  • June 14, 2025, 02:55:08 PM
Author Topic: Pathfinder LE updates  (Read 27279 times)
Online Guy Markham
« on: October 17, 2023, 08:05:22 AM »
Any changes from the May 2006 article in Flying  Models? want to build one. Thanks, Guy
You only have to floss the teeth you want to keep!
Re: Pathfinder LE updates
« Reply #1 on: October 17, 2023, 11:52:00 AM »
Do a search on nthis forum. D>K
Offline John Miller
« Reply #2 on: October 19, 2023, 01:06:31 PM »
Try a search of Fred Cesquim's excellent Pathfinder L.E. build postings. Since a piped engine would not be used, he removed some of the lower fuselage giving the plane a leaner look. I don't know how that may have an altering effect on the side area, or if it's even a factor. His slimmer PF L.E. is a nice look.
John M.
