shark 35 - finished at last
« Reply #1 on: October 26, 2012, 04:43:54 PM »
Very, very nice !  Is there prop clearance for anything more than a 11" prop ?
Dan
AMA 33676
  • High Desert Flier
« Reply #2 on: October 26, 2012, 04:56:22 PM »
No, 11" is the max for this setup. Next prop I will try will be a CF Bolly 3 Blade 10 1/4 x 6 1/4. Engine seems to like to run a slight 4-2-4 break in the 9000-9500 rpm range. This prop may not work but it sure looks cool! 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Dan Bregar
  • Field Marshall
« Reply #3 on: October 26, 2012, 05:15:31 PM »
Thanks Pete
Good luck trimming her out.  I'll bet your gonna like this bird.  Very attractive scheme.  I'll stay tuned for your later flight reports.  A job well done ! That Enya is waaay better than Pirelli  LL~
AMA 33676
« Reply #4 on: October 26, 2012, 08:20:01 PM »
Pat Johnston (the guy that drew the plans for RSM) flew his with an OS 46LA. Pretty good plane.
Offline John Sunderland
« Reply #5 on: October 26, 2012, 08:25:47 PM »
Very nice! I was planning a build of this model for this winter but life keeps getting in the way of execution.
  • High Desert Flier
« Reply #6 on: October 26, 2012, 09:56:23 PM »
It is definitely worth building and Pat did do a great job on the plans. I went with the Enya because I was impressed with the way it ran. It is the same size, weight, and mounting pattern as an AT-36 (still an option).  8)
« Last Edit: October 26, 2012, 10:55:21 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #7 on: October 27, 2012, 09:01:53 AM »
I know people don't like to do it, but, larger wheels will give more ground clearance.   Flying off of grass most of the time I go with larger wheels than what the plans show on the planes.  By the way the Shark looks great.
  • High Desert Flier
« Reply #8 on: October 27, 2012, 09:45:50 AM »
Thanks Doc, the Shark actually has pretty large wheels. 2 1/4 mains, 1/ 3/4 nose and no problems at all flying off the moderately tall grass at our flying field. An 11" will be plenty of prop diameter for this engine, just have to find the right one.  8)
Pete Cunha
Sacramento CA.
AMA 57499
