  • July 08, 2025, 03:30:05 PM
Author Topic: Wood fillets  (Read 3785 times)
Wood fillets
« on: October 05, 2006, 09:37:46 PM »
Since I haven't ordered my Super Fil yet, and I have tons (literally it seems) of scrap contest balsa, I am going to make some wood fillets on my Profile Stuka that I am getting ready to cover.  I will use Ambroids to glue it all down, and then carve/sand them to shape.  I tried it under the stab, and it is a quick process.
Anyone else use wood for fillets??
Bill <><
Online RC Storick
Re: Wood fillets
« Reply #1 on: October 05, 2006, 11:14:31 PM »
You will see them on my next T-Bolt. Much stronger and lighter..
Offline Glen Wearden
Re: Wood fillets
« Reply #2 on: October 06, 2006, 07:57:15 AM »
I've thought about using triangle stock stuck down with Sigment.  I guess one would have to wet it to go around the leading edge curve.  Think I'll try it on the Oriental I'm building "at".   Glen
Glen Wearden
Offline L0U CRANE
Re: Wood fillets
« Reply #3 on: October 06, 2006, 10:09:05 PM »
Ty,
Epoxy fillets, without even some 'dust' (microballoons or whatever) CAN be painted and not lift.
First to suggest this, I think, was Dee Rice, in the MAN Oriental article. Basically, 5-minute epoxy smoothed on with fingertip or prop tip...
For the amount used, negligible weight gain. To keep it paintable, nitrate dope dusted-over per Joe Reinhardt's FM Gypsy 35 article... Just overspray to build color coats and butyrate color.
Mask? yeah. and some high% rubbing alcohol to feather the edges. Use the high% rubbing isopropyl to kill finger oils if you, like me, can't resist touching the fillets with oily fingers.
Sanded balsa fillets with a wipe of 5-minute are even lighter and larger... Going around tight turns may require cutting a 'glove' of soft balsa to the curve... No matter - even 5-minute will saturate well enough. When all this under-stuff looks right, a thinly stretched scrape of 5-minute finish-preps the fillet for final finishing.
Ty, if I can do it, you sure can.
\BEST\LOU
Offline Ward Van Duzer
Re: Wood fillets
« Reply #4 on: October 08, 2006, 08:35:40 PM »
Do you have to soften the leather filets before you glue them down? How?
Did balsa once...How come I never did that again?
Re: Wood fillets
« Reply #5 on: October 08, 2006, 09:53:10 PM »
The leather fillets I use are very soft.  I pre-glue the area the fillets will "fill" and then using a lot of Ambroid I lay the precut fillet into the joint. I use a ball on a stick to force them into the groove so to speak.  They come out very smooth and no edge. They lay right down. On  occasion I have wet an area with thinner and relaid it. Then after they dry, I coat them with Ambroid.  Later I dope and sand them. I do the fillets AFTER the wing is covered.  There is a warehouse that sells them in one hundred foot batches.  That's where everyone gets them. No kidding. ;D <=
The ball on a stick is a device I obtained through Micro Mark that is used to smack a drilled hole to make it a little smaller. ;)
You are correct, Sir!
For the "ball on a stick", I just glued a ball on a stick with J.B. Weld.  **)
Bill <><
Re: Wood fillets
« Reply #6 on: October 09, 2006, 09:01:42 AM »
Marbles!
Offline Tom Dugan
Re: Wood fillets
« Reply #7 on: October 09, 2006, 09:18:42 AM »
Yes a marble will work.  You can also use steel ball bearings.  The size depends on the radius of the fillet.  Ive used popcicle sticks too, which can be bought at a crafts store.  But, the ball on a stick give a more consistant radius.
Thomas
Offline Ron Merrill
Re: Wood fillets
« Reply #8 on: October 09, 2006, 09:19:46 AM »
Why Ambroid glue? ??? Ron.
Re: Wood fillets
« Reply #9 on: October 09, 2006, 09:46:09 AM »
It's light, sands well, It's light, and dope sticks to it really good!  Did I say it's light??
Bill <><
Offline Ron Merrill
Re: Wood fillets
« Reply #10 on: October 09, 2006, 10:48:20 AM »
Thanks Bill, makes sense to me. y1 Ron.
Re: Wood fillets
« Reply #11 on: October 11, 2006, 02:41:01 PM »
And it makes my jeans stand up in the corner all by themselves!
Offline Dennis Pedersen
  • ACE
Re: Wood fillets
« Reply #12 on: October 11, 2006, 08:15:56 PM »
I used balsa fillets on my Nobler.I cut the balsa into a triangle stick shape  .It is cut across the end grain so you pieces are going to be 3 or 4" long.This way it makes curves nice and adds more strength.I sand a slight concave into it before gluing it down with as stated (Ambroid).Then just sand and blend into the wing and fuse.Very easy and light. ;D
Dennis Pedersen
Alberta Canada
Offline Jim Thomerson
Re: Wood fillets
« Reply #13 on: October 12, 2006, 08:10:02 AM »
Just use your wing rib pattern to cut fillets out of scrap balsa.
Offline Bill Sawyer
Re: Wood fillets
« Reply #14 on: October 12, 2006, 09:25:43 AM »
I sell leather fillets by the foot. There is no minimum. My ad is on the classifieds. I also will send instruction sheets if needed.
Bill Sawyer
AMA 53987
Windancer Models
