Classic Designs => Classic Planes => Topic started by: Al Rabe on November 28, 2006, 08:23:19 AM
In 1969, I had just finished the molded Bearcat III and was thinking of putting together a simple stunt ship just to play with. There were many Orientals around here in Dallas. I had used one to win my first contests. That first Oriental also happened to be the first airplane used to experiment with an idea that I had about yaw control and movable rudders. I cut off the vertical tail surfaces and retrofitted the first movable rudder onto that Oriental.
Anyway, I decided to build a modified Oriental specifically designed around the movable rudder (Rabe rudder), a fatter airfoil, semi-scale features, sliding block adjustable leadouts (an original idea), upright engine, a full house of trimming adjustments including variable ratio flap/elevators, some molded components and simplified construction. It turned out to be an excellent little airplane. It was used for several contest wins and met its end at Shreveport when a judge walked into the circle. He wasn't hurt but the airplane was destroyed.
There were request for plans and a goodly number of Mustunts were built locally. That first Mustunt was later labeled a Mustunt II. In 1970 some local flyers began to fly profile Mustunts, so I legitimized the airplane by redesigning it for even simpler construction while retaining the semi-scale military character. This airplane retained the aerodynamics of the Mustunt II but omitted formed wingtips for simplicity and trimming ease. It also featured an upright or inverted engine with a molded cowl and plastic wheel covers to dress things up a bit. It was a popular design.
In late 1971, I decided to write an article about trimming and learning to stunt using the basic Mustunt design and offering progressive stages of improvements for developing stunt flyers. To complete the series, I designed and built the Mustunt III and sold the article to American aircraft Modeler for publication in the Feb 1973 issue.
The article was well received and in the next to last paragraph, I stated there was enclosed in the article a thinner rib template for Mustunts needing less lift than provided by the original thick section. Thinner wing Mustunts were refereed to Mustunt IIAs. The thinner wing rib template was somehow omitted from the published article. The wing rib existed as part of the original design, differing little from an Oriental rib. it should probably be considered legal for Classic Mustunts.
OK, so the Mustunt was a "bashed" Oriental. I guess I shouldn't have taken it so personally when Sig kitted the "Twister" shortly after the Mustunt article was published. Did anyone else noticed the resemblance of this profile stunt trainer with its fat constant chord wing and square tips? I think they missed the Mustunt I's best feature of having an upright engine for simple engine operation for beginners.
Al
Al
Al;
Just curious, but if you were to built a Mustunt today, which of the moderately priced engines would you put in it, or would you stick with the Fox 35?
V/r
Bob
Bob,
Today, I'd use an OS 40 or 46 because I have one not in service at this time. Thanks for asking. If I didn't care about P-40 or classic, I'd proably build a Mustunt III with the OS 46 and shock gear. the nose needs to be a bit longer to make room for 5 oz tank, otherwise, there would be no need for changes. Building a Mustunt II would be much faster and I'd use the thick wing for the extra weight of the larger engine and fuel load.
Al
Al: A couple of weeks ago I saw on I believe it was Tanks web site that they were going to kit the Mustunts. I checked today and didn't see that. Are there still plans for the kits ? Any info would be great. Thanks
Bob,
Al
Al;
Actually I was thinking of the LA 40 or 46. The only other thing I was thinking of was lengthening the fusel just a little aft of the wing to compensate for the heavier engine and longer nose needed for the 5 oz tank. And, perhaps enlarge the elevator and stab just a bit. It would not be classic "legal", but .... Its hot on my mind once this long TDY I am on is finally over.
Just another question - how thick is "thick?" I believe the plans that were published have the "thinner" wing.
V/r
Bob
Bob,
Actually, I was thinking of the LA series. I have a LA46.
Second, the plans are illustrative of the original fat wing airplane. The thinner rib has never been published anywhere. It was supposed to be in the article but never made it into the publication,
Third, Sure, lengthen the fuselage, enlarge the stab and elevators, paint it red with white candy stripes but please don't call it a Mustunt. the Mustunt II has a nose long enough as published, to accommodate a 5 oz tank by simply moving the front tank bulkhead a bit. This can be done without altering the external dimensions of appearance of the airplane, not that there is anything sacred about the shapes and dimensions of the Mustunt. Its just true that when you redesign an airplane, you will have differing handling characteristics and maneuver capabilities..
Al
