  • July 29, 2025, 01:08:12 AM
Author Topic: Engine for Thunderbird II?  (Read 8660 times)
Offline Tony Eyers
« on: April 14, 2025, 12:23:01 AM »
I've just gotten a Thunderbird II kit. All the wood appears to be in good order, I'm looking forward to the build. I generally go for minimal finishes on my models, UltraCote on the wings, clear on the fuselage, with blue tissue trim. So it shouldn't be too heavy. I'm guessing it was originally designed for Fox 35? What would be a suitable engine these days? Would a 46 LA add too much weight up the front?
Offline Steve Berry
Re: Engine for Thunderbird II?
« Reply #1 on: April 14, 2025, 11:09:58 AM »
I believe the original was designed for a Veco .35, not a Fox .35.
A suitable modern replacement could the .46LA, although it's a little heavier and more powerful than the original. Balance could be an issue.
Another could be an OS .35-S. They are good stunt engines, more power than a Fox, and less fiddly (no burp).
Another choice would be simply convert to electric. A BadAss 2820-910 on a 4-cell battery would be a pretty good combo.
Sent from my SM-N986U using Tapatalk
« Last Edit: April 14, 2025, 05:25:11 PM by Steve Berry »
« Reply #2 on: April 14, 2025, 05:04:23 PM »
Another choice would be simply convert to electric. A BadAss 2810-910 on a 4-cell battery would be a pretty good combo.
I think the 2820-810 on a 5s would be more like a OS35s. You might get away with a 4s.
Offline Steve Berry
« Reply #3 on: April 14, 2025, 05:25:01 PM »
Yeah, I fat-fingered it. It's supposed to be the 2820-910.
Offline C.T. Schaefer
« Reply #4 on: April 15, 2025, 05:44:57 AM »
Just for reference I have been flying a Brodak T-Bird. Weighs about 50 oz. Power old school ST .46. Master 12x6. Good combo. I you keep weight under 45 the B-40 would be a good choice. Or the LA 40/46.  TS
Offline Tony Eyers
« Reply #5 on: April 15, 2025, 07:06:34 AM »
Thanks for this. I have a Brodak 40, an LA 40 and an LA 46. Spoiled for choice.
Offline George Waters
« Reply #6 on: April 16, 2025, 05:08:38 PM »
I have a rojett 40 bsre in my tbird and i used an fp 40 in the old one. mine weighs 49.5 oz.  George
« Reply #7 on: April 18, 2025, 12:53:31 PM »
  George mentioned  RO Jett .40.   A super choice since it's in a .25 size case.   Pretty pricey if you don't have one.   I have pulled up to 64 ounce airplanes with it though.   My next choice would likely be the OS .35S- again weight and 'classic' type power.   Of what you mention you have I'd probably do the Brodak .40.   Never had one but I know they are light and I've seen them run well.   The other engines you mention can work but will be heavier, especially with a muffler.    Since these like to run mostly two stroking the muffler is almost a requirement.   The older engines breaking in and out seem far less annoying -to me anyways.   An old Merco .35 or Blackstreak .40 would also be a good choice.    I have an old Thunderbird kit here that might get the Merco Blackstreak in it .  It sounds like you understand these old Classic airplanes were designed around 6-7 ounce,  non-muffled engines and that's what you'll need to get the best performance from them.
Offline Ty Marcucci
« Reply #8 on: April 18, 2025, 02:38:32 PM »
The other thing to remember is in the classic era, we did one lap between maneuvers.. Now with two, that is at least 15 extra laps, so tank accordingly.. I didn't, ran under , missed the over head and 4 leaf.. ARRRGGHH. LL~
Ty Marcucci
« Reply #9 on: April 19, 2025, 03:48:46 PM »
I don't know exactly when the two lap rules started.   They had to be before 1965 because that's when I started flying stunt airplanes and it has always been two laps since I started.   I know it was one lap during most the early 50's,  hence the super short-nosed airplanes you can't get a large enough tank in now.   That was cruel and unusual punishment on judges.   Sometimes it's hard enough to get accomplished with two laps.
Offline Ty Marcucci
« Reply #10 on: April 19, 2025, 05:30:26 PM »
On a few of my classics I had to extend the nose 1 to 1/2 inches to accomodate the tank..Then about 1973 they added mufflers.. Balance became a trick. I know it was one lap in 64 when I started stunt. Did mostly combat and some carrier, got serious about stunt in 69, did my first full pattern in April 69 and I thought it was still one lap then..  D>K
Ty Marcucci
« Reply #11 on: April 19, 2025, 09:06:36 PM »
  I have some old rule books from back then, so I'll check the next time I'm in the basement. I was under the impression that the one lap between tricks ended with the OTS era because George's new pattern had more tricks to it???
« Reply #12 on: April 19, 2025, 10:12:36 PM »
Now you got the memory cells tickled and I have to know!  I flew the Nats in 65 and I don't remember doing two laps.  What I do remember was my first contest after coming home from the "war to end all wars trust in our government" I was cautioned that I needed to be flying two laps.  That was around 1976.
« Reply #13 on: April 20, 2025, 12:09:51 PM »
Ty it wouldn't surprise me if this was one of those things that evolved in the beginning depending on where the contest was and how the CD played it sort of like the BOM rules today.   It would be interesting if rule change dates were recorded at AMA someplace.   I'm sure it could be researched if you went back through old rule books in the library at the museum.  Maybe I'll make a reminder to myself and do that during the Nats this year when it rains or blows.
« Reply #14 on: April 20, 2025, 12:20:33 PM »
I wonder why they are not digitized and on their Web Site now.
« Reply #15 on: April 20, 2025, 01:12:34 PM »
Likely the costs involved and maybe nobody pushed it.   The amount of stuff in the library is really pretty amazing.
Offline Ty Marcucci
« Reply #16 on: April 20, 2025, 01:13:09 PM »
All it takes is money, time and one volunteer. H^^
Ty Marcucci
« Reply #17 on: April 20, 2025, 08:04:16 PM »
Actually the time required can be a lot.   I scanned and loaded the old issues of Stunt News for the PAMPA website.   That took almost a month of evenings and weekends.  Then we found it increased the website costs annually for the storage space from the web.   AMA would probably have to hire an outside company to do the work if they were to digitize the whole library and the cost might be more than they consider worthwhile.
« Reply #18 on: April 20, 2025, 11:39:26 PM »
   Some of the old rule books I have were actually in the original version of Model Aviation that they put out back then, prior to putting AMA news in American Modeler in about `1966 or '67. If the Museum has Model Aviation back that far digitized you should find them by looking under the magazine. I've never checked the website. I'll dig hose out tomorrow.
« Reply #19 on: April 21, 2025, 11:30:59 PM »
  I have rule books for 1959/60, 1962, 1964 and 1965, and all of them mention one lap between maneuvers. Interesting to look at because the size of the rule book in pages and each section really increased from 1959 to 1965!!
« Reply #20 on: April 23, 2025, 07:38:22 PM »
I'm curious Dan,  in the last couple , say '64-'65 what is the wording.   Does it say 'shall be one lap'  or something like 'a minimum of one lap'?   I never actually flew in a contest from '65 on where we did only one lap.   I know for a fact we flew two laps at the '68 Nats.   I'm thinking there must have been some discretion in there and many/most were doing two laps if there was a choice.  BTW you did receive the tea bag paper?
