  • August 01, 2025, 04:10:42 AM
Author Topic: Sea Vixen Construction  (Read 3707 times)
Offline Tom Niebuhr
« on: June 20, 2007, 05:09:24 PM »
The Sheeks "Sea Vixen" is started!
This, hopefully, will be my Sheeks entry for the 2008 VSC XX.
Jack Sheeks has been very helpful, and patient with my questions.
The photos show the Trial Fit of spars, and booms.
With a close look, you will notice red line corrections to the drawing. The FM plans directory says the span is 56", the FM plan is 52.5". Jack confirmed the span is actually 56" and the plan is too small. We agreed on how to increase the span for an accurate reproduction of the airplane.
When starting the building I also found that the spar detail was drawn incorrectly. The spar tip height is correct, but the the spar height at the root is 1/4" too small. This is obviously a drafting error since the mistake is equal to the total height of the 1/8" spar caps.
At first I was concerned about the strength of the "V" configuration of the spars on the swept wing I-beams. But when the 1/8" ply "V" is added to the top and bottom of the spar. it is amazingly strong! The "V"s are flush with the top of the vertical spar and under the spar caps. You can the see the plywood "V" at the top of the spar.
If you are considering one of the swept wing I-beamers, this area is fine.
The bellcranks are part of the trial fit. The spar is built first.This takes time, so that the interconnect rods, will go though the spar with no binding. The interconnect rods and bellcranks required long slots in the spars, so I have added 1/4" wide, 1/16" ply spar triplers to the top and bottom of the vertical spar face in this area. If you look closely you can see them in picture #2. The triplers might not be necessary, but I will feel more comfortable with them.
I will be adding a 1/8" ply plate to the bottom of the spar to allow for a removable landing gear. This will replace the standard spar cap in the gear area. The bellcrank pivot bolts will be trapped by the same plate on the spar bottom, and a simple smaller plywood piece in the area as part of the top spar cap. The spar caps are not installed on the spar yet.
The "Sea Vixen" requires a lot of forethought, but will be worth it. I have made mockups of the controls and the aft booms and rudders, to check for potential problems. I will show progress reports, periodically.
I have added photos of the only flight worthy "Sea Vixen"
This airplane was flown in Red Bull colors for a few years, and has just been repainted to the Royal Navy Colors. That is how I will paint it!
AMA 7544
Re: Sea Vixen Construction
« Reply #1 on: June 21, 2007, 07:59:19 AM »
Looking great so far, Tom.  The crossover pushrod from CF tube and ball links should be a very smooth operating system and alingment is certainly simplified!
Keep the pictures coming.  I have been fascianted by that plane since I first saw the article!  What will be the power source?
Bill <><
Offline John Miller
« Reply #2 on: June 21, 2007, 08:10:19 AM »
Tom, looking real good there. You've got the jump on me as I'm not finishd with the CAD work yet on the Torino. I am really looking forward to seeing more build pics as you go along.
Great start.
John Miller
Offline Jim Pollock
« Reply #3 on: June 21, 2007, 09:42:46 AM »
Tom,
Wish I could build like you do!  It's going to be a gorgeous airplane.
Are you going to paint it like the picture, or maybe the one in Thunderball?
Jim Pollock   H^^
« Reply #4 on: June 21, 2007, 10:55:30 AM »
Tom, Looks really great. After you posted this, I pulled out the plans I have for the SeaVixen. I can see what you're talking about, but how did you increase the span? Just pull it out or did you change the chord?
I'm considering a swept wing Sheeks plane for VSC. We'll have to see. Maybe a Swinger or Freedom 45 or perhaps the Scottsman. Hmm, a Knight?
« Reply #5 on: June 21, 2007, 05:42:32 PM »
Randy: I already called "dibs" on the Swinger! (meaning I'll have to build it AND figure out how to miss 2 weeks work to do VSC)  n1
Tom: uhh, looks like our spar got seriously BENT!  LL~
btw,  WHO got the franchise to sell Tom multiple bellcranks he needed for this bird??? SOMEONE got a guaranteed profit on the VOLUME!
Tom. its also looking like a REALLY good start.   CLP**
jealous & moping in Marshall...
« Reply #6 on: June 21, 2007, 08:29:14 PM »
Dennis I also have thought about the Swinger for a long time. The Body is hard to figure out from the plans. I sat down with Jack a few years ago and went over the plans with him. Its built with one body going into another body.The front extends to the back and the sides are added to the back 2/3. He said build it any way I want just to get the basic shape. His weighed over 60 ounces and still flew sort of OK. A lot of changes could be made to keep it light.He made a lot of notes on my plans.The one big change to all of his swept back wings is to move the leadouts back into the wing.Many had the front leadout coming out the leading edge. Move the bellcrank back near the trailing edge and run the flaps off the elevator pushrod.I can draw you a picture if you want. It is very easy to do and it gets rid of the swept wing problem of one flap moving more than the other.
Ed Ruane
« Reply #7 on: June 21, 2007, 09:47:55 PM »
Ed:
I know what you mean about the fuse - its almost like it has 4 fuse sides!   ???  I figured on running the inner/forward fuse sides back only as far as the wing TE then starting the outer/aft fuse sides to the tail.  Plans show the leadouts inside the wing already.  the article shows a pix with the leadouts out front, then refinished with the leadouts inside.  It seems like it had to be a second airplane!
It does not look like it would HAVE to build heavy, seems like it could be built ion the low to mid 40's without too much effort - but I am always an optimist about weight.
The high wing (above the thrust line!) scares me a little too, but I think it is manageable.
Besides, it just LOOKS cool!  8)
Offline Tom Niebuhr
« Reply #8 on: June 21, 2007, 11:38:18 PM »
WOW,
 Sounds like like we getting some serious interest in Jack's airplanes. I hope so.
Bill: Power will be a RoJet .40.  That's what I have been using in my "JD Falcon". I don't want to buy another engine unless I have to!
Jim: Yes my intentions are to paint it in the Royal Navy colors as in the above pictures.. BTW. that airplane has a very glossy finish!
Randy: Chord remains the same. The sweep dimension at the leading edge tip remains the same, relative to the root. Just project the tip section out spanwise. This changes spar lengths, and actual sweep angles. I am marking up the drawing as I go. I'll have to take a picture of the redlines at the tip.
You really have a lot of Sheek's airplane choices, maybe Robert can "Speed Build" a few!
Dennis: Yeah the spar is really bent, but not broke! Not only more bellcranks, but more horns and ball links too!
I hope you build the "Swinger" built. I'd love to see you at VSC.. it's been too long..about 35 yrs or more!
AMA 7544
« Reply #9 on: June 22, 2007, 07:42:31 AM »
With the right paint job the Swinger would be a tough looking plane. Very intimidating.Paint it black with red panel lines.
« Reply #10 on: June 22, 2007, 08:40:32 AM »
Ed:
GOOD CALL! like the B-57 Canberra night scheme - hhhhOT!  ;D
I was thinking of something more like the OLD TF-Contender: white with red & grey trim  8)
BTW the your suggestion on flap horns was already in the bag, along with a SINGLE flap horn arrangement.  Just makes better packaging sense and better mechanically too.
Offline Tom Niebuhr
« Reply #11 on: June 22, 2007, 12:12:40 PM »
Ed,
Hutch's F86 uses a variation of operating the flaps from the elevator. The F86 has a rod clamped to the elevator oush rod that goes back forward to the flaps.. See model Aviation 8/2003
In my discussions with Jack, he likes the 2 bellcrank system of the "Sea Vixen". He also did not recommend moving the leadouts back, in fact they had to move the leadouts forward on the original airplane. As I have discussed previously in the "Freedom 45 thread, leadout location is relative to the MAC and CG. It also would be very difficult to come off the elevator to operate the flaps, the "Sea Vixen" has a high tail, and there is very little room in the booms. In fact, with the high tail you have to be creative just to get the elevator to work there is so little room in the aft rudder.
In a non-boomer, like the "Swinger" working off the elevator horn, or a system like the F86 will work very well.
AMA 7544
« Reply #12 on: June 22, 2007, 09:05:49 PM »
Tom I was referring to the Swinger only
Offline Tom Niebuhr
« Reply #13 on: June 23, 2007, 04:45:16 AM »
Ed,
Thanks for the clarification. I agree, it would work fine in the "Swinger".
Ty,
Sorry no "Sea Vixen" kit in the future. I don't think it is an airplane with sufficient potential interest that would validate the work involved, and the costs of laser cutting all those ribs, etc.
AMA 7544
Offline Tom Niebuhr
« Reply #14 on: July 01, 2007, 08:41:17 PM »
Here is the Sea Vixen as of today. It took wuite a bit of time to fit the bellcranks and interconnect rod. Much care is a must to assure free movement ina cramped space, before final installation of the I-beam.
Picture 1: Bottom with bottom ribs and booms
Picture 2: Bottom at fuselage root, and inboard bellcrank
Picture3: Shows inboard bellcrank, and the plate for the removable gear. The 3/4" rib in this area will be cut to allow for the gear cover, which will follow the contours with the booms.
AMA 7544
Offline Tom Niebuhr
« Reply #15 on: July 10, 2007, 09:01:15 AM »
Here is the completed main landing gear door.
AMA 7544
