CLICK HERE--><--CLICK HERE
Brodak Accentor
Started by Harry Rountree, September 03, 2025, 11:48:13 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Harry Rountree
Is the Brodak Accentor a good plane for stunt? not like I'm a competitor I just like the looks... HR
  It's about as good as any for a sport flying model, I guess. I thinks it's a sorta modern copy of the Veco Powwow, I think. You like the look because it is a nice looking design!! Just build it straight, keep the finish simple and use your most favorite and familiar power plant, then enjoy! You asked this question in the Classic section, which is for models in what is called the "Classic Era" for competition, which has a cut off date of December 31, 1969, and the Powow was from that era, but this has been changed enough that I don't think it qualifies, but still a very worthy airplane for your purposes.
Motorman
I have the profile version Tanager and it is an excellent stunt plane with a great wing. Also, a good windy day flier. The Accentor is the same except the fuselage is made from wooden blocks so, get ready for lots of carving to keep the weight down.
I would use a carbon fiber push rod, 4" bellcrank, adjustable lead outs, tip weight box and stiffen the stab/elev with some fiberglass cloth. I power mine with an LA46 and 4.5oz tank, 63' radius .015" lines.
Basically if you build it like a modern stunt ship with a good control system and stiff flippers it will perform as such. If you use the crappy control system stuff and flimsy tail and flaps in the kit it will be mediocre. You'll get out what you put into it.
MM :)
