  • June 16, 2025, 07:05:58 PM
Author Topic: Windy U Still Providing Inspiration ( For repairing plane)  (Read 4329 times)
Online Walter Hicks
« on: September 23, 2018, 10:36:47 PM »
- This caused a control lock up and subsequently this:
. Bellcrank was held on 1/8 wire by soldered eyelets one let loose.
Starting repair of fuse:
« Last Edit: September 23, 2018, 10:55:01 PM by Walter Hicks »
Online TDM
Re: Windy U Still Providing Inspiration ( For repairing plane)
« Reply #1 on: September 24, 2018, 08:23:56 AM »
Walt what did you do  :'(
Online Walter Hicks
« Reply #2 on: September 24, 2018, 10:27:01 AM »
I did nothing , when the plane was launched it rolled about 5 feet then did a loop as the bellcrank locked in up nothing I could do. NOT Fun I really liked this plane. Windy has had video of repairs which was very much the inspiration for the repair.
« Reply #3 on: September 24, 2018, 06:59:01 PM »
Walt,
Did you find out what caused the lock up? While you have the wing in two halfs check all the motion of the bellcrank, leadouts, pushrods. Even a small bind can cause a problem at full tension with normal vibration. Keep us informed what you find.
Best,   DennisT
Online Walter Hicks
« Reply #4 on: September 24, 2018, 07:10:19 PM »
Dennis , The Bellcrank was carbon fiber and the bearing is a ball bearing, and was mounted on a 1/8 piano wire. It was secured by Eyelets on both sides of the bellcrank. One of the eyelets let loose and the bellcrank came off the ball bearing and locked up. See picture.It would be best to use JB Weld if using this set up.
« Reply #5 on: September 25, 2018, 11:50:38 AM »
That does look bad.  But as Windy says, keep all the pieces you can find.  I lost my Sheeks Spitfire because the rod vibrated/move out of the bottom ply plate.   I now make sure there is ply top and bottom on the rod as well as notches for the wheel collars.   o far so good. D>K
« Reply #6 on: September 26, 2018, 07:46:35 PM »
Walter...sorry to see your nice Spitfire busted up like that. I hope you'll add some fiberglass (and not that weenie 3/4 oz stuff) over the repairs. Maybe two or three layers...
OBTW, I contacted Windy for his suggestions for grafting a whole new nose onto Pete Peterson's old Sultan, which was tailheavy and had a 1/8" balsa nose doubler go soft. Windy's reply was very negative and suggested building a whole new fuselage. When I contacted him, I stated that I intended to build a new nose back past the wing highpoint and fiberglass the new nose on with 2 oz glass & epoxy. The thing was tailheavy anyway, so intend to extend the nose an inch and install a RO-Jett .76/pipe. Rumor has it that there's 5 oz of lead in the nose, so I could possibly end up with a lower net GVW.  :o Steve
« Last Edit: September 29, 2018, 03:59:35 PM by Steve Helmick »
Online Walter Hicks
« Reply #7 on: September 26, 2018, 08:05:01 PM »
Yes Steve I will be adding fiberglass cloth both inside and outside. the fuse doublers broke in places where I could use 1/64 ply over the breaks for strength. The way it broke makes for a descent repair. Now the wing that is another issue !!!! Will be doing that this week so far so good. It has a dihedral and was a take apart so too many areas to line up correctly it will be a challenge.
Online TDM
« Reply #8 on: September 27, 2018, 06:49:49 AM »
Walt use this http://www.easycomposites.co.uk/#!/fabric-and-reinforcement/carbon-fibre-reinforcement/woven-carbon-cloth-under-400gsm/plain-weave-200gsm-3k.html
Place the cloth with 3M77 spray wherevr you need to fix or reinforce then hit with thin CA. You don.t need epoxy to use composites especially for fixing stuff. The 3M77 should be very light it is there just to keep the cloth in position. Use this on the inside of the fuselage and that should make the finishing the outside of the model easier. Same technique applies if you use glass.
Online Walter Hicks
« Reply #9 on: February 14, 2019, 11:07:58 AM »
RL=https://s82.photobucket.com/user/kickercoach12/media/IMG_1242.jpg.html][/URL]
Ready for sealer and new paint!!!!!!!
Online Brent Williams
« Reply #10 on: February 14, 2019, 07:38:10 PM »
Photobucket links have troubles on some browsers.
Here's Walter's plane.
« Last Edit: February 15, 2019, 06:51:05 AM by Brent Williams »
Online Walter Hicks
« Reply #11 on: March 15, 2019, 11:17:30 PM »
Work continues on the Spitfire, Wing is mostly repaired, Fuse done, canopy attached today will add fillets to canopy tomorrow and touch up paint over fillets. I need to repair one flap where the flap horn is. And paint the clear ( 2 part auto clear) Stilll having problems trying to post pictures .
When if I ever do figure it out I will post pictures.
« Last Edit: March 16, 2019, 01:36:46 AM by Walter Hicks »
Online Walter Hicks
« Reply #12 on: March 16, 2019, 01:10:46 AM »
Basecoat on with Blending clear, next is to spray Auto Paint Clear ( 2 part Urathane ,Nason)
Online Walter Hicks
« Reply #13 on: March 16, 2019, 01:16:03 AM »
- finally a picture that is right side up canopy drying and will have fillits added tomorrow.
« Last Edit: March 16, 2019, 01:44:44 AM by Walter Hicks »
Online Walter Hicks
« Reply #14 on: March 16, 2019, 01:46:15 AM »
Fuse with Blending clear, will add fillets for canopy and they touch up basecoat then Nason 2 part Auto Clear
Area near nose ring will also need some work
