Speed,Combat,Scale,Racing => Carrier => Topic started by: john vlna on February 23, 2019, 07:18:32 PM
The draft Brodak annucement says .25, can a smaller displacement be used?
Or a mild .35 like a FP .35?
Joe
The engine is a 25-size maximum. Yes, you can use a smaller engine. I will be testing very old ST 23 this spring.
No, you cannot use a 35 on this event, but you CAN use a 35 in six other events that come to mind.
I set the size at 25 because there are a lot of good throttled 25's on the market and this nicely fills a gap between 15 & 36.
