  • June 18, 2025, 12:47:12 AM
Author Topic: Cornstarch filler?  (Read 3875 times)
Offline the original Steve Smith
  • Fly Stunt!
Cornstarch filler?
« on: July 31, 2006, 08:23:56 PM »
Ok, I read the entire Talc post and several folks mentioned using cornstarch.  Well I've never used anything but premixed sanding sealer so I don't know the proportions.
Any help would be appreciated - I really want to learn how to do a decent finish and I've got two Twisters on the board and almost ready to start with the covering/finishing.
I'm going to brush on the mixture so how much dope, thinner, and cornstarch in the mix?  How many coats of that do I do?  I know I have to sand most of it off each coat.
Also I don't have any spray equipment nor a place to do it so I am stuck with brushes.  Any hints on brushing rather than spraying will also be listened to and utilized.
Thanks in advance for your help.  y1
AMA 2112
  • Fly Stunt!
Re: Cornstarch filler?
« Reply #1 on: August 07, 2006, 09:03:11 PM »
Thanks Ty - I'll try this as soon as it gets a little cooler here in the 'Lou.  Gotta work in the garage where there's no AC.
AMA 2112
« Reply #2 on: August 07, 2006, 09:18:22 PM »
Did you know that newsprint was used at one time to buff out finishes?
Bill <><
Offline Andy
« Reply #3 on: August 23, 2006, 09:08:06 AM »
Hello Ty,
Where is Lovelock? There used to be (and still kinda is) a town out here in N. CA called Lovelock and there was a local paper of sorts called The Miner. Not the same place?
Andy
Offline Jim Thomerson
« Reply #4 on: August 23, 2006, 01:55:06 PM »
And then there is the hand rubbed finish, where you just rub the finish with your bare hand until it shines.  Try it, it works.  don't think I would do an entire airplane that way--take forever.
« Reply #5 on: August 23, 2006, 01:58:50 PM »
Nah, Jim....... too many blisters.........
 n~
Bill <><
Offline Ironbomb
« Reply #6 on: August 24, 2006, 01:39:52 PM »
I am gonna try the cornstarch filler. I have a box of Argo type filler, I mean starch. I will post a pic of the happy mess. I hope it works as good as it sounds like it does.  :)
 y1 Greg
Beating the crap out of the ground, one airplane at a time
Greg Bossio
AMA 834382
« Reply #7 on: August 24, 2006, 04:16:08 PM »
You want to be a little careful about putting it on too thick.  It can crack on you as the (even non-tautening) dope shrinks.
Offline Ironbomb
« Reply #8 on: August 25, 2006, 08:09:54 AM »
Thanks for the tips guys. I should have some on by tonight. I had forgotten what the thickness should be. Had to  say "pancake" didnt you, now I am hungry for pancakes... <=
I should have a pic up tonight, of the fues, not the pancakes.  ~>
Greg
Greg Bossio
AMA 834382
Offline Ironbomb
« Reply #9 on: September 01, 2006, 06:38:56 PM »
I tried the cornstach filler. it worked great, and I'll use again. I only goofed in that I made it too thick. I guess I missed the part about "runny" pancake batter. I made like pancake batter. I had a ton to sand off, and I did sand it all off. Everything was real smooth, but then I got into the silkspan. So after I fixed the "sand thru s" I weighed the fues, 10.8oz. Ouch! I took it all back down to bare wood, and am starting over. Weight is now 9.1 . Thin is what I'll make it next time. I would post a pic, but they didnt show anything close to detail. The parts looked like they had cake frosting on them. I shoulda quit while I was so tired, but didnt want to waste quality drying time while I slept. Mistake.
Things are back to "normal" for me now.  :P
Greg  :X
Greg Bossio
AMA 834382
« Reply #10 on: September 02, 2006, 07:30:59 PM »
I use blue ink in all my nitrate and filler.  Just enough to tint it.  When I am using silkspan on a fuselage, it gets three coats of notrate, sanded after 2 and 3 to knock down the grain, then I put on the silkspan.  The filler comes next.  I just never put filler on the raw wood if I plan on covering the wood.  After 8 years, there is no grain showing on my Geo Juno.
Bill <><
