  • July 12, 2025, 01:36:12 PM
Author Topic: Wing alignment.  (Read 604 times)
Offline Perry Rose
Wing alignment.
« on: June 18, 2025, 11:32:44 AM »
What is the favored technique for aligning a wing into a full fuselage? Profile planes are simple, straight leading edges again simple. This one has a tapered leading edge straight trailing edge. J.D. Falcon.
Re: Wing alignment.
« Reply #1 on: June 18, 2025, 02:11:35 PM »
What has worked for me is to mark a true centerline on the fuselage using pins and thread.  To get the horizontal alignment I measure points on the wing equal distances from the center then measure the pin to tail and pin to nose distances until they are equal.
Offline Perry Rose
Re: Wing alignment.
« Reply #2 on: June 18, 2025, 04:05:03 PM »
Thanks Ken.
Re: Wing alignment.
« Reply #3 on: June 19, 2025, 07:32:53 AM »
Ken's method works for me.  It's just basic geometry.
Re: Wing alignment.
« Reply #4 on: June 19, 2025, 05:12:21 PM »
How do you find the center of the leading edge on the wing?
Re: Wing alignment.
« Reply #5 on: June 19, 2025, 06:55:44 PM »
You mark it while it is in the jig and mark the fuselage sides.
