  • July 16, 2025, 02:18:56 AM
Author Topic: Looking for kit suggestions  (Read 9315 times)
Offline Controlliner
« on: November 30, 2021, 02:09:34 PM »
What kit would ye suggest for an OK Cub .149?
Offline Steve Berry
Re: Looking for kit suggestions
« Reply #1 on: November 30, 2021, 03:17:09 PM »
First thing that comes to mind is a lightly built Flying Clown, or something along those lines.
Sent from my SM-N986U using Tapatalk
« Reply #2 on: November 30, 2021, 03:32:15 PM »
If it's power is equivalent to the Fox then a Flight Streak Jr.
« Reply #3 on: November 30, 2021, 04:37:09 PM »
  So, it's close to a .15? Just making sure of displacement. Have you run the engine on a stand to see how it handles and what props seem to work on it? Instead of the Flying Clown, ( because I'm not that familiar with that airframe) the next down in size is the Circus Prince in the PDQ line. My son framed one up back when he was young teenager recovering from his dive out of the maple tree in our back yard. It's quite light and if the Cub isn't exactly a powerhouse it may be a good match. I would try running the engine and make sure it runs consistent and somewhat reliably. If it doesn't you can just put it in the display case and move on to something else. use some fuel with some castor in it.
« Reply #4 on: December 01, 2021, 08:00:01 AM »
Cub .14 is a very low output motor. Not at all equal to any other.15.   I use to use them in small rc trainers in the 1950’s.  Not a great runner unless it is in new condition. I had one in a small zilch and it was gutless. I put a OS .15 in it and it flew well.
« Reply #5 on: December 03, 2021, 10:07:47 AM »
It gets 11,600 RPM on Zero nitro and 20% Bakers AA castor. And a Fox standard short. Wi ae 8X4. Engine is 2 3/4 oz weight. M' Fox .15 X is 3.6 oz. The Cub is light so the model wae need nose weight depending on which model.
« Reply #6 on: December 03, 2021, 11:58:07 AM »
   Well that sounds pretty respectable. I would say the Circus Prince, or any other real .15 size model should work. If not you could always hunt down another engine. Maybe even the JR Flite Streak. Brodak had a renamed version of the Flite Streak called Lightning Streak in several sizes and you may find a deal on one of the .15 sized kits.
« Reply #7 on: December 03, 2021, 07:12:58 PM »
 Brodak Flying Clown.  y1
 https://brodak.com/flying-clown-kit.html
Offline Fredvon4
  • Central Texas
« Reply #8 on: December 03, 2021, 07:56:20 PM »
I am selling Brodak $92 Lightning streak on RCG for $75
https://www.rcgroups.com/forums/showthread.php?4025185-Brodak-Jr-Lightning-Streak
Fred von Gortler IV
