Speed,Combat,Scale,Racing => Carrier => Topic started by: Mike Anderson on September 11, 2015, 11:50:49 PM
At the Nats, I was impressed by the engine runs that Burt Brokaw and Eric Conley were getting with their piped Nelsons. I was able to pick up a used Nelson .40 Pylon engine and it is not going to be just 'plug and play'. Main problem is that the carb is just an air cutoff, with no fuel metering. The fuel goes through a normal needle valve/spray bar. I'm not sure how they run these things in Pylon and the engine that I got was for event 428 (which is now discontinued and so I wasn't able to read the rules for a description), but it seems that they were run on suction, with a max of 15% Nitro and using the tuned muffler which Eric has written about in other threads, so it should be adaptable to Class 1 pretty easily. So I got in contact with Eric to get a couple of questions answered, and we decided that it might make an interesting thread in case anyone else has a similar application, rather than just a series of emails between us.
So my initial questions for Eric are -
1. First off, is this the Nelson that you are using? When I inquired about the ability to idle and fly with a reliable mid-range, the fellow that I was talking to recommended this engine rather than the one he was actually selling. He claimed it would idle and fly at mid-range very well, even with the crude 'carb' that is currently fitted.
2. What are you using for carbs on these? I did look through some old posts concerning Nelsons here on SH, and found reference to Perry's in a discussion of the 'big case' .36. Is that also the carb you use in Class 1? I want to fit something with low-end metering, at least and wonder how much carb bore this engine will stand, using suction fuel feed.
3. What prop do you use? I won't be trying to 'reverse crank-shaft' this one but a starting point for diameter, pitch and material (glass, wood, carbon, etc) would be helpful.
4. This engine has a Nelson plug (naturally). I haven't pulled the head, but it doesn't look like a button type, so other plugs appear to be no-go. Is there more than one type of Nelson plug? I am only familiar with the Nelson conversion heads that are available for 1/2A combat engines that allow use of a Nelson plug (I think it's called an "HD").
5. I know you use the muffler, and that is my intention also, but just out of curiosity, have you tried the engine open-faced? Do you know of any Pros and Cons?
If anyone else has any info or other questions, please feel free to add to this discussion. Thanks in advance to Eric.
Mike, this is a great set of questions and I'll try to shed some light on them for you and I hope anyone else that may be wondering about the Nelson engines used in carrier. I'm pretty sure your engine is the same one that I am using. The Nelsons come in several different types of tune and the one you want is tuned for the quarter wave muffler. The other engine that you referred to was probably tuned for a full wave pipe (?). The carb that your engine came with is one used in pylon racing and I don't believe can be used in carrier. I have purchased all of my engines directly from Henry Nelson and I believed he referred to it as a "Nelson Sport 40" or "Sport Q-500" engine the Q-500 being equipped with an air valve which it sounds like your engine is equipped with. By chance did you get a quarter wave muffler with yours? I bought my Nelson engines back in the mid 90s and have never had to repair anything on them. I found that my engines got better and faster after almost 4 years of use, they just improved each year and don't know if it was because they were breaking in or I was just getting better at handling them. And then came Burt, he has taken carrier flying to a whole new level. I'm sort of going to try to answer your questions maybe one at a time that way it will give anyone else a chance to jump in and join the conversation. Eric
Hi Mike
I do not use "social media" and I do not normally visit any "forums" the reasons for which I will not go into here. However I welcome questions and comments from others and am more than willing to help anyone in any way that I am able. I just prefer to do it with direct contact. In spite of that, Eric has persuaded me to post on this forum in response to your post. So here goes:
1) The FISE Nelson .40 Pylon engine is what I am using for Class I carrier. I am not familiar with the carb that you have described so cannot help you with that.
2) The carb that I am using in Class I is a Magnum .91 carburetor that Henry Nelson recommended to me and he installed a sleeve for me on the outside of the carb throat so that it fits perfectly into the carb boss on the engine. The way this sleeve is designed, it only fits into the engine one way so depending on your engine installation the sleeve may need to be installed "backwards" in order to put the throttle arm on the correct side of the engine (as I had to do on one of my models). This carb has a throat ID of .430 so must be run on pressure. I use "muffler" pressure using the pressure tap on the "tuned" muffler that came with the engine from Henry. I also use a one-way check valve in the pressure line which does two things. First, it prevents fuel from flowing into the muffler during the "fueling" process. Second, it results in a much higher tank pressure since the pressure pulses are totally "additive". As a result of all these factors it is necessary to use a very fine thread remote needle valve assembly. I use the needle valve assembly from an OS carburetor that was designed for use on OS .15 size engines. I have also tried one that was designed for .25 size OS engine carburetors but it was a little more sensitive than I liked.
As for running this engine on suction, I tried using a ST carb with .350 bore but had problems getting reliable throttle response throughout the throttle range. I have had some success running this engine on suction using a Perry carb with .315 bore. If you really want to stay with suction I would recommend this setup. The only reason that I developed the system that I am using was because I was feeling the "need for speed". The down side of the way I am running it is I have given up some reliability for a little extra speed. Due to the very high tank pressure, even the slightest pin-hole leak anywhere in the system and it is big trouble amigo. But on the other hand when it is all working as advertised it is very satisfying.
3) I recommend using APC 9-6 props. They are available in right and left hand rotation so if you ever decide to try a reverse crank it is a piece of cake to convert. I have experimented with different diameters and different pitch props of different materials but always came back to the APC 9-6. For me it is the best compromise of performance, availability, cost, and consistency.
4) I highly recommend staying with the Nelson one-piece plugs. They are still available and they are still the lowest cost plug that I am aware of. If you use an after-market head that will accept a common 1/4-32 plug you will not only pay more for the plugs but you will also lose some performance because the Nelson plugs seal at the bottom instead of at the top as other plugs do. Nelson makes a "large hole" plug sometimes referred to as a "hot" plug and also a "small hole" plug that is usually referred to as a "heavy duty" plug and is what is used by the combat guys and some of the speed guys. Henry recommends the "large hole" plugs for carrier but I have used both and can't tell much difference but am currently using the "large hole" plugs.
5) There are three very good reasons that I am using the Nelson "tuned" muffler on all my Nelson carrier engines (except for the .15): PERFORMANCE, PERFORMANCE, AND PERFORMANCE. I tried very hard to get the same performance without using the tuned muffler. I was eventually able to get the same airspeed by using lots of Nitro and trimming the prop diameter down. The problem was that the acceleration as so poor that my high speed times were much slower. With the same prop and fuel the tuned muffler is worth approximately 2000 RPM. The weight and drag of the "tuned muffler" is a non-issue when compared to the performance boost, plus being able to use stock props and cheaper fuel.
Hope at least some of this may be helpful to you. If you or anyone else wishes to contact me directly here is my contact information:
Burt Brokaw
lecreit@msn.com
520-743-3003 hm
520-360-6552 cell
First off, a big Thank You to Eric and Burt for sharing their experience. Met both gentlemen at the Nats and personally had a blast all week - mainly due to the company that was there. I also owe a big Thanks to John V for the help with pitting and flying all week.
I'm attaching a picture of the engine. The carb shown is simply an air-cutoff, with no fuel metering and I'm sure it's just used as a shutoff, which is required in Pylon racing.
I was thinking of a Magnum or OS .60 size, run on suction. I have the Magnum .90 carb, which I'll be running on a Webra .60 in Class 2. I'll do some measuring and see what I might be able to do with it. I have used many of the Magnum carbs in the past, and generally I'm happy with them. Plus they are available from Hobbyking as ASP replacement parts for ridiculously low cost.
As for the plugs, I've been poking around some of the Pylon racing threads on RCGroups and it looks as though many of them are switching to Merlin plugs which are plug-in replacements for the Nelson HD, and available for pretty reasonable prices as well (~$5 @).
Again, thanks to both of you, especially Burt for gritting his teeth and posting to a forum - Like I said, we decided this might be educational and informational enough to be of general interest. To anyone else who has setup info like this, we'd appreciate more input.
H O L Y C O W, I didn't think I was that persuasive. Eric
Just a little more info. There are also 2 different versions of nelson engines. There are Long Stroke(currently used) and Short Stroke. Mike I would guess that your engine is a SS version because it doesn't have the counterbalanced drive hub and it looks like a small flange sleeve. Although to throw in a little more confusion there are small flange LS versions too. I attached a pic of a current LS version that you can see the flange for the sleeve between the head and top of the case compared to Mikes where you can see the gap.
There is also the Q 500 and the Q 40 versions. I have had long talks with Henry and with Mike Langois(the current manufacturer of Nelson Engines) about which would be better to use and both of them said that the Q 500 engine would be better for carrier use. The Q 40 engine would go faster but the power band is so narrow that it would just be a pain on anything but wide open throttle.
I have been breaking in a new Q 500 LS engine for a class 1 and It runs great so far on the bench. I cant find my calipers to measure th throat bore right now but I think it is around .400 and I am also using muffler pres as well as a Tetra tank.
On the prop sizing Henry told me that the Q 500 LS engines should not have any trouble turning a 9-6 because they are designed to run a 8.75" dia with around an 8 pitch at 20000+ rpm. so by the time you nic the tip of the 9-6 off on a couple of landings you will probably have a 8.75" prop.
I haven't had enough experience with the merlin plugs yet in carrier to be able to tell if they are better than Henrys plugs yet but they seem very similar and they have the 2 heat ranges just like Henry has. the one plus is that the Merlin plug allows you to use a standard glow driver instead of a clip.
One big suggestion for Carb choice that I have is whatever you do if you order a Perry carb do not listen to Garys suggestion on throat bore size because he has always tried to sell me a carb that was WAY TOO SMALL or he will tell me that the size I want to use absolutely will not work! They are very good carbs though.
If I can think of anything else I will post it.
David
