  • July 07, 2025, 07:14:45 AM
Author Topic: What is the best way to sand a LE on a wing???  (Read 2180 times)
« on: March 26, 2011, 03:47:23 PM »
I want to make sure I do this right.
What is the best way to sand the LE on a wing?
I did a search did not come up with anything good.
Offline Allan Perret
  • Proverbs
Re: What is the best way to sand a LE on a wing???
« Reply #1 on: March 26, 2011, 04:26:48 PM »
Sticky back paper on inside of PVC pipe sections.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: March 26, 2011, 04:37:37 PM »
Thanks Allen!
« Reply #3 on: March 26, 2011, 06:48:47 PM »
Alan, that is one cool idea and I thank you for sharing it.
« Reply #4 on: April 01, 2011, 10:34:21 PM »
Good ole 3M Blue - is there anything it cant do?
I Must admit - I have not heard / Used this teqhnique - but It should work perfectly.
« Reply #5 on: April 03, 2011, 04:42:19 PM »
paul - on the vector - you want to pay particular attention to the LE shape - there is a template on the plan - cut it out and glue it to a block of balsa - then cut to shape - glue sand paper to the internal face and use that as the shaping tool.
I will take a photo of my one when I get the house unpacked.......
Offline Joe Rice
« Reply #6 on: May 27, 2011, 05:46:31 AM »
 H^^ H^^ H^^ Brilliant ideas on this site just keep coming y1
Joe
Joe Rice
AMA 740106
Online Larry Renger
« Reply #7 on: May 27, 2011, 10:30:14 AM »
Use a razor plane to get the contour close, then "shoeshine sand" for perfect contour.  The technique is to hold the wing leading edge up, then grab a length of sandpaper at both ends and work it back and forth across the l.e., holding the ends as close to the wing as possible.  The tension on the paper will hit only the high spots and leave the low ones until it is perfectly even.  No hardware required!
  • Proverbs
« Reply #8 on: May 27, 2011, 04:54:34 PM »
I realize now that I left out the most important tool for working on a wing, that's the holder.
This one I made with the jaws from flexible 1/8" masonite sheet accommodates various wing shapes and sizes.
I use this jig when shaping LE, TE, or cutting hinge pockets.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline builditright
  • So happy to be alive!
« Reply #9 on: May 28, 2011, 03:26:57 PM »
I make these jigs for shaping the L.E. on some of our kits
Thank you and God Bless
Walter
aka/ builditright
Offline Douglas Ames
« Reply #10 on: May 28, 2011, 06:41:55 PM »
For a specific leading edge shape, that's a great idea!
AMA 656546
