  • March 28, 2024, 08:45:11 AM
Author Topic: Time To Finish The Spitfire  (Read 21050 times)
Offline kevin king
Re: Time To Finish The Spitfire
« Reply #50 on: September 02, 2018, 08:00:59 AM »
Matt, you're hilarious AND you're an encyclopedia of Spitfire knowledge.😁 "No ruler or tape measure" 😆. I Enjoy reading your posts.
« Last Edit: November 11, 2020, 02:48:22 PM by kevin king »
Offline kevin king
« Reply #51 on: September 02, 2018, 09:41:12 AM »
Working on the roundels this weekend. I've never taken so many measurements in my life.  Millimeters matter🧐. I marked off the centers of the wing's top and bottom roundels. Starting on the bottom I layed the mask and stuck a piece of scrap paper under the edge to help remove it later.
Offline kevin king
« Reply #52 on: September 02, 2018, 09:48:54 AM »
Sprayed one light coat of Sig White dope thinned 65 % with lacquer thinner. The bottom roundels will only have one thin narrow white band.
« Last Edit: September 02, 2018, 11:12:14 AM by kevin king »
Offline kevin king
« Reply #53 on: September 02, 2018, 11:15:38 AM »
Top roundel. Huge!
Offline kevin king
« Reply #54 on: September 02, 2018, 11:20:34 AM »
Sprayed on 3 coats of white dope...This was a mistake...tell you why in a minute.
« Last Edit: September 03, 2018, 12:06:36 PM by kevin king »
Offline kevin king
« Reply #55 on: September 02, 2018, 11:25:30 AM »
...then after the white dried, I sprayed on 3 coats of Brodak Insignia Blue.  That was fine, but I didn't feather it in toward the center, and this was to cause problems as you will soon see.
« Last Edit: September 03, 2018, 09:22:25 AM by kevin king »
Offline kevin king
« Reply #56 on: September 02, 2018, 11:31:21 AM »
Bottom roundels, 3 coats of Insignia blue.
« Last Edit: September 03, 2018, 09:06:33 AM by kevin king »
Offline kevin king
« Reply #57 on: September 03, 2018, 07:00:15 AM »
Problem # 1. After  removing the center
Mask of the top roundels , I had a ridge of paint build up which I had to sand and blend in. Of course it's on the top of the wing, on an open bay, and right on top of a rib. And that's medium silkspan I used for covering to😫. So I had to sand the ridge off. That was fun. I got it as smooth as possible without cutting into the silkspan, then built up the area with silver, sanded it smooth again, and repeated that... like 3 times. That really sucked. My mistake was forgetting to fade the paint as I came to the center. 😫🤬🤭
« Last Edit: September 03, 2018, 09:10:20 AM by kevin king »
Offline kevin king
« Reply #58 on: September 03, 2018, 07:55:36 AM »
You can still see the halo effect after the red was sprayed. It looked a bit better after it dried though.
Offline kevin king
« Reply #59 on: September 03, 2018, 08:10:52 AM »
Mistake #2. Too much paint build up. I should not have put THREE coats of white underneath the blue. One coat would have been good. Once the paint film is too thick,  it will separate from the mask leaving those ratty edges instead of coming off cleanly like a thinner film of paint would do. Shame on me.😞 Even that I know better but I still did it.🤯 I will post my mistakes to help others. Time to dig out the airbrush and do some touch ups. Yup. Control line stunt...10 % fun and 90 % something else.
« Last Edit: September 03, 2018, 03:49:50 PM by kevin king »
Offline kevin king
« Reply #60 on: September 03, 2018, 08:22:27 AM »
Thankfully both the bottoms turned out nice. Go figure 🤨.
Offline kevin king
« Reply #61 on: September 03, 2018, 02:10:47 PM »
How can you fight in the air, defend our Island, whatever the cost may be if you're roundels don't have perfect edges?? That's crazy! Good thing I scored this mint condition airbrush on Kijiji for 50 bucks.😁
« Last Edit: September 05, 2018, 11:00:26 AM by kevin king »
Offline kevin king
« Reply #62 on: September 03, 2018, 02:11:36 PM »
   S?P
Offline kevin king
« Reply #63 on: September 03, 2018, 02:12:44 PM »
Offline kevin king
« Reply #64 on: September 05, 2018, 09:06:50 AM »
I found a video of my wing on you tube. I forgot I uploaded it. 😁
« Last Edit: April 25, 2020, 07:55:05 AM by kevin king »
Offline kevin king
« Reply #65 on: September 05, 2018, 07:16:05 PM »
Offline kevin king
« Reply #66 on: September 07, 2018, 05:55:26 AM »
After seeing Keith's shark mouth post I decided to throw my hat in the ring. This will be my first time spraying one and I didn't want the typical P40 mouth. There is the Grey Nurse one which is nice but I wanted something different.
« Last Edit: September 29, 2018, 07:34:43 AM by kevin king »
Offline kevin king
« Reply #67 on: September 07, 2018, 05:58:35 AM »
It's ok dude, I got this!! - Is my board ok? -Optimist.
« Last Edit: October 13, 2018, 02:58:28 PM by kevin king »
Offline kevin king
« Reply #68 on: September 07, 2018, 06:45:44 AM »
Something like this. The raised upper lip gives it a snarl look😁
Offline kevin king
« Reply #69 on: September 07, 2018, 09:01:59 AM »
Similar to this one. Almost impossible to copy it  because of the camera angle. I have only found 1 photo of it. Truly this is the meanest looking shark mouth I've ever seen.
« Last Edit: October 18, 2020, 03:31:08 AM by kevin king »
« Reply #70 on: September 07, 2018, 09:35:07 AM »
Kevin,
You're correct. Camera angles create a thing called "foreshortening."
Has to do with perspective and the angle of vision.
There was, years ago, a whole article about tracing the fuselage side of an aircraft and how to deal with this.
Obviously if a 3-view wasn't available or plans.
With CAD programs like mine, I could do a draw then actually grab the end of the graphic and "pull" or stretch it until it looks correct or just better.
No matter what mouth you draw, you will still need a mask for each color or, a simple way, would be to use brushes and paint the thing on white vinyl, then apply the vinyl.
Hand painting the thing on the model could be cumbersome whereas the vinyl would be flat and easer to rotate if necessary.
Easiest way is to make the thing using colored vinyl.
You have a really nice model happening. Kudos!
Charles
Offline kevin king
« Reply #71 on: September 07, 2018, 07:27:01 PM »
Thanks for the tips Charles. 👍
Offline kevin king
« Reply #72 on: September 08, 2018, 12:57:16 PM »
I got the two yellow stripes on the leading edge. Always put white under yellow!! Ask me how I know.😁 Nice and bright...if there centered properly  I will be happy.
Offline kevin king
« Reply #73 on: September 08, 2018, 01:03:09 PM »
 Control line tip of the week: ALWAYS fly near power lines. The closer the better. 💪
« Last Edit: September 08, 2018, 01:39:51 PM by kevin king »
Offline kevin king
« Reply #74 on: September 08, 2018, 01:48:49 PM »
Heartbreaking Spitfire crash . Yikes.🤪
Offline kevin king
« Reply #75 on: September 08, 2018, 03:50:17 PM »
Woohoo! Yellow leading edges perfecto!
Offline kevin king
« Reply #76 on: September 08, 2018, 03:52:40 PM »
Offline kevin king
« Reply #77 on: September 29, 2018, 05:27:19 AM »
Ok, back to the painting of a shark mouth. After I got the look I was after on paper, I adjusted the size using my printer and printed off 3 copies. One for each color. I then reversed the image on Windows Paint and printed off 3 copies for the other side. I then used those templates to mask the shape of the mouth with tape.
« Last Edit: October 09, 2018, 08:54:46 PM by kevin king »
Offline kevin king
« Reply #78 on: September 29, 2018, 05:42:56 AM »
Ready for white.
Offline kevin king
« Reply #79 on: September 29, 2018, 05:49:28 AM »
Sprayed the white and left all the masking in place.
Offline kevin king
« Reply #80 on: September 29, 2018, 06:04:31 AM »
I then cut out the black area of the mouth on my paper template. Then brushed rubber cement on the white painted area of the mouth on the plane, then placed the teeth part of the mask on and rubbed off the rubber cement in the area to be sprayed black.
« Last Edit: October 01, 2020, 11:02:20 AM by kevin king »
Offline kevin king
« Reply #81 on: September 29, 2018, 06:14:06 AM »
Spraying the black center area of the mouth using an airbrush.
Offline kevin king
« Reply #82 on: September 29, 2018, 06:22:06 AM »
Wife airbrushing shark mouth. 😁
« Last Edit: December 22, 2018, 07:10:02 AM by kevin king »
Offline kevin king
« Reply #83 on: September 29, 2018, 06:29:40 AM »
Masking removed. Now I have to give him eyes. Good lord what have I created, an abomination?
« Last Edit: October 18, 2018, 05:16:50 AM by kevin king »
Offline kevin king
« Reply #84 on: September 29, 2018, 06:33:58 AM »
Gone but not forgotten
« Last Edit: November 11, 2020, 02:50:14 PM by kevin king »
Offline kevin king
« Reply #85 on: September 29, 2018, 06:37:26 AM »
Masked off the eye and sprayed it white.
Offline kevin king
« Reply #86 on: September 29, 2018, 06:41:56 AM »
Masked off the white eye and sprayed the red.
Offline kevin king
« Reply #87 on: September 29, 2018, 06:46:32 AM »
I then a used a drafting pen to draw the black pupil... It's alive!
« Last Edit: October 18, 2018, 05:19:10 AM by kevin king »
Offline kevin king
« Reply #88 on: September 29, 2018, 06:50:25 AM »
 Outlined the red part of eye with black ink.
« Last Edit: October 22, 2018, 10:56:59 AM by kevin king »
Offline kevin king
« Reply #89 on: September 29, 2018, 07:02:50 AM »
To get the red part of the mouth on the plane, I taped a piece of frisket film on to a cutting mat. Then taped my shark mouth template on top of the frisket. Then, using a #11 blade I cut out the red part of the mouth. I then placed the mask on the  mouth on the plane, and spray the red.
« Last Edit: October 01, 2020, 11:09:53 AM by kevin king »
Offline kevin king
« Reply #90 on: September 29, 2018, 07:25:42 AM »
What a mess. Just finished masking and spraying the black outline.
« Last Edit: September 29, 2018, 04:08:37 PM by kevin king »
Offline kevin king
« Reply #91 on: September 29, 2018, 08:02:11 AM »
Guess that's it for the mouth. I still have some touch ups to make on it. Over all I think it captures the look I was after. I felt like a Dentist touching up all those teeth.😛
« Last Edit: February 02, 2021, 10:51:56 AM by kevin king »
Offline MikeCoulombe
« Reply #92 on: September 29, 2018, 09:34:14 AM »
"WOW" Just awesome Buddy.
Hey Email me your address and I'll send you the Chipmunk.
We'll figure out the mustang later.
Keep up the good work Man.
Offline kevin king
« Reply #93 on: September 29, 2018, 03:53:27 PM »
➡️Email sent Mike.☑️
Offline kevin king
« Reply #94 on: September 29, 2018, 04:10:22 PM »
Last picture of the Shark mouth. As the Good Lord once said ' It is finished.'
Offline kevin king
« Reply #95 on: October 01, 2018, 05:56:36 PM »
Whats next? fuselage invasion stripes, roundel and squadron markings, or maybe a gold leaf tooth with a diamond in it? 🤔
« Last Edit: October 01, 2018, 07:39:26 PM by kevin king »
Offline kevin king
« Reply #96 on: October 01, 2018, 07:55:26 PM »
Thanks to ➡️motorman⬅️ my new Brian Eather 3 blade 12.5 x 5.25 carbon fibre Spitfire prop is balanced and pitched & to ➡️Walter Hicks⬅️ for suggesting this prop for the Spitfire's RO Jett 65 Re.
« Last Edit: October 11, 2018, 02:02:17 PM by kevin king »
Offline kevin king
« Reply #97 on: October 03, 2018, 07:57:46 PM »
Hard edge camo ❎
Soft edge camo ☑️ Actually with the amount of trim this paint job has there won't be much room left for camo on it anyways.  It's overkill already.
« Last Edit: October 04, 2018, 11:22:20 AM by kevin king »
Offline kevin king
« Reply #98 on: October 08, 2018, 08:48:08 PM »
Invasion stripes are not easy. Here I used one of those blue postal elastic bands to help mask a straight line over a coned shape surface. When it looked right, I layed out the green 3M vinyl masking tape. I then repeated the process for the front. I cut a strip of black construction paper to the width of the invasion stripe panel, then checked it for any inconsistencies.
Offline kevin king
« Reply #99 on: October 08, 2018, 08:51:47 PM »
Checking for equal distance all the way around.
