  • July 08, 2025, 05:49:09 PM
Author Topic: Wing Jig Pic  (Read 3755 times)
Wing Jig Pic
« on: February 06, 2016, 09:30:25 PM »
I made this out of 2" "C" channel aluminum with 1/8" wall. The top edge was milled to a thickness equal to the kerf of my jigsaw blade (.050") so I can just cut little slots in any rib and get it on the jig. The leading edge is two pieces of channel so I can make a taper or straight leading edge wing. It sits on a 1/2" glass table top that is shimmed to be flat.
« Last Edit: February 10, 2016, 07:04:05 AM by Motorman »
Re: Walts Wing Jig
« Reply #1 on: February 06, 2016, 10:36:29 PM »
You're assuming that extrusion is straight and not twisted or anything? I've seen some that were WAY not straight AND twisted.  y1 Steve
Re: Walts Wing Jig
« Reply #2 on: February 07, 2016, 07:40:38 AM »
I like the idea.   Yes some places you have to look through the rack to find straight pieces.   But why not just leave the edge at full thickness?
Re: Walts Wing Jig
« Reply #3 on: February 07, 2016, 08:41:10 AM »
Being a machinist, I checked them for straightness and they were certainly milled straight after that. I milled the edge because I didn't want a big slot on the trailing edge.
Re: Wing Jig Pic
« Reply #4 on: March 28, 2016, 12:58:02 PM »
Well it's finally starting to look like something. Not sure how to finish the top. I think I'll just put a 1/4" sheet on it and round it off and go bubble canopy. This is a one off 92% TunderGrazer 40 so I don't want to bother with molding bucks for it. My first full fuselage, it's funny I've boxed the fuse on 3 sides and it's still pretty flexy, will adding the top give it the tremendous stiffness full fuse is famous for?
Re: Wing Jig Pic
« Reply #5 on: March 28, 2016, 01:33:49 PM »
Absolutely,, Its not a box until,, well until its a box,, until then its just three chunks glued together
