Speed,Combat,Scale,Racing => Carrier => Topic started by: Thomas Wilk on February 18, 2011, 12:29:45 PM
here is proof that the Stinson L-5 Sentinel was used on US Aircraft Carriers
T.A. Wilk
Is there any information to suggest it made an arrested landing? A number of light planes have made flights from carrier decks and were able to land without arresting simply because of the slow landing speed inherent in their design. The Fieseler Storch has flown from carrier decks for tests, but, because if its extreme low speed flight characteristics, a hook was not really necessary and was, as far as I know, never fitted. So while these light planes did fly off of carriers, they never made arrested landings and are therefore not eligible for scale bonus points. Perhaps some of them did make arrested landings, but that may be challenging to document. It is probably easier for the very early airplanes, where they just tied grappling hooks to the landing gear.
Pete
Perhaps something like this??
(http://i275.photobucket.com/albums/jj307/afml_photos/DCTripWes097.jpg)
(http://i275.photobucket.com/albums/jj307/afml_photos/DCTripWes105-1.jpg)
(http://i275.photobucket.com/albums/jj307/afml_photos/DCTripWes405.jpg)
(http://i275.photobucket.com/albums/jj307/afml_photos/DCTripWes416.jpg)
"Tight Lines!" H^^
Wes
Hey Pete,
Some food for thought.
What does arrested mean. One meaning is simply to stop, which these planes could do. Why does it mean it had to have a hook? The Vought kingfisher which is legal was used on carriers at times, never had a hook though. I remember Perry saying the AE-1 Hospital version of the cub was legal. How about the OV-10, no hook but used a lot in Vietnam from carrier. Also Tom's picture show an LST launch. Some LST's did have Brodie gear to recover planes. They we too short for reliable landings with out hooks. The Brodie gear was a trapeze setup with the hook on top of the plane I think para B. covers these types, seems to me if the plane was assigned to carrier duty, by definition it is designated as a carrier type.
The problem is with the rules. Without a hook you can't snag a cable, right? So if you don't hook a cable you can't get landing points. So the MO-1's that have been so popular over the years have not had a hook like in pictures I have seen such as we use. How many of the planes that have competed have had the hook in the proper location as to the real planes. An idea for a proposal is maybe allowing planes that actually landed on the decks without hooks and can do it on model form be allowed? I have seen entries land on the deck and have add throttle to hook a cable. That just might put some fun back in carrier if a person could land on the deck and still keep the engine running(not motor) and on the deck. There are more planes out there that could do it. VD~ S?P H^^
Hi John,
There are a lot of meanings of the word "arrested" and one means simply to stop. Another is to have been stopped, and that is pretty clearly the meaning our rules are using. Our rules actually define "arrested landing" in sufficient detail that the idea of an arrested landing being one in which the aircraft is stopped by the arresting wires is quite clear. We might argue that arresting by standard arresting wires is not the only way that a prototype might be qualified, and that other mechanical devices on the carrier could be used. I'm just not familiar with alternate arresting systems, but there has probably been quite of variety of systems developed in the early days.
The fact that an aircraft was used on a carrier might not automatically make it a "carrier aircraft" within the meaning of part b. of the rule. (b. Aircraft is designated as a carrier aircraft by an acceptable source (in cases where actual carrier-type takeoff and arrested landing are not documented).) The famous C-130 flight did not make it a carrier aircraft. And the Doolittle raid did not qualify the B-25 as a carrier aircraft. My feeling is that part b. was put in to allow airplanes that were carrier aircraft in our usual understanding including the arrested landing but for which documentation is not readily available. If that is the case (and I am not absolutely sure it is) then some of the others, particularly the example of the OV-10 would not be qualified because it was not designed to and never did make an arrested landing. The imprecision of the rule meaning might be a tiny can of worms.
Doc, the MO-1 was pretty clearly a carrier aircraft. In addition, the old documents that I remember said that the arresting was by grappling hooks attached to the landing gear. Apparently that was the standard method back in those early days. We don't have a rule that the hook be scale or in the scale location. And I have many times landed but the airplane stopped without hooking. Pretty easy to do since with a slider, the airplane is landing crabwise and just doesn't want to roll out.
Pete
Hey Guys,
Some airplanes without hooks have been considered legal, the Vought Kingfisher for one. Dick Perry held the profile record one with one. I have flown a Kingfisher at the NATS myself and received bonus points.
The OV-10 was declared legal by the AMA according to an article in the old AAM in the 70’s. That one seems to make sense to me. Clearly it was tested and used as a carrier plane. The attached picture is of a OV-10D (the last model) during qualification trials in 1985, over 15 years after the first models enter service and flew from ships in Vietnam. And the NAVY was still using them from carrier type ships. To me that makes it a carrier plane
As far as the MO-1’s hooks on the gear, most of the early planes used them to engage the longitudinal wire to keep the plane from veering off the deck. Again they weren’t used for very long. Are those really hooks?
It seems to me it comes down to intent. If the Navy tests for carrier use they probably intend to use the plane in that role.
Navy B-25 were PBJ-1 Some had hooks and flew and landed from carriers. Land based OS2U Kingfishers had hooks. Check out this site:
http://steeljawscribe.com/2007/10/05/flightdeck-friday-more-oddities
[/quote]
OK, How about the Lorning MO-8?(sp?) Looks much like the veneral MO-1 but with a non tapered, scalloped wing. I have a painting of one and for several years I thought it was a MO-1. Designed as a scout plane for the Navy and acording to a good friend it was tested mechanically for Carrier landings.
I can not scan the photo with this computer or I would attach a picture.
Joe
Mike,
I assume the site you ref is also for the Kingfisher, but I couldn't find anything on it about a hook on the kingfisher. I never seen a picture or drawing that showed one. Do you have a more pointed ref?
Joe,
The Loening M-8 was primarily an Army aircraft. One M-8-0 was ordered by the navy but I am unaware of any carrier use. There was a M-8-S seaplane version. Ted Kraver has one he built like in the 60's or 70's. It is a profile and is nostalgia legal since back then there was no scale bonus in profile.
John my source is the book "Naval Aircraft" 1977. L of C # 76-47871 Page 49 says "In 1918 the navy asked the m LOENING
CO. To develop a two seater to out preform he British Bri8stol Fighter, but the 46 models delivered saw shipboard service as observation aircraft."
The aircraft paintin is in Army colors and the scaloping was on the horisontal elevator only. I would say this is eligible for Navy Carrier.
Also in the same book is a picture on page 6 showzx Eugene Ely as he launched his Curtis form a ship. It notes that his plane's wheels, (floats)? and prop hit the water but Ely managed to stay aloft and make it to shore. A pure "loss of landing and flight score if you ask me.
At one time a firend, sent me three views of this plane but i lost them in moving here in 97' alon g with whole boxes of NCS materials.
Joe
Joe,
here is the 3 view. I'll let you fly it if you let me fly my KA-1.
Actually it is legal for Nostalgia profile since Ted flew one and there is no scale requirement
Joe,
If you like high wing monoplanes here is another evaluated by the Navy. Dornier H 'Falke' . I don't know what evaluted means however.
Joe,
John, I don't think so. After all the passing years I still feel like the guy in an old Laural and Hardy movie( or was it Abbot and Costello?) that went ballistic when ever he heard the name Niagara Falls..."Slowly I turned, step by step"!!! KA-1....Slowly Joe turns, step by step etc. Just now able to show up at a Carrier meet here in the NW without having my lawyers along, and both of them are on retainers. However, neither of them can stand the "A" word mentioned again!
Joe
Hi John,after a bunch of research I must come to the conclusion that the Vought OS2U Kingfisher never had a tailhook of any kind. Except for one written story on a another web site of an experiment with a home built hook with no photos there is no mention of wheeled carrier landings. I can't even find a photo of a wheeled Kingfisher on a carrier deck.
This site has about everything you wanted to know about Kingfishers including cutaway drawings of the control system,no hook to be seen. If you can believe the "home built hook" story the Kingfisher is legal for our event.
http://www.navsource.org/archives/01/57k1.htm
Actually I think it was the 3 Stooges, Curly was a truly underrated comic actor IMHO. BTW, great site for Kingfisher info, thanks. 8)
Pete
Now did you get a score? I remember several times people landing, getting a cable on landing but losing it when the plane stopped. The contestant was given a zero because the cable was not in the hook. That is where the little thin wire was attached to keep the cable in the hook. I have even received zero points for landing when the wheels got under the cable and the gear stopped the plane. You may have it or not but have witnessed people not getting scores for landing without getting a cable hook. VD~
The late Bill Skelton of OR was aboard a Carrier where the Kingfisher made an arrested landing. He even showed me a picture of it. Bill was highly regaurded here in he NW and for a short time after his death there was a plaque given out each year to the NW Carrier high point leader. One problem in research is that many authors give themselves too much credit for their research. This is particularly evident in history research. For example
The US marines are given sole credit for winning the battle of Bellaeu Wood in France in June of 1918. At that point, the Marines were under the officers of the 2nd Division US Army where all combat troops at that battle wore Army uniforms. About 6 years ago I visited that site in France and paid my respects to my uncle Frank a member of the 2nd Division, US Army who lies buried there at the foot of the hill at Bellaeu Wood. I guess the marines had a better press agent.
After all that, I still take the word of Bill over a historical review.
Joe
Mike,
I have never seen anything that says or shows a hook on a kingfisher. But it has been flown in the event forever as a legal plane. I also believe that it flew on and off carriers, seems logical, but don't have any documented proof of that.
John,
I was sure they had a hook but I must have looked at a hundred web sites and in all my books and I have a lot, no hook! The web site I found to be the clincher was the one I linked to. It looks like they got some factory drawings and the cut away shows nada!
Doc, remember that points are only awarded for an "Arrested" landing. That is defined as the model's forward motion being stopped by the hook catching a line. Snagging a line with the landing gear doesn't count; stopping without hooking a line doesn't count. I believe the rules say it's OK for the hook to become disengaged after stopping the model, but the little catch wire helps avoid any doubt or confusion.
