  • August 02, 2025, 08:58:39 AM
Author Topic: Sheeks Knight and the Tucker 4 in clear  (Read 1851 times)
Offline Ty Marcucci
« on: October 20, 2008, 03:04:12 PM »
Well I have them this far. Nothing fancy, just mostly clear over colored silk and some trim. I am trying to get the feel of the planes they are based on using photos or the Profiles books.
Ty Marcucci
Re: Sheeks Knight and the Tucker 4 in clear
« Reply #1 on: October 20, 2008, 09:32:34 PM »
Ty,
Love those transparent finishes. I especially like the Tucker. That looks slick.
Offline Bootlegger
« Reply #2 on: October 30, 2008, 07:16:20 PM »
 #^  Ty That looks really nice on the Tucker, but both of them look good. Keep us up to date on the "doping" secret.
  "Inquiring minds want to know."   H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #3 on: November 02, 2008, 09:10:18 AM »
Two tricks that works well on silk is to a) use a sponge (it has to be a real sponge, 'cause synthetic sponges are generally disolved by clear dope) to wipe the fairly thin and well retarded dope on,  and b) put the dope on the bottom of the surface, i.e., get the model up above you and put it on from below. Gravity makes the dope stay on the surface, instead of form droplets inside the wing.
If you have a hole here and a hole there, I'd consider putting a dab of fairly thick clear (and a bunch of retarder?) on the hole and immediately covering the area with a piece of plastic kitchen wrap. Capilary action should keep the dope on the surface, but again, gravity can also help, so let it dry with that downward.
If Ty has a scheme that involves water, I'm perplexed....  y1 Steve
« Reply #4 on: January 29, 2009, 10:15:51 AM »
...and THAT is the best angle to view the Tucker!
« Reply #5 on: January 29, 2009, 11:38:52 AM »
Ty,
Love the Tucker, great side profile shot,,
Like the other bird as well, but that view of the tucker, just rocks!
