  • August 02, 2025, 03:35:39 AM
Author Topic: wheel skirts instead of wheelpants?  (Read 4987 times)
Offline Matt Colan
« on: March 21, 2010, 05:54:55 AM »
Pretty soon, I'm going to get back to work on my Cobra, and I don't want to deal with wheelpants, because the Cobra's pants are EXTREMELY chunky.  If i put wheelskirts on the airplane instead of wheelpants, is the plane still classic legal?
Offline James Mills
Re: wheel skirts instead of wheelpants?
« Reply #1 on: March 21, 2010, 04:03:51 PM »
I think as long as the wheel placement doesn't change you're okay, you'll take a hit on fidelity points more than likely.
James
AMA 491167
« Reply #2 on: March 21, 2010, 06:04:12 PM »
Basically, there's no rule in the Classic rules, that allows a disqualification for any modifications to the model.
And I don't know what "wheelskirts" are. The usual option is fake LG doors (which I like), but don't think I could do that to a Cobra. I'd say that if you think the Cobra wheelpants are "chunky", then you should thin them out and shape them as you like (within reason) and not suffer any points penalty.   ~>  Steve
Offline Matt Colan
« Reply #3 on: March 21, 2010, 07:19:31 PM »
Landing gear doors is what I meant, but for some reason, I don't know why, I refer to them as wheelskirts H^^
Offline Tom Niebuhr
« Reply #4 on: March 22, 2010, 08:17:43 AM »
I don't think that the Cobra wheel pants are "chunky". Matt you have to use more sand paper. The Cobra wheel pants are part of the look.
AMA 7544
« Reply #5 on: March 22, 2010, 10:00:09 AM »
The original Cobra had very slim wheelpants that were sort of pointed at the apex of perimeter. The ones I put on mine were incorrect and as Matt describes them, chunky. If I had it to do again, I would use much thinner wheels and cut them down. But Tom is right, it's part of the look. It just wouldn't be right without them.
« Reply #6 on: March 29, 2010, 06:39:14 PM »
The lad is wondering whether he prefers skirts or pants. (Maybe the boy got into the nitrobenzene.)  Look, Matt, however it turns out, it's OK with us.
Offline Matt Colan
« Reply #7 on: March 30, 2010, 03:23:05 PM »
Part of my reasoning to use "wheelskirts" is because 99% of the time, we fly on grass, and after learning what happens to a plane with wheelpants, and having EXTREMELY long grass, I always now want ground clearance with plenty of insurance to be able to get off the ground easily.  Also I am using 2 1/2 inch, and wide brodak wheels to help getting off the ground which probably is why the one wheelpant I did came out chunky (I could still take some more material off).
« Reply #8 on: March 31, 2010, 10:11:11 AM »
Well, the Cobra is sort of a low-rider. Getting off long grass can be a real problem. Maybe you could add hydraulics.    ;D
« Reply #9 on: March 31, 2010, 10:51:27 PM »
Hey with a set of Al Rabe's spring gear, and a set of Robart air cylindars, yeah, now your cooking, oh man, now where did I put those Cobra plans,, hmmm
« Reply #10 on: December 08, 2010, 10:26:03 PM »
Thats priceless..  I also support any choices you make, I dont think you should be forced by what society dictates.
Offline Dennis Saydak
« Reply #11 on: December 09, 2010, 10:50:21 AM »
The Cobra is one of the sleekest stunters ever designed and the wheel pants are part of the beautiful look. It might even look wierd without wheel pants. That may have a subliminal negative effect as far as scores are concerned. I built two Argus models back in the 60s with wheel pants and never had a problem flying off grass. The models just sort of smoothly walked off the grass during take off, and I was amazed at how whell the flexible L.G. worked. I used K&B slim rat race wheels, which are no longer availble. However, there are cottage suppliers that make similar wheels. I recently ordered some 2" slim wheels for my Umland Cobra kit.
Offline Matt Colan
« Reply #12 on: December 09, 2010, 01:59:32 PM »
I did decide to go with the wheel"pants" for the cobra instead of "skirts" in order to keep the look, just use big wheels and make sure there is plenty of ground clearance.
And believe me, I love skirts!!!!  ;D
Offline louie klein
« Reply #13 on: December 09, 2010, 02:53:04 PM »
Oh you little rascal you!---LOUIE  :## :##
« Reply #14 on: December 10, 2010, 07:40:23 PM »
A kilt is a skirt.. your secret is safe with us Matt :)
Here is another good tip, you can use those ultra light wheels that are foam, and sand them down narrow on a belt sander to get them to fit.
« Reply #15 on: December 10, 2010, 11:52:01 PM »
There is a set of 2 and I think 2 1/2 Inch foam light wheels that are pretty narrow, maybe Dave Brown? I will look since I have a set or two in my wheel drawer, but for now, I am going to sleep,, Matt remind me tomorrow,,,
« Reply #16 on: December 11, 2010, 09:10:52 PM »
On reducing foam wheels. The technique I use is simpler. I put a screw through the wheel with a bolt on the back. Chuck it up in the drill press and use a rough sanding block (80 or 100 grit) and just hold it on the wheel as the drill press spins and low rpm. that them down pretty quickly.
Offline Mike Lauerman
« Reply #17 on: December 12, 2010, 04:55:28 PM »
   Matt...look back at some of the early Seversky planes...some were fitted with 'spats', but SOME had 'Wheel Trousers'! I prefer skirts, too...
« Reply #18 on: December 12, 2010, 04:57:50 PM »
Matt here is the wheels I use. They are 3/8" wide but you do need to put a bearing in the hub. I just use a piece of tubbing that will go over the 1/8: wire gear. Here is a set of wheel pants I made yesterday for my Juno. They took about two hours and that included using a dremmiel to open them up more than is done here. They weigh .5 oz when finished. 1/2" center core a 3/16" sides. Allup weight is 3/4 oz when finished and on plane with struts added and they are glassed.
Offline Matt Colan
« Reply #19 on: December 13, 2010, 02:07:21 PM »
Simplify the problem.  Hopefully you have removable landing gear.  Make two sets, one for grass and one for pavement.   H^^
When I started the thread, we didn't have the wing close to finished yet.  We do have the removable landing gear blocks in the plane, and they should work.  I won't know until I finish working on the TP, as that is a more important project to be working on.
Offline jim gilmore
« Reply #20 on: December 13, 2010, 03:02:04 PM »
Wheel pant's are worn by big burly aircraft.
Wheel skirts are worn by the one's that do the real work.....
Ducking...ok guy's I'm just kidding..
