  • July 31, 2025, 06:50:20 AM
Author Topic: Ares 59  (Read 16528 times)
Offline David Ruff
Ares 59
« on: April 29, 2015, 03:09:24 AM »
Looking at engines for an Ares 59.
The original ran the Fox .35 I think.
Considering an Enya 30SS.  It weighs about one oz more than the Fox and produces .75 HP compared to the Fox at .35.
Thoughts on this engine for the Ares?
I understand the lighter the better.
« Last Edit: May 01, 2015, 04:59:37 AM by David Ruff »
Retired Army
Offline Steve Thomas
Re: Ares 59
« Reply #1 on: April 29, 2015, 06:42:30 AM »
I wouldn't hesitate to use it, it's a great engine.  It's not really going to be ideal if you want the full classic 4/2 experience, but run in a wet 2 with something like a 10.5x4.5, it's excellent.
Offline David Ruff
Re: Ares 59
« Reply #2 on: April 29, 2015, 11:11:19 AM »
Well I do have several Fox .35 Stunt engines.  Was just looking for something else for this.
Retired Army
Re: Ares 59
« Reply #3 on: April 29, 2015, 01:50:46 PM »
Fine an OS 35S. That would be the ticket.
Re: Ares 59
« Reply #4 on: April 29, 2015, 04:28:43 PM »
Keep the Ares under 40 oz.  The Enya should be fine running in a wet 2.  For a real nostalgic experience put in a good running Fox .35.  But using more power never hurts!  My son had a lot of success running a well worn OS .32F, and later the compact Magnum .36XLS.  I will probably use the Aero Tiger .36 in my next Ares.
BIG Bear
RNMM/AMM
Offline David Ruff
Re: Ares 59
« Reply #5 on: May 01, 2015, 05:02:41 AM »
Actually this is an Enya SS.30 BB engine.
So my choices are that Enya SS.30 BB, an OS .40 Stunt, Enya SS.40 S or the Enya SS.40 BB S or new J&B .40.
I an told to keep it light.  All the Enya engines range from about 8 to 10 ounces without mufflers.  The Fox .35 is about 7 oz.
So any of the engines should be light enough.
51 inch wing and about 550 squares.
Which engine do you all recommend out of my choices above?
All the engines except the K&B need prop extensions to fit properly on the Ares.
Actually I just laid the K&B .40 up against the plans and it fits perfectly without an extension.  That sort of fixes my problem?
« Last Edit: May 01, 2015, 07:00:55 AM by David Ruff »
Retired Army
Re: Ares 59
« Reply #6 on: May 01, 2015, 10:10:35 AM »
those are really heavy engines for an ARES, use the FOX  35 over the 10 ounce motors, also  check is your 30BB  really a 35?  I have not seen a 30 that was ball bearing
Offline David Ruff
Re: Ares 59
« Reply #7 on: May 01, 2015, 04:34:32 PM »
Based on Randy Smith and Chuck Holtzapple advice, I will go with a Fox .35 60th Anniversary engine.
If it was good enough for Mr. Werwage.....
May need some Randy tweaks, tho.
Retired Army
Re: Ares 59
« Reply #8 on: May 02, 2015, 08:39:43 AM »
Hi David,
Somethings I have learned about Ares over the years (built my first one in 1964) is that they have to be built light (39oz. oe less) to fly best and they need to fly at about 5.1 laps on 60' eye to eye .015 unless you have a real abundance of power.  I spent a lot of time talking to Mr. Werwage about the different Classic models of his.  Not everyone knows that Billy did a lot of work on the Fox .35 and also tipped the nitro jug very generously.
Your 60th Anniv. Fox .35 will fly yours well and you will really enjoy it as long as you don't let the weight climb.  A heavy Ares just doesn't fly like it should.
BIG Bear
RNMM/AMM
P.S.  Letting Randy Smith B&B your Fox is a good idea.
Offline David Ruff
Re: Ares 59
« Reply #9 on: May 03, 2015, 02:42:47 AM »
Hi David,
BIG Bear
RNMM/AMM
Thanks for the info.  Chuck said Mr. Werwage went with 25% nitro with that Fox .35.  That can be done.  I will really work on hollowing out the balsa blocks that come in that kit to keep it light.  Going with silkspan on the wing and fuselage but keeping the finish coats to a minimum.
Sending to Randy for engine tweaks.  He ran out of stuffer plates but I found one here I will send with the engine.
Retired Army
Re: Ares 59
« Reply #10 on: May 03, 2015, 01:21:43 PM »
Here you go, Randy.  Enya SS.30 BB weighs 8 ounces.
Has much more power than the Fox .35 Stunt
Still need prop extension, tho
Hi David
Thanks for the photo, looks like they used a 25BB frontend, I had many 30s and 35 in my shop, that is the first one (30) I had seen, although I did have the 25BBs in stock, Those had the aluminum piston also, does your 30 have a steel or aluminum piston? can you tell
Offline David Ruff
Re: Ares 59
« Reply #11 on: May 03, 2015, 04:53:45 PM »
Hi David
It appears from this literature that it is a cast iron cylinder.  The Enya guys always talk about long break in procedures and very long engine life if the break in is properly executed.  Usually an hour of break in time.  See link...
http://s429905827.online.de/Manual/Instruction-manual-SS25-SS35_E.pdf
Also, I contacted Bob Brooks, the US Enya distributor and he verified that it is cast iron.
« Last Edit: May 04, 2015, 02:47:54 AM by David Ruff »
Retired Army
Offline Skip Chernoff
Re: Ares 59
« Reply #12 on: May 17, 2016, 03:57:44 PM »
I'm flying a 59 Ares at 48 oz with an La 40 ,63 ft lines, 10.5x4.5 prop and seems to be flying just fine.
Re: Ares 59
« Reply #13 on: May 19, 2016, 09:51:20 PM »
BINGO  !!!   Older  OS 35 S   is  a great choice
although a good FOX 35 or  Merco 35 will pull it very easy
Offline David Ruff
Re: Ares 59
« Reply #14 on: June 30, 2016, 05:15:43 PM »
been a while, but Randy built a Fox 35 for me.  I have the Brodak Ares 59 kit and the Fox will power it.
Building a profile Cardinal first to get my hand back into building.
Retired Army
