  • June 14, 2025, 09:55:25 PM
Author Topic: Design Basics  (Read 22539 times)
Offline John Miller
Design Basics
« on: November 08, 2020, 01:34:46 PM »
Figuring Control ratios:
Let's assume that most bellcranks rotate 45 Degrees in each direction. If we want 45 degrees of flap, the ratio is easy, 1 to 1, but what if you want 30 degrees of flap rotation?
Using simple Algebra we can solve these types of questions.
In this type of problem, we will have 3 out of 4 variables. Usually, these fixed values will be the bellcrank rotation, the flap horn length, and the flap rotation we want. The number we're missing is the bellcrank moment arm.
The 4 attachments are PDF's and are sized for a standard sheet of paper. You can download and print them with your printer if you desire.
Re: Design Basics
« Reply #1 on: November 09, 2020, 05:16:43 AM »
You can also do this with a motion diagram.
