  • August 03, 2025, 05:50:51 AM
Author Topic: Olympic: Finished at Last.  (Read 3058 times)
Offline Balsa Butcher
  • High Desert Flier
« on: June 17, 2010, 07:58:15 PM »
Y'all are probably tired of seeing this model in various stages of completion but here it is finished, at last. First flights today, pretty much flew the pattern right off the board.  A little flap tweak and remove some nose weight and go for it. Engine still needs some tuning, a Magnum .36, still experimenting with props. All-up weight is 44 ounces, not bad for a kit built Olympic.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Mike Scholtes
Re: Olympic: Finished at Last.
« Reply #1 on: June 17, 2010, 10:12:39 PM »
Great job Pete!
If I type fast enough I may get to be the first to congratulate you! That is one awesome model and a unique paint scheme. As a fellow Olympian, I wish you square corners and tight lines!
And how the heck did you build this to 44 oz? Water colors?
« Reply #2 on: June 18, 2010, 08:50:52 AM »
Pete,  love your Olympic.  Sand paper and watching finish coats does help keep the weight down, doesn't it?  Mine was built from kit also.  The one kit I had left is now on it's way to the NATS for some beginner to enjoy.  Did I say that is a gorgeous paint scheme? H^^
« Reply #3 on: June 18, 2010, 09:54:04 AM »
Looks very nice, Pete.
  • High Desert Flier
« Reply #4 on: June 18, 2010, 10:10:04 AM »
Thanks All, great pic icon Doc. Yes, use lots of sandpaper and building with lots of air helps keep the weight down. Also, this was one of the first Olympic lazar cut kits from Brodak and the wood was excellent. Fuselage gear, no tail wheel strut and light weight hardware (nylon 4/40 screws where I could get away with them) help also. FWIW: Mag .36 is to be replaced by an Aero-Tiger, you need all the power you can get when flying at 5,000'msl.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Kim Mortimore
« Reply #5 on: June 18, 2010, 11:49:19 AM »
Pete,
Is that a RoJett muffler on the Magnum?  Have you weighed it?  Great color scheme.  The asymmetrical dip in the black trim lines over the AMA number is way kewl.   y1
Also, the cursive lettering style is very attractive.  How did you do the lettering?
I'm sure there is lots of interest in hearing how the switch to the Aero Tiger affects performance, if you would like to let us know at that time.
Thanks!
Kim Mortimore
Santa Clara, CA
  • High Desert Flier
« Reply #6 on: June 18, 2010, 12:12:24 PM »
Hey Kim, good to hear from you. Yes, it is a Ro-Jett muffler. Weighs 1.1 ounces. It has been swapped out for an Aero Products muffler, also 1.1 ounces. The main difference is that due to the design, the Aero Products muffler has a larger exhaust intake opening will be freer flowing. As far as the paint scheme goes, it is the 4th plane (Vector, Magnum, Buccaneer and now this one) I have painted with a similar scheme. It seems to work well on a variety of designs. Lettering is painted with a stencil ordered through Jim Snelson at CLC. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #7 on: June 18, 2010, 12:38:24 PM »
I believe it was the Vector that you redesigned with the open cockpit and some other changes.  That plane was awesome-looking.  Good thing I didn't have a chance to steal it or I might be in jail right now!  LL~ VD~
Kim Mortimore
Santa Clara, CA
  • High Desert Flier
« Reply #8 on: June 18, 2010, 03:15:10 PM »
Yup, that was one of them.  8)
Pete Cunha
Sacramento CA.
AMA 57499
  • High Desert Flier
« Reply #9 on: June 18, 2010, 07:00:56 PM »
Go for it Tye, just mention my name when you win the Concourse award at the Nats.  ;)
« Last Edit: June 18, 2010, 09:28:59 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #10 on: June 18, 2010, 10:23:42 PM »
Hey! Looks great, Pete. Are you going to bring it to the Mackey contest?
« Reply #11 on: June 19, 2010, 09:17:16 AM »
I have falllen in love again.  This may be a modern plane design but, really looks like a plane from the 30's-40's style.   H^^
  • High Desert Flier
« Reply #12 on: June 19, 2010, 06:25:37 PM »
Thanks Doc, that was the plan. Actually though, the model that gave me the idea for this kit-bash was John Sunderland's "Chevelle" stunter as published in FM. A much bigger plane but has the same "vibe".  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #13 on: June 20, 2010, 02:05:15 AM »
Very nice, Pete.  Too bad about the trim peeling back on the right wing like that.
  • High Desert Flier
« Reply #14 on: June 20, 2010, 09:33:14 AM »
Yup, seems to happen a lot on my models...and for Clint: Mackey?, maybe.  8)
Pete Cunha
Sacramento CA.
AMA 57499
