  • June 18, 2025, 06:29:39 AM
Author Topic: Vents, vents, vents, Oh My!  (Read 4014 times)
« on: August 11, 2007, 09:03:22 PM »
Between Playing Lord of Destruction and Freelancer on the computer and doing yard construction, I've managed to get a few things done on the new plane. Included are a picture of the new vent I punched in. Just needed a touch more exhaust area from the pipe tunnel and one pic of the flaps. One flap is shaped and just needs final sanding and the other is constructed, but not yet shaped or sanded.
On the first picture, keep in mind that this thing has two cowls. The front one and the one that the scoop is mounted to.
Fun stuff.
Offline steve pagano
Re: Vents, vents, vents, Oh My!
« Reply #1 on: August 11, 2007, 09:14:30 PM »
Simply Amazing craftsmanship! Awesome looking flaps, Man i can wait to hear how it flies #^ #^ #^
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
« Reply #2 on: August 11, 2007, 10:10:01 PM »
Thanks, Steve.
Well, at 650 square inches and about 60oz, it should fly OK if it's square...and I think it is.  :)
It's aerodynamically the same as the last plane, the Slider with a couple of corrections I thought it needed/
I have the paint scheme pretty much figured out. White, black, silver, bronze, candy apple red and candy cobalt blue. I have an, uh, interesting paint layout worked up. Should be fun if I can lay off too much paint. Should be a problem, black (the base color) is pretty light. Actually, not all that much will be black, but it is the base.
« Reply #3 on: August 11, 2007, 10:19:03 PM »
Randy how did u come up with the idea of the built up rudder does it have an air foil? or is it just one flat thickness? I would love to try something like that on a design I'm working on.
A.M.A. 820-823
« Reply #4 on: August 11, 2007, 10:29:55 PM »
Steve,
Like a lot of things, it just sort of occurred to me. Odd brain, I guess. Thought it would look cool and be functional. No, it's not airfoiled. All of my designs tend to be pretty square. Equal length wing panels (though there is a bit of asymmetry in this one) and no rudder or engine offset. On the rudder, I wanted something that would blend to the top block. Sort of a sexy shape. It's close to an inch wide at the base and a bit under  1/8" at the top, so it has a pretty severe taper. Should make for an interesting look when covered. The structure used was just to keep the weight down. Wish I'd gotten a good picture of it before gluing it on. Sigh...
I weighed the whole airframe today without flaps or gear and it's hovering right around 18oz. That should give me a finished weight for the airframe prior to covering of about 25 or so ounces. That gives an all up weight with drive train but without finish of around 45 oz. And that gives me around a 15oz of finish budget! Man, you'd think even I can keep under that.
« Reply #5 on: August 11, 2007, 10:34:40 PM »
18oz, not bad usually i come in at 18oz when i do a single wing tip **) n~ n~
A.M.A. 820-823
« Reply #6 on: August 11, 2007, 10:41:32 PM »
Steve,
We need to introduce you to the wonder of the X-Acto hollowing tool.   LL~
Offline Larry Renger
« Reply #7 on: August 13, 2007, 08:23:49 PM »
I love how light those flaps are, but how do you plan to keep them from flexing under flight loads?  Got some CF tube buried at the hingeline?
« Reply #8 on: August 13, 2007, 10:49:00 PM »
Hi Larry,
They are thicker than they look in the picture. The core is "C" grain, 8lb. stock, 1/8" sheet. It's cut out in the middle with crossgrain truss installed. Then the ribs are glued to the crossmembers to give vertical stability. There is CF along the leading edge (under the 5/16" x 1/4" cap) on the top and bottom of the core. The ribs are the lightest 3/32" balsa I could come up with (about 3lb stock - been saving that sheet for something like this). It will allow some expansion/compression control in use. The hardwood piece for the control horn is full width also. Trust me, they don't flex much now. When the SGM silkspan is on, they will start flexing about the time that the airframe explodes from flight stress. And best, they weigh about 0.6oz each.
I've done several sets of flaps like this, improving the materials selection, placement and structure each time. Wish I would have built flaps like these on my current PA plane. I tried a different structure with that trying to make them lighter and thinner and they flex pretty badly. But at least they seem to be doing it equally.
Truth is, you don't really need massive amounts of high class, high zoot building material to build a light and rigid structure. Just thoughtful selection of materials and a solid architecture. Judicious placement of carbon fiber and such can help to increase rigidity, but more just weighs things down without much benefit.
I often say before you do something, understand why you are doing it and what you hope to accomplish. As I've done this, more and more I ask myself does this piece of wood, CF whatever, really need to be there. What happens if I leave it out? If I can't answer those questions, I need to cogitate on it some more. In the end, there had better be a good argument on why I'm leaving it in, whatever it is. And what are the tradeoffs. Every airplane is a bundle of compromises between structural rigidity, weight and durability.
Don't get me wrong, I've done plenty of dumb stuff when building, made some structural decisions that led to very dead planes. But I think I always learn something and hopefully do it better next time.
~~~Sorry for the soapbox. This is just something I've been thinking about a lot lately.
« Reply #9 on: August 13, 2007, 11:24:36 PM »
Randy,
pardon me for climbing on the soap box with ya, I think the key is understanding the strength of the material you are working with.(which is what you are saying if I am correctly interpreting, ok so we have talked about this) Im gonna spell it out like I build now, simple,, you say it like you build, eloquent,,,,
the key is to make sure that the line of strength in the material is in line with the stress it is resisting. in other words, the grain direction is the strenght in balsa, by alternating the direction of the grain in a structure, like Randy does with his buildup method, instills strength, and torsional resistance by virtue of the multitude of grain directions in the structure to resist torque. Actually each peice ideally will resist motion in a tension mode since that is where the strenght comes from. hence the warren truss structure is strong because the lines of resistance counter the lines of stress. ,,,,,, Um oh yea, I said I was gonna be simple, I will stop there,,,,,,,
Ok Randy back to you,,,
bythe way, I like the belly scoop mucho better,,
Offline Doug Moon
« Reply #10 on: August 14, 2007, 07:30:05 AM »
Randy,
As usual, outstanding work!!!!!  Now could you possibly show us how you sand that flap to shape?
I have used tapered flaps in the past and have some techniques but I am sure mine are not as precise as they could be.  For this reason I went to non tapered built up flaps.  Straight 1/4" thickness LE to TE.  Makes for strong and light but I like the look of tapered as well.  I really like yours.
Thanks in advance.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #11 on: August 14, 2007, 11:03:51 AM »
Mark,
Yea, the scoop is better. With the gear mock-up I did, I set it on the table and it looks pretty cool. Still messing around with venting (as you can see). I am just short of the 1 to 2 ratio, so it will probably get another vent somewhere back there. I'm using an old differential equation that I picked up somewhere (probably college calculus) to figure areas. Fun stuff tried to measure a couple of those openings.  :)
Along the lines of what you were saying, I suppose I was effected a lot during college by a roomate I had. He was majoring in structural engineering. I helped with the design and building of his project for a bridge contest. You know, the old build a bridge, put it in a press and measure the stress it will take before it colapses? Anyway, he and I did EXTENSIVE reading on various materials and elected to use balsa. I have to admit that I was facinated by the fact that for the weight, balsa had greater compression and tension resistance than most any other material. And we won the contest, by the way, with a Warren truss, tied arch design. I think I still have that design in my mind when I'm messing with things like this.
Doug,
Good question. I think you can see in the picture that the flap standing up is unshaped, the one laying down is ready for final sanding. When I build these things, I lay the core down on a chunk of 3/8" think glass and tack it down in a couple of places with CA. I cut out the ribs, LE and end blocks with the bandsaw. Glue on all that, flip the thing over on the glass and glue on the other side. Then you get the flap that is upright in the picture.
To shape, I use a razor plane with the core as a reference line and plane down the ribs and end blocks using a sort of template to check. There is, admittedly, a lot of eyeballing involved. I use a long, thick ruler I picked up to check the lengthwize taper often.When I get the profile close, I use a long sanding block to bring it down to profile.
If the core is straight and relatively rigid, then it's pretty easy. It takes some touch, but isn't all that hard. I've done enough of these that I can plane off and shape both flaps in a half hour or so. But initially, when I was developing the technique I use, it seemed to take hours to do one flap. It works for me OK.
Hope all that's clear.
« Last Edit: August 14, 2007, 11:25:36 AM by Randy Powell »
Offline Warren Wagner
  • Bradenton, FL
« Reply #12 on: August 14, 2007, 04:51:53 PM »
Randy,
Everything looks superb, as usual.   Is there any problem in keeping the TE of the flaps straight?    They look rather delicate, and possibly prone to warpage.
Need more photos !!
Cheers.
Warren Wagner
p.s.  When do your building classes start??   <g>
Warren Wagner
AMA 1385
« Reply #13 on: August 14, 2007, 06:42:17 PM »
Warren,
Well that goes back to having a relative rigid core piece. That is probably the most scrutinized piece of wood in the whole enchilada. As I noted, I use a piece of "C" grain (in this case) 7lb stock with pretty consistent grain. I usually want a plank for this; something that could be used as a diving board. A lot gets cut away and so, the final weight of the core isn't much. But the structual rigidity of the inherent piece remains. By the way, the grain runs parallel to the trailing edge, not the leading edge. Haven't had any problems with it warping yet, but I imagine that the rib arch helps in that, too.
No building classes for me. I have too tough a time explaining what I'm doing as it is. A lot of this stuff is just accumulation of trying something, having it fail, sometimes spectacularly (read elsewhere about the USA- explosion), going back to look at the plans and figure out what caused the problem, figuring out a way to make whatever broke stronger by rearranding the structure rather than adding more structure (unless absolutely necessary) and trying again.
I'll try to take a couple more pictures of the flaps and elevators. I still have one flap and one elevator to shape. Got sidetracked with a new idea on building with a sort of prebuilt hinge pocket and I wanted to build a quite mockup to see if it worked (I don't ALWAYS try new idea on the actual airframe). Anyway, I'll see if I can take a couple more pictures of the before, during and after shaping.
One of the things that I get, uh, reminded of regularly is that I don't tend to do things half way. I get an idea, I build a full boogie stunt plane with serviceable finish to try out the idea. Probably not very bright on my part since half the time the bright idea is a non-starter. But along the way I get to test out a lot of structural ideas, finishing techniques, etc. And that is never wasted time even if the plane ends up as a hanger queen or parts carcass.
Offline L0U CRANE
« Reply #14 on: August 15, 2007, 11:07:41 AM »
VERY nice, Randy, as usual...
I think Warren W wanted to hear,  - I suspect - that you flip the flap over, rest the core TE on jig pieces, THEN shape the second surface.
If the flap LE height is tapered, the TE jig pieces can match that, too.
Am I close?
\BEST\LOU
« Reply #15 on: August 15, 2007, 01:39:30 PM »
Great Lou, give all my secrets away!  How do you expect me to be mysterious if you tell them everything?  HB~>
Yea, I generally lay it down on the glass, plane then sand it to shape checking periodically with a straight edge (for spanwise taper) and a template for rib taper and, of course, liberal use of the Mark 1 Eyeball.
When I flip it over to do the other side I usually just use some scrap 1/4" plywood pieces up against  the core to keep the finished surface up off the glass and do the other side.  I do the finish sanding lightly by hand. I tooks some pics last night while I was doing the flap, but it was too late to mess with re-sizing so I could post them. Maybe tonight.
One note to all: I wouldn't expect anyone to build the way I do. I've sort of evolved the techniques I use over a lot of years; usually copying someone elses idea, then modifying it to fit what I wanted to do. Sometimes just coming up with an idea. Some things are probably harder than they have to be, but I'm comfortable with them and know I can get things light and straight this way, so I continue to employ such techinques. The hope here to just get folks interested in how they build stuff.
« Reply #16 on: August 15, 2007, 07:18:26 PM »
OK, Warren. Here's a couple of pictures of the flap in progress. The last one is of it temporarily mounted on the plane. (Man, looking at the picture it is really going to need some more sanding). Note the ancient razor plane on the bench.   #^
« Reply #17 on: August 16, 2007, 09:33:39 AM »
Hi Randy,
One thing to consider: with the pipe systems, it has become general practice around here (read that around Randy Smith! LOL!!) to not have any cooling outlets until the pipe outlet at the rear.  For whatecer reason (I don't know, I just do as I'm told! ;D ) Randy had us close up our header cooling holes and all the others.  Now the air flows all the way down the pipe to exit.  And he says that's the only way to do it. ?? ?? ??  I rememer Ted having to put backing in the cowl to close up all those beautiful holes in one of his TPs.
« Reply #18 on: August 16, 2007, 10:56:01 AM »
Bill,
That is generally true unless the whole pipe is hanging out in the wind. If you have exits ahead of the main exit at the rear, the hot air will tend to exit there leaving the rest of the pipe to cook.
I suppose I should have shown a picture of the inside of this pipe tunnel. That section with the scoop is actually a removable cowl. There is a small entry hole in the scoop and an exit hole that is just slightly bigger. There's a slit along the area just over the head of the pipe and some venting that draws most of the air that will intake at the scoop into the pipe tunnel. The exit should just get the air that isn't pulled into the pipe tunnel. I didn't want to have a cul-de-sac at the end of the scoop causing the intake to refuse air. This was a method to allow fresh air to hit the head of the pipe (where it tends to be the hottest); air that hadn't already been heated by going around the engine and header. There are ducts in there that will (I hope) force that new air directly onto the front of the pipe and into the pipe tunnel. Not much air will exit out the back of the scoop. It's also why I wanted to increase the exit area at the rear of the pipe tunnel. I wanted to create a bit more draw to insure that I overcome any residual draw from the small exit at the back of the scoop.
All this has been a progression. In the previous plane, there was only a small entry point for air in the cowl then the exit at the rear of the pipe tunnel. It worked fine, but on really hot days, I would check the pipe and it seemed that it was overheating somewhat right at the front of the pipe near the connection to the header. So I made a similar scoop and started experimenting. This setup seemed to work the best to get some fresh air into the area while continuing to draw to the rear of the pipe tunnel. I suppose a different design that didn't have an exit on the scoop could be done, but it tends to create other problems. At least it did for me with the experiments I did.
If it turns out that the rear of the pipe gets hot, I will probably pull the cowl and block the exit in the scoop. But I think this will work pretty well.
« Reply #19 on: August 17, 2007, 02:31:42 PM »
Well, the control surfaces are completed and on (temporarily at least). I'll try to get the fairings on tonight and start getting the gear built. Once that's done, I do the final sanding and start slopping dope on. I imagine once the thing is in silkspan, it will go in the rack for a bit so I can get my Cobra fixed and refinished. VSC is only, what, 7 months away?
Offline RC Storick
« Reply #20 on: August 17, 2007, 04:36:55 PM »
With all that work I have to ask myself is it worth it? My flaps weigh 1/2 oz sanded and shaped. What do those weigh? Aside from looking kool! Was it worth it?   S?P
« Reply #21 on: August 17, 2007, 04:41:56 PM »
Randy:
I just kinda wish you had made this with an UPRIGHT ingine so you could REALLY show off all that pipe tunnel work!
« Reply #22 on: August 17, 2007, 04:49:22 PM »
Robert,
Believe it or not, they took less work than sheet flaps. At least from my prespective. And they were a lot easier to keep straight. Last set of sheet flaps I did I had to go through 4 different sets before I got a set I was happy with. The wood grain kept tweaking after tension was released cutting them out and planning them off. Sigh. These weight about .4 oz each (the inboard one is slightly lighter than the ourboard unit). And they resist twisting much better than normal sheet flaps and as well or better than built up and sheeted flaps (and lighter than conventional built up flaps). It's a choice, I suppose.
Dennis. Well, there is a set of plans I have...
« Last Edit: August 17, 2007, 11:13:11 PM by Randy Powell »
