Cool! Can we make the red to match to match the Rustoleum Gloss Protective Enamel red? I'd be more than happy to send you a "test" piece.Thanks,Thanks,Thanks,...PhillySkip
Skip,
I stock one red, the best red.
Couple of ways to do this graphic. The black you see can be red. Or, the white you see can be red. Then the black can be black or some other color.
If you don't use a color for the white in the graphic, it will be whatever color you place the graphic on.
I suggest having a two color graphic, even if the background, or "fill" color is white.
Maximize the size, this will make cutting easier. I'm not sure all of it will cut? Sometimes adjustments have to be made. Especially when you draw the graphic from scratch.
CB
