  • July 16, 2025, 01:23:06 AM
Author Topic: Future paint scheme for the Knight??  (Read 3998 times)
Online Ty Marcucci
« on: November 27, 2007, 01:29:09 PM »
x
« Last Edit: June 23, 2017, 06:36:41 PM by Ty Marcucci »
Ty Marcucci
Re: Future paint scheme for the Knight??
« Reply #1 on: November 27, 2007, 02:39:55 PM »
I'd use a lighter red, but looks fine to me.
Offline Arch Adamisin
« Reply #2 on: November 28, 2007, 03:30:12 PM »
Ty,
Great minds must think alike. I'm also going to paint my version of the Knight like the Rivets. I'm going to have the hoerner tips and the color scheme as it was on it's last flight.
Tucson is going to be a lot of fun. I'm really looking forward to it as well as the Sheeks contest. A nice tribute to great guy and a long time family friend.
     Arch
« Reply #3 on: November 28, 2007, 08:44:14 PM »
Hey, Ty. You could mix your own. My method is, see a car color I like, look the color number up on autocolorlibrary.com and go the the auto paint store and have the guy mix up the color without clear binder. The pour in Randolph's clear as the binder and spray away. Had pretty good luck. The only trick is, you have to make sure the color you're having mixed doesn't have a pearl or metallic that's added in liquid form and it usually has a urethane based clear in it. I just have my guy substitute dry pearl or metallics. Works out well.
And then you could use Ford Performance Red. About the screamingest red out there.
« Reply #4 on: November 28, 2007, 10:36:50 PM »
Don,
The colors on the Rivets are Bright red and bright yellow. Ty's photo is a great one of the plane but the colors are not correct. We've all seen color photos that came nack with different shades than what we really saw.
     Arch
« Reply #5 on: November 29, 2007, 07:56:35 AM »
Maroon cars are not only a hazard on the road, but also in the assembly plant.
In 1985, we replaced mechnical limit switches with "new", "better", "foolproof" photoelectric LS's.   It turned out that the maroon paint we using on the Grand Am was the perfect infrared stealth color.  Our photocells couldn't even see 'em.  In critical cases it was ncessary to add a mechanical 'blinder" to force the LS to see the maroon.
Perhaps the color's ability to absorb rather than reflect infrared light is the root cause of some human's inability to see it.
Offline Shultzie
« Reply #6 on: November 29, 2007, 12:26:09 PM »
YES!....AS I REMEMBER IT!!!! THAT WAS WHAT THE LAB EXPERIMENT was about...how not only human beings see and detect colors when they are put into motion. Our instructor was working at the time with Birds of Prey...and how they perceive prey in flight....and can home in with such accuracy....especially in dim-low light conditions.
Don Shultz
« Reply #7 on: November 30, 2007, 10:38:59 AM »
Hi Ty,
Duplicolor now has their LACQUER in a new series of quarts called PAINT SHOP.  There are 6 or 7 colors right now, but one is Performance Red and another is Chrome Yellow.  Those are perfect for the Rivets/Knight!
The Duplicolor is compatible with Sig and Randolph.  We used this on Aaron's recently finished Thunderbird I.  I get it at Auto Zone along with the Duplicolor Filler/Primer (in gallons!).
« Reply #8 on: November 30, 2007, 10:55:19 AM »
Thanks Bill. I shall try some. Gallons??? .  LL~ Too bad it doesn't come in pints or quarts.
The colors come in quarts like I said! LOL!!
The filler/primer (gallon) also comes in quarts or large spray cans.  But at the rate you build, a gallon of primer isn't out of the realm of reality! LL~
« Reply #9 on: November 30, 2007, 10:55:41 AM »
Hmmm... The primer comes in quarts.
Online Steve Helmick
« Reply #10 on: November 30, 2007, 05:28:06 PM »
"Hmmm... The primer comes in quarts."
Uhhhh....reminds me of an old joke. We won't go there!  n1 Steve
« Last Edit: December 01, 2007, 06:13:30 PM by Steve Helmick »
« Reply #11 on: December 01, 2007, 12:31:06 PM »
Yes, quarts and gallons.  Duplicolor sells its own thinner in gallons, but I use 3608S.
Cheaper by the gallon, though, and it doesn't "go bad" for many years.  So I get it by the gallon when I buy bulk.
« Reply #12 on: December 01, 2007, 05:16:59 PM »
http://www.duplicolor.com/products/paintshop.html
Paint Shop Finish System
Paint Shop Finish System gives you everything you need to create a high-quality DIY finish – primer, color and clear. It’s a high-quality lacquer system designed for automotive and motorcycle applications. Paint Shop is easy to apply, dries quickly and can be buffed to a brilliant smooth finish. Paint Shop is a ready-to-spray system, so no mixing or reducing is required. And with no re-coat window, additional coats can be applied at anytime.
STEP 1
Wash and Prepare the Surface
STEP 2
Prime the Surface
STEP 3
Apply Color
STEP 4
Apply Clear Coat
STEP 5
Post Application Buff and Polish
Related Links
Where to Buy
Coupons & Promotions
Auto Spray Tips
Frequently Asked Questions
Available Colors
Paint Shop Primer
BSP100 Gray
Paint Shop Color
BSP200 Jet Black
BSP201 Championship White
BSP202 Brilliant Silver
BSP203 Performance Red
BSP204 Deep Blue
BSP205 Gray
BSP206 Chrome Yellow
BSP207 Hugger Orange
Paint Shop Clear
BSP300 Clear Coat
Strainer Kit
BSP400 Strainer Kit
Click the link below and then enter a specific SKU to find MSDS data.
MSDS Sheet
