  • August 01, 2025, 07:31:11 PM
Author Topic: Opinions about refinishings  (Read 3487 times)
« on: August 17, 2007, 02:41:33 PM »
I'm getting ready to start refinishing my classic Cobra. It was originally painted with dope with catalyzed polyurethane as the topcoat. The plane needs some alterations in the controls so that a human can fly it, but once that's done, I plane to strip the finish and redo it. This was the 6 day wonder paint job I did a couple of years ago for VSC and the plane really deserves to get a nice finish. It currently weighs 45 or 46 ounces, most of the extra weight is in the ridiculously rushed finish. I'm hoping that along the way I can knock a few ounces off of it as well.
My plan is to use a combination of lacquer thinner and naptha with steel wool to take the finish down. I thought about stripper, but was afraid it would get into the wood and cause problems. Once I get it back to silkspan I imagine there will be some patching involved and some reshoot of primer in some areas. Then I repaint and reclear it. Probably all dope this time.
Any thoughts or ideas on this process? Based on some previous experience, I don't expect it to take too long to take the finish down to the silkspan, but if you've done this before, I'd love to hear any thoughts about it or tricks you learned.
Thanks for input.
Offline Jim Oliver
Re: Opinions about refinishings
« Reply #1 on: August 17, 2007, 04:07:23 PM »
Watching this one with great interest--- maybe I will learn something. #^
Jim
Jim Oliver
AMA 18475
Offline Tim McTigue
  • MAAC 65703
    • Tim McTigue's Control Line Model Aviation
« Reply #2 on: August 17, 2007, 07:13:25 PM »
I second the comment on hoping to learn something.  Randy, any chance you can post pics as you go?  Maybe in the "Building Techniques" forum?  I'm amazed you can take the finish off and leave the original silkspan.  My expectation would be you'd have to just remove the 'span, remove finish from elsewhere, re-silkspan, etc...
__________
Tim
Online Dennis Adamisin
« Reply #3 on: August 17, 2007, 09:13:14 PM »
How timely can you get.
I am trying to salvage an OLD stunter too.  I my case it is all wood (foam wing) with a hurried but thin dope finish.  It ought to be easier than stripping down an I-Beamer!  Because the finish is thin I was considering power sanding it down, then re-priming etc like you described.  I have also wiped down some areas with denatured alchohol and it will remove the dope, with steel wool it would go a lot faster.
I guess I thought the urethane finish was impervious to any chemical strippers.  Are you counting on the steel wool to abrade that finish off so the other chemistry can go to work on the dope underneath?
If you can safely get down to the silkspan you should be in GREAT shape to re-finish!
« Reply #4 on: August 17, 2007, 11:18:36 PM »
Dennis,
I can tell you from experience that using 000 steel wool and a bit of lacquer thinner and it will cut right through catalyzed urethane. I've done that before. Once I get through the urethane and if I can manage to not take too much of the color off, I'll switch to naptha for the dope. While you can use naptha to clean a dope surface for further painting and such, with steel wool, it takes dope off pretty quickly. I think the method will work fine, just wondered if others that have done it had any trick they might want to pass along.
I've used the techinques separately for other things, but never tried it all together. Guess we'll see.
Offline James Mills
« Reply #5 on: August 18, 2007, 11:10:03 AM »
Dennis,
I probably should already know the answer to this, but what is naptha?
James
AMA 491167
Offline Tom Perry
« Reply #6 on: August 18, 2007, 06:32:03 PM »
James
Cigarette lighter fluif is mostly naptha but it's cheaper to buy by the gallon at a hardware or paint store.
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #7 on: August 18, 2007, 08:07:45 PM »
Randy,
I used a product called Dad's stripper on my Veco Chief when the clear Hobby Poxy job went sour. It did a beautiful job even with the Hobby Poxy and had no negative effects on the wood. The model is covered with dyed silkspan and clear doped and there are zero visual effects from the stripper. I and going to redo the Gladiator and I will again use the Dad's. I got it from Home Depot and it comes in a steel can with a plastic spray bottle. I sprays on neatly, stays put, and works FAST. Absolutely the best stripper I've ever used for models. With the silkspan on the Chief there were about 3 coats of clear and 2 coats on Hobby Poxy. With this stripper I was able to lift an edge with an Exacto and actually peal enter panels off. A quick wipe down with dope thinner, a quick sanding and I was ready to cover it again.
Worth a try!
« Reply #8 on: August 18, 2007, 09:10:02 PM »
I've got a couple of models I need to strip and refinish, so I'll be watching this thread. Please post your results as they happen!  LL~ Steve
« Reply #9 on: August 19, 2007, 01:01:37 AM »
Randy,
Thanks for the tip. I tried some aircraft stripper on a test piece (bottom of a wing on a "retired" plane) and it made a hash of things. Actually ate into the silkspan. I'll head to Home Depot and get some Dad's.
Steve,
I won't be starting it for a bit yet. But if the stripper Randy suggests works well, maybe the Novi will get the same treatment.
« Reply #10 on: August 19, 2007, 07:41:30 AM »
Randy,
Steve,
Hi Randy,
I posted on SSW a few years ago about the "Dad's Stripper".  Aaron found it at Wal Mart and it came with a squirt bottle to fill and use.  It will take off as much or as *little* as you want.  It will depend on how long you leave it on the surface.  We gat a new roll of paper towels, set the plane on soft pads and go to town!  It will take a layer of dope off about as fast as you can spray  it on and wipe it off.  A *little* longer wait and it will really work.
As Randy said, it will even remove the silkspan substrate if you care to.
We have done three refinishes with it.  Aaron's Ares, my P-47 and a SV-11.
DO NOT LET IT GET ON A PLASTIC CANOPY!  That is the ONLY problem we had with it.
« Reply #11 on: August 19, 2007, 10:27:35 PM »
Bill,
The Cobra has a simulated canopy so no problem there. Hey, maybe this is the way to fix the slightly warped canopy on the Novi; just melt it off.  :)
I'm just finishing up the framing on the new PA plane. Just making the gear and wheelpants now. Should be done in a few days and I will slop a couple of coats on it and then get started on the Cobra.
« Reply #12 on: August 24, 2007, 07:40:12 PM »
I had to go to Homey Depot today, and looked for the Dad's paint stripper. No luck at finding any product from Dad's. I did find two products from Mötsenböcker's, and brought them home. The first, in an aerosol can, is Liftoff 2. It is claimed to remove grease and oil stains from anything. Maybe a K2R substitute? The second one is in a spritzer bottle, called Liftoff 4. It's for Graffiti, and will remove most things applied by aerosol can without damaging the fence or building surface. Maybe it will take the paint off stunters, along with some Scotchbrite or (stainless)steelwool and papertowels.
Another thought...we use two kinds of Layout Dye Remover at work, in aerosol cans. One, Dykem brand, is very mild, mostly liquid propane. I wouldn't use it next to the furnace or hot water heater, but I think it would be good for taking tape goo off, or removing India Ink faux paux. Crown brand is a bit more aggressive, and it's what we use mostly. Either is more expensive than a gallon of MEK or alcohol, but there are no stupid questions from the EPA about how we disposed of the "dirty" gallon of MEK! SOP is to put it in a "wash bottle", squirt some on the part, wipe the part clean, let the stuff evaporate, throw the rag in the safety can...or someplace close to it, or on the floor...my co-workers are mostly pigs, it seems.
Needless to say, test these products with some care, in those "inconspicuous" areas where nobody will ever notice.  LL~
 H^^ Steve
« Reply #13 on: August 24, 2007, 07:54:19 PM »
Try a Meijer's Steve, I've heard its carreid there too.
« Reply #14 on: August 25, 2007, 11:23:34 AM »
Hey, Steve, you got a Wally World around there??  ;D
« Reply #15 on: August 26, 2007, 09:04:43 PM »
AFAIK, we got no Meijer's. We got Wally's World some years ago, but I generally avoid them like the plague they are. I may have to make an exception. I did a Google for Dad's Paint Stripper (or something like that) and found a blog where they reported the stuff was in WW's and K-Marts. There were lots of folks recommending it, and lots asking where to get it. Apparently "Dad" doesn't have a website? I'll probably check at McLendon's Hardware first, because if it's worth having, they generally do. A local hardware chain that is just WAY too good not to patronize.  H^^ Steve
« Reply #16 on: August 28, 2007, 08:21:27 AM »
Unfortunately, I have not found it around here in any store besides Wally World.  :'(
