  • July 06, 2025, 03:16:38 PM
Author Topic: Vector 40 tail moment length  (Read 2753 times)
Offline kevin king
« on: January 19, 2022, 11:54:04 AM »
Anyone know the the correct distance from the wing TE to stab TE? The plans measure  14 3/4" but the fuse sides are cut at 15"
Offline Matt Colan
Re: Vector 40 tail moment length
« Reply #1 on: January 21, 2022, 07:34:46 AM »
I personally wouldn’t worry about it and build it to the length that is cut on the sheet
Offline Dave Rigotti
« Reply #2 on: January 21, 2022, 08:53:20 AM »
When the sides are pulled in at the tail it becomes shorter and then shows what is on the plans?
"Gotta think in 3D"
Build it with the cut parts......
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #3 on: January 21, 2022, 09:00:41 AM »
A 1/4" more or less in the tail moment arm length won't make a difference in a plane that size.  Take the pieces as cut, use the plans as a guide, and make it all fit with a minimum of cutting and hacking of the parts provided.
Offline Mark wood
« Reply #4 on: January 22, 2022, 02:10:53 AM »
Definitely not within the worthy of worry about zone. An inch maybe maybe. Two inches probably. Bottom line, it'll fly just fine like that.
Life is good AMA 1488
Offline Serge_Krauss
« Reply #5 on: January 22, 2022, 03:59:45 PM »
FWIW, I have a wrecked ARF downstairs that measures a little less than 14 5/8". Experience has shown me that plan copies can vary by more than 1% and by different percents in different directions. That's a bit over 1/8" in your dimension. As said, that error wouldn't affect your control feel enough in itself.
SK
Offline kevin king
« Reply #6 on: January 23, 2022, 01:37:14 AM »
Thanks for the replies gentlemen.
Offline Mike Haverly
« Reply #7 on: January 23, 2022, 11:49:48 AM »
You have it lying flat on the plans.  The fuselage sides are not straight, it gets narrow at the rear so it would have to be longer to go around the corner.
