  • June 20, 2025, 12:48:19 PM
Author Topic: What makes the best building board?  (Read 3926 times)
Offline Douglas Ames
« on: July 04, 2011, 07:26:01 PM »
I need a piece about 30"x 60". Would a scrap pc. of drywall work or is there something better at Lowes/ Home despot? It's gotta be flat and true. I normally don't use pins but my next project I wan't to be more precise.
AMA 656546
Offline Leester
Re: What makes the best building board?
« Reply #1 on: July 04, 2011, 08:09:24 PM »
The drywall will work fine as long as it's on a flat surface like an old solid core door.
Leester
ama 830538
« Reply #2 on: July 04, 2011, 09:00:13 PM »
you cant beat glass.......but if you want to use pins - drywall is the key - like Lee said - make sure its one something flat......like glass HA
« Reply #3 on: July 04, 2011, 09:40:48 PM »
Like sheetrock, glass has to be placed on something flat, or it will also conform to the surface below.
I was given (well, I asked for it) a glass coffee table top that was abandoned during a move. I put a solid core door on on the 2' x 6' workbench I built in Jr. High shop, followed by a piece of white melamine skinned Masonite, followed by the glass. I adjusted the whole pile to be not only straight, but flat to the World, using a machine level. Then I covered it with all the clutter I could possibly accumulate....<sigh>   :( Steve
Offline Allan Perret
  • Proverbs
« Reply #4 on: July 05, 2011, 06:29:25 AM »
Here's my recommendation.  You dont need it to be 30" wide.  That is a large surface to try to keep staight and flat.  It it much easier if you make it just wide enough to build your wing on, around 14~16 inches.  I use the 16" wide white melamine shelf boards.  They are available in 4, 5, and 8' lengths at Home Depot and Lowes.  Also get a second 12" wide shelf,  rip it on table saw to 3" wide strips and glue or screw a couple of those to the bottom of top shelf to keep it straight.  Makes a good rigid portable building surface that will stay straight and flat on its own.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #5 on: July 05, 2011, 09:35:29 AM »
>>Like sheetrock, glass has to be placed on something flat, or it will also conform to the surface below.<<
Depends on how thick the glass is, but generally true. I have a solid chunk of oak (2" thick) as a 40" x 65" building board. It's been squared up pretty well. The I sometimes use glass on that. I have a piece of display case glass 20" x 60 inches and 1/2" thick that dates back to the 50s sometime. I also have a smaller piece, maybe 28" x 12" that I use to build certain things.
Another issue is that the surface needs to be flat and not just level. Watch out for flaws in drywall that can cause you problems.
There are a lot of options. I know one guy that got a chunk of water cut granite that he uses as a build surface. Absolutely flat. Cool if you can both afford it and have 10 guys that can carry it to your shop.
« Reply #6 on: July 05, 2011, 09:53:13 AM »
I think drywall (gypsum board) is a poor choice.  For the money, a piece of 3/4" MDF is flat, straight, and it doesn't warp over time.
Offline Peter Nevai
    • C3EL
« Reply #7 on: July 05, 2011, 02:15:37 PM »
It kinda depends on how you are going to jig your fuse and wing. I agree that the item be only long enough to fit the biggest wing you will ever plan on building, and just a bit wider. Obviously if your jigs require screwing into the building surface you can't use glass. But if your jigging method uses jigs glued to the surface then glass is perfect as you can easily remove the jigs and with a couple of passes of a razor blade to scrape off any CA you ready to go with a new build. The glass should be 3/16 to 1/4 inch thick and if you can get it tempered. Glass over any good flat surface is a dream to build on, so long as you don't have to pin stuff in place, or screw attach jigs. If otherwise then any of the other reccomendations work fine. Granite or marble is great also, I had a 5 X 2 1 inch thick marble slab at one time. It was part of some discarded furniture, heavy as heck though. you can use some granite floor tiles glued to some MDF that will work as well, (not so heavy) The problem with sheet rock, is it absorbs moisture and if you get it wet it can deform otherwise it holds pins well. Still has to be mounted to a flat subsurface, spilled glue can not be removed so you have to be careful, nice thing about it is that you can easily replace it between builds.
« Reply #8 on: July 05, 2011, 05:09:49 PM »
Level to within 0.001" sounds very high-tech, but really isn't necessary.  We build with balsa wood, then cover it with paper that shrinks and pulls in all directions.  Then, we coat with dope, which shrinks and likewise pulls in all directions.  The straightest structure in the world is likely to warp or twist once covered and painted.
The real art is being able to detect anything less than perfect during flight, and then being able to get it straightened out!
Some of my planes flew absolutely straight the first few flights.  Then, after a few months aging, warps and stuff began to appear.  It is a constant struggle keeping everything straight.
Unless, of course, you build from pine and cover with plywood and Super Kem-Tone.
Dream on!
« Reply #9 on: July 06, 2011, 08:02:38 AM »
Over on Stuka Stunt, Al Rabe has constructions articles about his builds of his various planes.  He makes what I call temporary jigs for building using the rod method.  As I understand it he seldom uses the same jig twice.  Boards have a tendency to warp over time.  My old jig has been replaced with a peice of honey comb airplane section that is barely wide enough, but is dead straight according to my level.  Using the CLC Jig my P-47 wing is coming out pretty straight. H^^
« Reply #10 on: July 06, 2011, 10:32:16 AM »
Of course, my building board is the best and most stable I can find, and that helps building everything as straight as possible.
My "rant" was against those purists who insist on 0.001" straight (not necessarily "level", because level with the world doesn't matter)
Offline louie klein
« Reply #11 on: July 07, 2011, 06:55:17 AM »
Getting back into this hobby after 20 yrs I have a differant mind set. Back then I built pretty nice planes and flew decent, but now I fly not so decent but still build good. Well I made up my mind to get to fly good first and build better later but on a wim I baught a new Vector kit and after making this decission it will probably be 2 yrs before I start it! Thank the gods for Ringmasters!!--LOUIE  H^^ H^^ D>K
Offline Steven Kientz
« Reply #12 on: July 09, 2011, 06:34:25 AM »
  The coated melamine shelves work very well. I have went a step further and drilled holes at the rib spacing, using 90 deg. brackets for rib holders. Check them for squareness before using.
Steve Kientz
AMA 855912
Offline chuck_b24
« Reply #13 on: August 22, 2011, 12:50:56 PM »
Dumb question BUT what is "MDF"  ??? thanks  chuck
Offline BBury
  • AMA 63928
« Reply #14 on: August 22, 2011, 01:06:46 PM »
« Reply #15 on: August 22, 2011, 01:09:28 PM »
MDF = Medium Density Fiberboard.  It's the stuff that they make cheap bookshelves and kitchen cabinets out of.
In my oh-so humble opinion the stuff will pretty much take on the shape of whatever it's laid on, if you let it sit long enough.
My building board is a 1' by 4' hunk of 3/4" think plywood, with about 1/16" of bow across the length of it.  If I'm really trying to build straight, I use a rod jig and I shim up the ends so the rods are straight.  For anything with dihedral I just turn the board so that it bows down and leaves a graceful (and insignificant) upward bow to the wing tips.
I think the next time I get my bench cleaned all the way down to the surface I'm going to put down a sheet of tempered glass that I have waiting, probably on screw- or bolt-heads so I can adjust it.  Then when I want something really flat I'll build on that, and hold things down with weights.
For the ultimate in flat building boards, find a surplus cast aluminum, cast iron, or granite plate from some bit of machinery.  It'll weigh a ton, you won't be able to stick pins in it, if you paid full retail it'd cost as much as a really fancy new PC -- but it'd be way flatter than a board, and it would stay that way.
Flat, cheap, easy to use -- pick one or two...
« Reply #16 on: August 22, 2011, 01:16:39 PM »
No matter what you are using, if its not on a flat base it will warp. Yes glass will bend, so will granite. I have access to a lot of granite so that is what I use. If it is not on a flat surface it will bend, just like wood, balsa, MDF, just about anything. You would be amazed at the amount of bend I can get out of a piece of granite...... Now obviously the smaller the piece the harder it is to bend.
Offline Mike Scholtes
« Reply #17 on: August 22, 2011, 11:14:45 PM »
Home Despot sells a milled wood plank in the shelving dept made from many lengths of about 1x2" light wood glued as a big laminated piece then milled flat. With all the glue joints it is very warp resistant. I use 3M spray adhesive to attach 1/2" foam sheet to the board to serve as pinning material; the wood is too hard for pins. The piece I use is 72" by about 20",  more than big enough for anything we are likely to build. It is also cheap and easy to move. The wood pieces from which the board is made are full-length 72" pieces. I have built many wings on this board, all straight.
Offline Dick Pacini
« Reply #18 on: August 23, 2011, 09:27:23 AM »
I bought a large oak stair tread from Home Depot.  It was a full 3/4 thick.  I took it to a cabinet shop and had them plane both sides to true it up.  Then, I put about 8 coats of Min-Wax water based urethane varnish, flipping over after every coat dried, until both sides had the same number of coats.  I also block sanded after each coat was dry.
I have used it only once to jig up a fuselage.  I can tell you this, it is flat but a bitch to stick pins into!
AMA 62221
« Reply #19 on: August 25, 2011, 01:00:21 AM »
I have been using an abandoned billiards table for years, even decades.  I have a piece of tempered 3/8"  glass for the top.  It is shimmed dead flat and I check it periodically.  CA will spot glue anything to it and removal is easy.  I can get my full size stunters on it for setting up the surfaces.  I do have a couple pieces of stationary used as shims under the glass.
For smaller wings I tape a piece of blue foam, just larger than the wing, so that I can use pins.  It is removable and I just store it under the table until I need it again.
Having a table that size is a blessing when building an I-Beamer, or doing final assembly of parts like the wing and stab.
I have a wing building station on the top of one of my counters.  It is 2" white foam which I shimmed flat.  I can build wings up to 54" on it.  Main thing is simply to make the surface FLAT.  If you need to pin then put a piece of blue foam or dry wall over the flat table.
#2 choice would be a flat solid core door covered with 3/8" glass.  I found my piece (42"X66") at a hardware store that cuts table tops for next to nothing.  It was cut for a customer but never picked up.
Big Bear
