  • June 18, 2025, 03:00:48 PM
Author Topic: Flaps.....  (Read 1101 times)
Offline Terry Bolin
  • Havin' the time of our lives!
Flaps.....
« on: February 02, 2008, 05:00:45 AM »
A good friend loaned me his tapes from Windy on building, triming and so on. I have been playing them while working on scratch building my Chief. On one of the tapes, Windy shows up how he builds the flaps for the Strega. He recommends after cutting the balsa for the flaps to use the grain going at an angle across for the hinge line. (Leading edge). leaving the factory cut for the trailing edge.
Question: What is the reason for that?
I did it that way but wanted to know why.
Offline Dick Fowler
Re: Flaps.....
« Reply #1 on: February 02, 2008, 05:40:42 AM »
Terry, try an experiment. Take a piece of 1/16' balsa approx. 3" wide and maybe 12" long which has the grain running length wise. Take the sheet and grasp it across the 3" dimension and and bend it. The sheet will cup very easily into a partial cylinder. Next take the same sheet from end to end and bend it... much stiffer more difficult to bend.
When flaps deflect, the air pressure strikes the flaps and being supported at the hinge line, they tend to twist and cup if not stiff enough. Getting the grain off of parallel creates and somewhat stiffer structure against that load which helps.
Dick Fowler AMA 144077
Kent, OH
Re: Flaps.....
« Reply #2 on: February 02, 2008, 11:59:03 PM »
It also gives a nicer edge for finishing. Saves some headaches later.
Offline Terry Bolin
Re: Flaps.....
« Reply #3 on: February 03, 2008, 07:26:04 AM »
Makes sense. Just wanted to know why we should do it that way. I'm not the kind of guy who "just does", I gotta know why!
Thanks guys.
