Speed,Combat,Scale,Racing => Carrier => Topic started by: Walter Hicks on October 19, 2013, 11:49:32 PM
I met a new vendor today at the Golden State Stunt Contest .He is selling a complete system 2.4 with servo,battery,receiver, and 2.4 trigger with aluminum c/l handle already set up for you for $99.00 I will try to
get some pictures tomorrow.
Asked the question in the scale section, but in carrier will it hold 100 pound pull test?
The new 2.4 item is now on ebey @ $99+ plus postage. Item looks well built. I bit the bullet and ordered one. I will let you know more when it arrives
Joe
Do you have link to the item on EBay?
I have searched under all sorts of key words and it doesn't show up.
Does anyone have his phone number?
Fred
Hi all, the person who is making this product is Ralph Saxton his phone # is 209-551-1242, I just got the latest
which has cnc cut metal for the handle which in this case is a Speckrtrum DX2E, system came with receiver already gone though the binding process ready to go. very light battery , turn key system I need to set it up
on a carrier plane asap. W Hicks
Fred
Fred, type in Control Line Handle in toys and hobbies.
Joe
Joe
Found the item using, control line handle, advanced search, under completed sales. Pull tested to 50 lbs, which I think is a "little light" for carrier.
Wayne
Thanks guys, I was looking under completed sales under the name "Ultimate U Control" with no luck...found it.
Looks good
Fred
Wayne,
Your right about the pull test. The home made " Bischoff " design will take a carrier pull. Mine will take at least 90 and probably more, but then I need a designated puller.
Wayne,
I hate to say this but if we don't watch out with these R/C handle conversions we are going to have big trouble. Has anyone reviewed pull test procedures on this handle? I remember a whole bunch of B/S about pulling safety thongs and J Roberts handles correctly. It took forever to get the procedure standardised somewhat and now we have this.
Wayne
Yeah, I agree about the pull tests. I seen that handle on the bay and when I seen 50 pound pull test I thought he has not pulled a Class I or Class II carrier plane. Profiles are a different story as I don't think they require a max pull of 100 pounds. But, I will have to go look at the rules again.
Doc
Profile is 20g's. 4lbs x 20 = 80lbs max. Most of mine pull at about 60 lbs. Class I and Class II 25 g's
Hi all I was told by Ralph Saxton that they were tested and pulled 65 lbs. This came from the horses mouth!
I ordered mine on 11/2. It came today! So far I am really pleased. More to follow as I take some time to get more familiar with it. I will note how light it is and how nicely it is put together. More later. I think it will be a selcome addition to HELP our Carrier hobby/sport make some gains in participants.
Joe
Here's two pictures of the newly offered 2.4 handle3. I really like it! After studying it for some time the only minor negative point is the line clips holes. I think I will enlarge them to fit the heavy clips I use. Other than that, the quality is there! I pull tested it to 80 pounds with no problem. Also the transmitter batteries were included.
Joe
I see the grip is at an angle. How do you do the pull test?
