  • June 17, 2025, 03:34:52 AM
Author Topic: Vector Tip Weight  (Read 977 times)
Offline ray copeland
Vector Tip Weight
« on: April 16, 2011, 07:55:17 PM »
Trying to finish up my Brodak Vector kit and am wondering about tip weight to start with. My plan was for 1 1/2 ounces, is this too much?   Thanks, Ray
Offline Allan Perret
  • Proverbs
Re: Vector Tip Weight
« Reply #1 on: April 17, 2011, 08:46:21 AM »
I think a good ballpark starting point for 40 size on .015" lines is about 1oz; and for 60 size on .018" lines is about 1.5oz.
But I like to hang model from nose and tail with outboard wing tip on scale and make it heavier by .75oz for 40 size; or 1oz for 60 size.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: April 18, 2011, 01:04:29 PM »
Thanks Allan, 1 ounce it will be to start!
« Reply #3 on: April 18, 2011, 06:23:10 PM »
you may want to do something a bit different, credit Pat Johnston for this super simple idea,,
with the airplane ready to fly ( minus lines) balance it on the spinner and the rudder, put a scale under the outboard tip and then add weight until it actually weighs one ounce. this will make up for any inherent imbalance due to mufflers, heavy wood , uneven finish weights. it will put an actual ounce on the tip.
« Reply #4 on: April 20, 2011, 08:56:12 AM »
Do you take out enough to make up for the glue? LL~ LL~ VD~Just being the real me. H^^I like the idea.
