  • October 22, 2018, 09:26:30 AM
Author Topic: Pushy Galore, Semi-Scale Stunt Design Biplane. BUILD!  (Read 1598 times)
« on: August 22, 2017, 02:24:10 PM »
I'm rewriting my posts in this Thread so I don't have to start another.
I designed a biplane stunter around an EAA aircraft with the IC engine in the rear as the aircraft.
It is now Electric for a few reasons, the main reason being the spent fuel through the prop wash.
I'll be putting up construction photos with little explanation so if anyone has questions I'll be glad to answer them.
Has anyone built a model with the IC engine in the rear as a pusher?
Thanks in advance.
Charles
« Last Edit: September 05, 2018, 05:56:14 PM by Avaiojet »
Trump Derangement Syndrome. TDS
Avaiojet Derangement Syndrome. ADS
Please visit my updated Website! www.cfcgraphics.com
If you're Trolled, you know you're doing something right.
Alpha Mike Foxtrot.
Owner of CFC Graphics. "Model Airplane Graphics from a Model Airplane Builder."
"No one has ever made a difference by being like everyone else."
Marcus Cordeiro, The "Mark of Excellence," you will not be forgotten.
I look at the Forum as a place to contribute and make friends, some view it as a Realm where they could be King.
"Ya gotta love it when a plane comes together."
Proverb 11.9  "With his mouth the Godless destroys his neighbor..."
"Perhaps the greatest challenge in modeling is to build a competitive control line stunter that looks like a real airplane." David McCellan, 1980.
Online TDM
Re: Pushy Galore, Biplane Stund Design Issues.
« Reply #1 on: August 23, 2017, 06:06:06 AM »
I just realized something. That something is I have not asked the most important question. Any design must have a purpose so he it comes: what do you want the model to do in the first place? Stunt? Sport flying? just fool around? Experimental platform? What is your goal?
ENGINE TANK FOR STUNT
Engine on back and tank in front of it is counter productive setup in Stunt. The motor will surge when the model dives and will slow down during climb. You can get away a little with a RC type carburetor with motor setup like a RC and use throttle servo that gets impute from a Active CL timer.  But if you do this you might as well go electric at this point and call it a day.
About electric
There is a small learning curve but if you can add and multiply you can do it. Battery technology is going in one direction now and the power density s getting better all the time and soon they will surpass the IC very soon. Soon I believe all the RC flight will be electric in the near future. You might as well bite the bullet and learn about it if you are not familiar with it. Most questions are at your finger tips (use the search button) seek and you shall find ask and you shall receive someone wise said a long time ago.
« Reply #2 on: August 23, 2017, 06:08:17 PM »
Traian,
The model is EAA EXPERIMENTAL stunt.  LL~
I have the fuselage designed around an Irving 46, 1.2 HP. However, there's plenty of room for an "E" motor. I had, for a short time an "E" design that I converted to IC. It's called the ARGO.
I also wanted the model to do touch n goes, so the Irvine 46 has an R/C carb.
The tank issue is solved. Advice from a fellow modeler.
I just feel the spent fuel will be an issue being drawn into the prop, so, that's the reason I'm thinking "E".
Charles
Alpha Mike Foxtrot.
Re: Pushy Galore, Biplane Stunt Design Issues.
« Reply #3 on: August 26, 2017, 05:08:55 AM »
I'm finishing the ARGO 2.
Pushy Galore has an R/C type engine mount so converting to an electric motor shouldn't be an issue. Battery room or placement could be?
What I'll do is continue with the wings a bit so I can get a better idea as to the overall weight. They are foam and require sheeting and landing gear.
Getting these tasks done will help in deciding which motor would be suitable and having the weight will be more accurate.
I would like the model to be a bit overpowered.
CB
« Last Edit: September 05, 2018, 05:58:20 PM by Avaiojet »
Alpha Mike Foxtrot.
« Reply #4 on: August 28, 2017, 06:39:16 PM »
TY,
I actually gave that a bit of thought and haven't yet ruled it out.
It would just take away from the looks of the model.
Electric is becoming much more popular. I did get a small taste of the construction of installing the motor, so I'm considering "E" as I said.
Confidence level is still low with electrics, but I do have the Forum for advice and help.
It's a money thing also. I'll have to sell some stuff.
Thanks for the reply.
Charles
Alpha Mike Foxtrot.
Online TDM
« Reply #5 on: October 18, 2017, 10:13:03 AM »
Here is an idea. You could use a servo and a CL active timer to achieve the 4-2-4 with rear motor. You might even have a wider motor envelope than the normal non throttle carburetor CL is using.
« Reply #6 on: October 18, 2017, 10:43:50 AM »
Traian,
Yes, "E" would offer many benefits.
You and I can talk about options as I continue with the framing to determine overall weight.
I'll be getting more work completed with the foam wings shortly.
Then, I can weigh the unassembled parts to get an idea of what the overall weight will be.
Charles
Alpha Mike Foxtrot.
Offline peabody
« Reply #7 on: November 02, 2017, 05:55:23 AM »
Young Daniel built a bipe with a pusher...cleaning the prop will be the LEAST of your issues!
Have fun!
Get to work!
Come to the MCRC contest
Offline Skip Chernoff
« Reply #8 on: November 08, 2017, 03:42:58 AM »
Charles for this set up electric is really the way to go....IMHO. Also if you used an R/C car or boat 2.4 transmitter with  receiver and ESC you could control the throttle and do touch n goes or slow flight.
« Reply #9 on: November 08, 2017, 05:37:52 AM »
Skip,
I'm considering Electric. Thing is, Electric is heavier than IC and the power plant is in the rear.
There's more to know with Electric and I don't know it. Yet.  ;D
Hey Skip! You been off planet?
Charles
Alpha Mike Foxtrot.
Online TDM
« Reply #10 on: November 15, 2017, 01:45:31 PM »
If you build electric the opposite is the truth.
Once you decide to build electric you have to think electric. You don't need 1/16 doubles in the fuselage. 1/64 ply here and there will be enough. The motor is smoother and you get almost no vibration. Motors weigh in the 140-175g while batteries are heavier so electric with rear motor has better weight distribution than the IC.
« Reply #11 on: November 15, 2017, 06:55:17 PM »
Traian,
OK, duly noted.
I can change this to Electric with little difficulty.
Let me weigh these unassembled parts. See what you think.
Charles
Alpha Mike Foxtrot.
« Reply #12 on: December 31, 2017, 08:58:16 AM »
I did mention I would consider "Electric" for Pushy Galore. Looks like I'm now really considering this.
Because of the model's design configuration it currently looks like a considerable amount of weight will be needed in the nose for the model to balance on the CG. This weight could be the battery.
I'll try to do a bit of research over the Holiday.
Charles
Alpha Mike Foxtrot.
Offline Will Moore
« Reply #13 on: January 01, 2018, 01:09:48 PM »
Or, you could ask someone who knows a thing or two, to help you with an electric setup,  near where you live in Florida .  Hmm , know anyone there ?
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
AMA # 209
« Reply #14 on: January 01, 2018, 02:05:25 PM »
Will,
Gee. I believe there's this modeler who just about invented the use of electric in stunt. He's already put a 'bug' in my ear, hence the new Post. Just so happens he flies at my field.
His name is Will Moore. I don't think you know him?
CB
Alpha Mike Foxtrot.
Offline Will Moore
« Reply #15 on: January 01, 2018, 02:30:00 PM »
 y1.  I think I do.....did you buy that pusher prop ? S?P.
Just for the record, Mike Palko was the first to consider electric in competition, followed closely, though independently,  involving experimentation and development,  by this guy you mention, Will Moore, in New England, and almost at the same time, another independent experimenter, Walt Brunell.  Those were the three pioneers who started it all,  and everyone else came much later.  H^^
AMA # 209
  • Gravitywell
« Reply #16 on: January 01, 2018, 02:34:29 PM »
 LL~ H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #17 on: January 01, 2018, 02:58:47 PM »
Will,
I told you I knew this. I'm just looking forward to free stuff!!  LL~ LL~ LL~
Hey! Check your email.
Charles
Alpha Mike Foxtrot.
« Reply #18 on: January 01, 2018, 03:01:17 PM »
LL~ H^^
Glenn, Anti-Gravitywell,
WHAT HAVE YOU BEEN UP TO!!
Happy New Year,
Pushy Galore is started.   n~
Charles
« Last Edit: September 05, 2018, 12:27:25 PM by Avaiojet »
Alpha Mike Foxtrot.
« Reply #19 on: January 06, 2018, 08:48:35 AM »
I had to design a custom and unusual elevator control horn.
There are hardships in designing really different models. Rewards also.
CB
« Last Edit: September 05, 2018, 12:12:35 PM by Avaiojet »
Alpha Mike Foxtrot.
  • Gravitywell
« Reply #20 on: January 06, 2018, 02:32:54 PM »
Hi ya Charles and welcome to 2018!  I made it as well..... LL~  I have been hiding in my basement doing as little as possible.  Its been very cold up here for quite a while now, but it has slowly started to warm up so I am happy.  I'm very slowly working on a rubber power Spitfire and I do mean sloooooowly!
Still waiting patiently to see some pics of this new bird of yours.....sounds like a real neat deal.
Your frozen friend, Glenn H^^
Glenn Reach
Westlock, Alberta
« Reply #21 on: January 06, 2018, 03:05:44 PM »
Hey! Hey! Glenn.
Thanks for stopping in.
Post photos I used to do rubber band and tissue models.
Charles
Alpha Mike Foxtrot.
« Reply #22 on: April 21, 2018, 09:47:01 AM »
Nose gear wire.
I bent the first test wire using a clothes hanger, easy to bend.
Alpha Mike Foxtrot.
« Reply #23 on: April 21, 2018, 08:12:01 PM »
Nose gear wire and plywood mounting plate.
Alpha Mike Foxtrot.
« Reply #24 on: April 22, 2018, 07:02:33 AM »
Aluminum pieces used to mount the nose gear wire to plywood. Blind nuts.
Plywood will be Epoxied in place before final mounting of the nose gear wire.
Alpha Mike Foxtrot.
Re: Pushy Galore, Semi-Scale Stunt Design Biplane. BUILD!
« Reply #25 on: October 05, 2018, 08:35:43 AM »
Here's the wing gear wire.
Alpha Mike Foxtrot.
