  • August 01, 2025, 07:23:03 PM
Author Topic: Repairing the Cobra  (Read 12244 times)
Re: Repairing the Cobra
« Reply #50 on: October 28, 2007, 09:59:14 AM »
But I liked the green Randy,it was so ,, so,, you LL~ LL~ oh I mean different
« Reply #51 on: October 28, 2007, 09:28:13 PM »
Ok, here it is so far. Man. sanding filler is a pain.
« Reply #52 on: October 29, 2007, 12:19:23 AM »
Randy, man, if my 109 only comes up to half of what you turn out quality wise, I think I will be thrilled. Looks good, now go put some liniment on the elbow, lotion the fingertips, and get some rest, for tomorrow more sanding follows.
first half of the wing for the 109 is in the jig, ribs set, spars in.LE and TE on. I want to stay up all night and work on it, but the boss may have a problem with me beign all bleary eyed tomorrow at work if I do that.
« Reply #53 on: October 29, 2007, 08:57:46 AM »
Mark,
Yea, my arm is a bit tired. You can see the primer spots on the fuse. I think next time I will wet the silkspan and just dope the edges and let it dry before hitting the main area with dope. Or possibly just go with Polyspan.
I can say one thing, I will never use other than SGM again. Absolutely no problems with sanding through on the ribs. Because this is a refinish and the framework wasn't as smooth and prepped as I normally do, I shot quite a lot of primer on this to insure that I got all the low spots with enough primer to fill them. But it makes sanding a real chore. I've been initially sanding it with 220 open coat aluminum oxide paper, then going to 320 of the same kind, then a trick 600 I picked up at the auto body shop. It's a zinc sterate paper that really takes out the scratches.
Should be ready for color in the next few days.
Don't stay up all night working on a plane. Leave off. It will be there when you come back and you'll be happier the next afternoon. Trust me.
« Reply #54 on: October 29, 2007, 12:54:47 PM »
We tried Polyspan on a fuselage, Randy, and will never try it again.  For everything except the nose,  I use OO or Jap Tissue.
I was going to ask you if you did the fuselage carving on that one with a machete............ **) **) **)
« Reply #55 on: October 29, 2007, 02:26:46 PM »
Bill,
No, I had hoped to get it done before my friend leaves for Tucson, but that isn't happening. I put the silkspan on the fuse wet and then doped right over it. Should have tacked the edges down and waited for it to dry or hit it with a heat gun or something. When you do that (dope right over wet silkspan), you float some of the silkspan and it give a slightly uneven surface when it dries. I probably should have put a couple of extra coats of dope on the fuse to fill the low spots. Those low spots aren't much, but enough to leave quite a lot of filler. Granted, it probably doesn't amount to much more than a gram or two, but it's just irritating as heck. What I get for trying to get it done by a certain date. Especially when I've now found another ride for the plane that isn't leaving until February. Sigh...
Not a big deal, I suppose. I weighed the whole thing before and after the primer was shot. I'll check it again after I get done sanding. I don't expect to pick up even a 1/2 ounce in primer when it's all said and done. If I do, it will be back to sanding.
Offline Shultzie
« Reply #56 on: October 30, 2007, 12:10:37 PM »
Bill,
I'm still debating on color. I had a scheme planned but it was going to be all dark colors and I decided that the Tucson sun wouldn't be kind to it. So now I'm considering using an off white as a base color and some interesting trim colors I have with basically the same scheme I used before. The sort of classic Bill Werwage Juno scheme. We'll see. Maybe I'll get a wild hair and do something else. I've got about 3 and a half wing sides of sanding to decide.
Not only for Tucson..but choice of paint color so much depends on keeping the model a color that WON'T BLEND WITH THE BACKGROUND  behind your flight window.
Dark Greens, and especially Dark Reds and maroons are really cameeeeeekkkkk0oh-SH-T!!! ~^color choices as you know can really trick de-ol' eyeballs...when that model is in motion and flying those fast 3-5 speed laps...n'allthatjizzjazz. H^^ LL~
Don Shultz
« Reply #57 on: October 30, 2007, 03:42:26 PM »
Don,
Yea, that was the one drawback to the Novi I built last year. I'm telling you, light pearl green is not the color to have around here with all the "treed" backgrounds. Poof!, it's gone!
Recently, I took all the cans of custom mixed paints I have (about 40 pint cans and 5 or 6 quarts) and moved the paint over to canning jars. Besides now not having to worry about the darned cans rusting (don't you just love living in a high humidity environment?), I can see the color through the side. An upside to this is being able to put jars side by side to see how the colors will look together. Makes picking out trim colors a lot easier.
So I now have my paint scheme AND colors picked out.
Main color will be Alabaster Pearl White, trim will be Ford Redfire Pearl, A custom mix Orangy-Yellow pearl, GMC French Blue Pearlcoat(as sort of Burple color), BMW Custom Bronze Pearlcoat and a bit of Black Pearl. Should be interesting anyway. Certainly the jars standing next to each other look very good. Oh, and Hawai'ian shirt LOUD!
« Reply #58 on: October 30, 2007, 04:35:56 PM »
Now your talking Randy, we like loud,, That will help Leo keep from walking on it too,,,  LL~
sounds like it is going to be an interesting color combination for sure. So get it painted already. Dont be worrying about the clear , just bring it over we can clear it in the shop,, you konw the big booth! No temp issues there. lol
Offline Shultzie
« Reply #59 on: October 30, 2007, 06:14:05 PM »
WOW! RANDY AND MARK!
I still have an old can of  Clear Coat Imeronie'  :X and harder sitting out in the garage.....
If you are brave or foolish enough to spray it? LL~ :X :X :X :X
Don Shultz
« Reply #60 on: October 30, 2007, 08:34:02 PM »
hey Shultzie, you can keep your Imronie That stuff is to brittle for me, I will take my Urethane super PPG 2021 thanks,, its the GOOD stuff, ,then an hour at 140 in the booth and its ready to take home!
« Reply #61 on: October 31, 2007, 12:22:45 PM »
First plane I ever painted with car paints had an Imron topcoat. The stuff almost put me in the hospital. Nasty stuff. Now I use a much better mask, long sleeves, a hat and goggles and shoot it outside, but not Imron. The stuff is way too heavy. I think I added something like 5oz in clear coat with one coat of Imron. I use some 2 to 1 catalyzed polyurethane now and it works well.
Interestingly, that plane had a base color of medium charcoal metallic (first plane painted with metallics) and 6 trim colors; mostly reds and oranges with a really cool Camero dark blue metallic. That was a pretty plane. Shame it weighed a ton.
« Reply #62 on: November 01, 2007, 10:16:59 AM »
Heck,
My color schemes are not hard to pick at all!  All my planes are red w/yellow and white trim, outlined in black! LOL!!
Of course I do paint a LOT of my Classic planes in their original paint scheme.
« Reply #63 on: November 02, 2007, 10:42:40 AM »
Bill,
Well, I often try to keep the spirit of the original paint scheme. That's what I did with the Green Weenie. But sometimes you just have to do something different.
Still fighting with fillets. What a pita. I hope to be able to paint the base color this weekend.
Offline Shultzie
« Reply #64 on: November 02, 2007, 06:45:13 PM »
 LL~ LL~ Good point.......plus not worth the risk.....besides some of those beautiful Pylon RC racers had some noticable lifting & delamination especially in the high flex-stress areas etc.... but perhaps that might have been not allowing enough for the undersurfaces to "gas off!" BOTTOM LINE! NOTHING IS WORTH THE RISK TO YOUR HEALTH!
Thinking back........most of those advocates that were screaming the loudest that "they knew how to take precautions" were sooner or later having health issues that screamed to me....they weren't as careful as they THOUGHT THEY WERE...n'allthatjazz. :X :X
Don Shultz
« Reply #65 on: November 04, 2007, 10:21:02 PM »
Well, the filler is all sanded. I would have shot some heavily thinned clear on it today, but the compressor seems to have gone tits up. I'll have to take it apart tomorrow to see what's up. It's leaking. Not a good thing. And I had a problem with one of my spray guns. Man, when it rains ...
Oh well, I'll get it sorted out.
« Reply #66 on: November 21, 2007, 08:54:11 PM »
Ok, I'm back in business again. All new from compressor to spary gun. Shot the clear on the primer tonight. Man, it's nice to use good equipment. I love trouble free.
