  • August 02, 2025, 03:28:42 AM
Author Topic: Jack Sheeks award for VSC XXI, 2009  (Read 1966 times)
Offline Tom Niebuhr
« on: August 11, 2008, 09:31:46 AM »
John Miller and I are again coordinating plans to present the  perpetual award for the Best Jack Sheeks Classic Stunter starting at the Vintage Stunt Championships, VSC-XXI, starting March 17th, 2009. We are hoping that Jack will be available to be the judge.
In addition there will be an award for the highest placing Jack Sheeks airplane!
Jack Sheeks is perhaps the most prolific designer of Stunt, Scale and RC airplanes of our lifetime. In addition he is one of the nicest people on the face of the earth.
During the Classic Era, (1953 to the end of 1969) Jack published, designed, approx. 20 CL Stunt airplanes. From that time to the present, Jack has published 27 more airplanes in Flying Models alone!
Following is a list of Sheeks airplanes that are eligible for Classic Stunt. This list will be updated if more information becomes available. I want to thank Jack Sheeks, and Frank Fanelli of Flying Models for their help in compiling this information. Special thanks also to Robin Sizemore, and the Cholla Choppers.
Jack Sheeks’ Classic Stunters:
(Ref. Flying Models, Pampa Classic Plans Directory, Wilkes Classic CD))
* Designates those in the current Flying Models Plans Directory
M/Yr Magazine Airplane Plan # Notes
8/63 FM Stuka Semi-scale I-Beam
2/64 FM La Donna I-Beam, Booms
6/64 FM Beech Staggerwing I-Beam, Bipe
8/64 FM F5F Skyrocket I-Beam, Twin Engine
6/65 FM* Sheik CF024 I-Beam, Gull Wing
10/65 FM Stuntliner I-Beam, Swept Wing
4/66 FM* Sea Vixen CF033 I-Beam,Swept wing, booms
8/66 FM* Demon CF049 I-Beam, Swept wing
1/67 FM* Swinger CF067 I-Beam, Swept wing
7/67 FM* Ryan SC CF087 I-Beam
1/68 FM* Focke-Wulf 190 CF106 I-Beam
5/68 FM* Freedom 45 CF121 "C"tube Swept Wing
9/68 FM* Spitfire CF134 I-Beam, Elliptical
1/69 FM* Torino S CF149 I-Beam,Swept wing, booms
2/69 FM* Scottsman CF153 "D"tube,Swept Wing
6/69 FM* Knight CF164 I-Beam, T-tail
4/70 FM* ME-109 CF185 Designed before 1970
7/70 FM* Stuka JU-87 CF212 Designed before 1970 Update of earlier Stuka
Note: also eligible is the ME262 built and published by Jim Vornholt, Flying Models March 1967. FM plan #CF210. Jack Sheeks aided with the design of this airplane
We hope that we will see many Sheeks airplanes at VSC-XXI.
AMA 7544
Offline Balsa Butcher
  • High Desert Flier
Re: Jack Sheeks award for VSC XXI, 2009
« Reply #1 on: August 11, 2008, 11:48:15 AM »
Hi Tom and John:  Just an unsolicited suggestion here:  At the appearance judging have a separate area for the Sheeks designs or at least a separate row for all of them to be viewed together.  Although there were not a lot of entries last year, they were sort of lost in the mix.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline John Miller
« Reply #2 on: August 11, 2008, 01:45:26 PM »
Pete that's an excellent idea.
Offline Tom Niebuhr
« Reply #3 on: August 11, 2008, 02:44:33 PM »
Pete,
Thanks for excellent suggestion.
AMA 7544
  • High Desert Flier
« Reply #4 on: August 11, 2008, 10:20:51 PM »
Your welcome Tom and John. I'm looking forward to seeing your Sea Vixen Tom and hopefully Tony Naccarato's Stuka.  I hope to have a Ryan SC complete but had better get busy cuttin' parts!  y1
Pete Cunha
Sacramento CA.
AMA 57499
Offline Tom Niebuhr
« Reply #5 on: August 12, 2008, 01:21:40 AM »
Pete,
I talked to Bob Hunt today. He said that He and Rickii Pyatt will help to place the Sheeks airplanes together, since this will help when they are taking pictures.
I was hoping that someone would build the Ryan. It looks like it will fly well. We all have a lot of work ahead of us.
Here is my "Sea Vixen" as of today. I am working on many nit picking items, but hope to have it in primer very soon.
« Last Edit: August 12, 2008, 03:02:21 PM by Tom Niebuhr »
AMA 7544
« Reply #6 on: August 12, 2008, 08:31:45 AM »
If they had placed all the Sheek's planes together I would have gotten negative points for appearance.  Mike Haverly's plane was one gorgeous piece of modeling.  DOC Holliday
Offline Tom Niebuhr
« Reply #7 on: August 12, 2008, 03:08:07 PM »
Ty,
 The blue is "SuperFil" by Poly Fiber that I use for fillets. With all the contours, the "Sea Vixen" is like a flying fillet! I just hope none of them pop.
I have been sanding a few days now preparing for the primer.
I use 0000 steel wool over the open bays. This helps to avoid sanding through I-beam ribs. This is a trick that I learned from Bill Werwage, when I built my "Argus". I didn't go through any ribs on that project. I pray that I can be as successful on the Vixen.
AMA 7544
