Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 19, 2025, 02:58:54 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Flexible leadouts vs Balsa wing tip slot.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Flexible leadouts vs Balsa wing tip slot. (Read 1898 times)
kevin king
25 supporter
Trade Count:
0
Admiral
on:
April 08, 2022, 12:56:21 AM »
Ive never used flexible lead outs before, so I am assuming i will need plywood top and bottom of the adjustable Lead out slot? Please enlighten me.
Logged
Craig Beswick
25 supporter
Trade Count:
0
Captain
Re: Flexible leadouts vs Balsa wing tip slot.
Reply #1 on:
April 08, 2022, 01:04:37 AM »
Kevin,
for the quality of model you build, yes.
Mine are lucky to last 6 months so I haven't seen the need. Ha.
Craig
Logged
AUS 87123
"The Ninja"
Motorman
Trade Count:
0
Admiral
Reply #2 on:
April 08, 2022, 06:48:27 AM »
1/64" birch ply usually does the trick. On some designs you can put the line slider out in the tip, cuts down on the problem.
Logged
kevin king
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
April 09, 2022, 01:19:29 AM »
Went with the 1/64 ply top and bottom. Thank you.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
Jump to:
=> Building techniques
