  • August 01, 2025, 07:38:52 PM
Author Topic: Conquistador before final assembly.  (Read 2163 times)
Offline Ty Marcucci
« on: November 19, 2007, 12:33:52 PM »
Covered in  silk and tail feathers in Japanese tissue, it is very light.
« Last Edit: February 05, 2017, 07:53:03 PM by Ty Marcucci »
Ty Marcucci
Re: Conquistador before final assembly.
« Reply #1 on: November 19, 2007, 02:34:33 PM »
Ty,
Looks very cool. Almost like it's cut out of foam board or something. Look forward to seeing it assembled.
Offline Tom Niebuhr
« Reply #2 on: November 20, 2007, 12:45:46 AM »
Ty,
Looks good.
I am glad to see someone building that airplane. It's a beautiful one.
AMA 7544
« Reply #3 on: November 20, 2007, 09:40:23 AM »
Just old fashioned balsa. The wing is very much like the typical Veco wings with the two 1/8 rear spars. The gray is automotive primer. Fills nicely and sands easily.  Now to fit the canopy. I even have a pilot set aside. He weighs about one gram.
Hi Ty,
The auto primer is great!  Just make sure that 99% of it is sanded off. ;D
Offline Steve Fitton
« Reply #4 on: November 20, 2007, 06:06:51 PM »
Hi Ty,
errrrr.  What happens if you don't sand 99% off?   n~
« Reply #5 on: November 21, 2007, 07:06:35 AM »
Hi Stevie Boy,
What Ty said and more...........
Offline gary tultz
« Reply #6 on: January 14, 2008, 08:30:17 AM »
The real key to Auto Primer is to make sure the can says LAQUER or laquer based  y1  H^^
Offline gary tultz
« Reply #7 on: January 14, 2008, 12:07:06 PM »
TY, Don't think I'd want to do Pactra nowadays. I've heard it's some kind of weird Acrylic Lacquer. I did have some curdling problems because I shot the first coat of Sig dope too heavily. I stopped when I saw the curdles, Let it dry 24 hrs,sanded them smooth then sprayed two or three mist coats then next day, two normal coats. Came out fine. I always seem to do the first coat too heavily.  n~  n~ My Biggest mistake was using Enamel primer. b1  Boy does that curdle when hit with dope.
