Speed,Combat,Scale,Racing => Carrier => Topic started by: john vlna on October 16, 2016, 12:54:21 PM
If you are into CL you probably are aware of the Annual Ringmaster Fly-A-Thon the first weekend in Oct each year. People all over the world see how many flights of a Ringmaster can be put up. I don’t have this year’s results yet but it’s going to be a lot.
No this isn’t on the wrong board. This year I decided to build a Ringmaster Jr. for the event, but as a carrier flier I thought, why not make it dual purpose, 15 carrier and sport plane for the Fly-A-Thon. The model is electric of course, that’s all I build these days, and set up for easily using different motors. For the Ringmaster fly I am using a 3536 1000KV motor that I have no idea where I got it from. It will run on 3 cells for sport flying. Carrier will need a more powerful motor for hitting 70MPH, easily swapped in, with a 4 cell battery.
Unfortunately, weather and illness keep me from flying it for the Fly-A-Thon, so no data yet on how a Ringmaster will do in carrier. It is an iconic design and I am sure someone has tried one before.
Color scheme is based on a F4F-3 wildcat flown by the Marines early in WWII.
Nice John. Sorry to hear you are not feeling well. Get better soon.
Wayne
Tim Wescott won the Sport 40 event in Portland, Oregon this Spring with a Ringmaster and an FP40. It can be done.
Hey John don't go getting sick on us. What too many voltage fumes. LL~ LL~ How about details of the construction? H^^
John, great minds and all that...I too am beginning to build a JR RM and plan on using it as a duel ship. This one will NOT be a take-apart ship. For the last 3 years I have been using a Jr. for the Fly-A-Thon. the next one will have a 32" ply full length doubler on the balsa and under the ply wood doubler as sell.
Get well my good friend!
Joe
John,
Is that a sheet wing?
The wing is foam, (3/8 Pink) with a KFm-2 airfoil. Is is a popular RC setup that I have been using for CL for about 10 years now. KFm airfoils are stepped airfoils, here is a link for more info http://www.rcgroups.com/forums/showthread.php?t=1117276 . I have found the KFm-2 quite effect for carrier and have used it on several 15 and 35 profiles before.
Don't worry Doc, I have now been vaccinated for voltage fumes. By the way except for the wing , construction is normal.
I did get it out flying today with the sport motor. I was conservative with the balance, but I think in carrier trim it should hang pretty well. Otherwise no bad habits, as you might expect from a Ringmaster. A good flying design.
