  • July 17, 2025, 10:46:29 AM
Author Topic: Vacuum forming for CL stunt  (Read 6144 times)
Offline Donald R Olson
« on: May 03, 2025, 12:08:54 PM »
I’ve been experimenting with 3d printing and vacuum forming for a few years now. I think I have it down really well. I showed some pics to Paul Emmerson, Circuit Flyer / Climb and Dive creator. He suggested I post some info on how I’ve been doing this here on Stunthanger. Paul’s timers are great by the way. They’re all I use anymore.
Unfortunately, the DYI vacuum formers that use a shop vac really can’t draw good enough to produce good quality results. I built this machine back in 2020. There are plans available online for sale of a very similar machine. I didn’t buy them, but I took a good look at it and adapted the design to fit the parts and materials I wanted to use.  I 'll go into how I make the bucks using a 3d printer in the next post. I want to see if I am getting the pictures attached before I proceed.
Re: Vacuum forming for CL stunt
« Reply #1 on: May 03, 2025, 12:34:13 PM »
Here is the latest plane I’m working on. It has several vacuum formed parts. The cowling, top and bottom hatches, and the canopy / turtle deck. All of then have been formed on bucks I 3d printed.  Next post I'll show the 3d printed bucks and some pulls.
« Reply #2 on: May 03, 2025, 01:19:15 PM »
Here’s a solid canopy in case I decide to go without a pilot. The next is the cowling buck. When 3d printing bucks, they need to be able to stand up to the heat and pressure of vacuum forming over it. These bucks have 8 side layers and 10 top layers. If you plan to form clear parts, the buck has to be perfectly smooth. If there is even a tiny line in it, it will show in the clean plastic. PLA or PETG are difficult to sand perfectly smooth. To make it easier, I sand the buck to get a lot of the layer lines out with 60 and 80 grit on an orbital sander.  Then I form oner it with .020 HIPS (high impact polystyrene). Then I will glue that to the buck. Then sand it smooth with 240, 320, and 400. The HIPS sands faster and cleaner than 3d print filament.  Also note the small holes in the areas that have a tight angle. I'll post more later, with a little more advice on how to make a successful buck and what are the best materials to use.
Offline 944_Jim
« Reply #3 on: May 03, 2025, 01:21:17 PM »
I want to know more about your vacuum table. I spy a vacuum pump and an air compressor tank...are you using the tank as a vacuum reservoir for a quick, hard pull-down?
Is the "up" position enclosing heater elements or hot bulbs so that you heat to visual observation of "sag," and then you pull the plastic down over the buck?
Can the table be converted to "bag and capture" resins from fiberglass work? Or is this all "plastic pulls?"
Slack-jawed however you do this...Bravo!
« Last Edit: May 05, 2025, 08:08:20 AM by 944_Jim »
Offline CircuitFlyer
    • www.circuitflyer.com
« Reply #4 on: May 04, 2025, 07:50:27 PM »
That's an impressive machine and awesome work. How many inches Hg of vacuum can that pump attain?  I'd like to hear more of the details about the materials you have found that work the best.
Paul Emmerson
« Reply #5 on: May 04, 2025, 07:58:34 PM »
I can show some pics from when I built it. It has a vacuum pump connected to an air tank salvaged from an old air compressor. The tank allows the vacuum to be built up and stored, then it is able to pull the air out quickly. It has enough volume to evacuate all the air even on large pulls.  The heater is a series of nichrome wires. They are arranged into 4 zones.  This allows you to only heat the center and expand outward up to the full 4’ if your pull is that big. It can accommodate sheets as small as 8” x 8”, or as large as 24” x 48”.  There is a vacuum regulator that I bought from machine surplus, Next Day Automation. They are online.  You’ll notice that the platen has one large hole in the center. It doesn’t have a bunch of small holes drilled all over the surface of the platen. This has several advantages. First there is no chamber below the platen that needs to be evacuated. The buck is placed on a piece of window screen or raised off the platen by blocks or washers.
Online Brent Williams
« Reply #6 on: May 04, 2025, 08:07:50 PM »
Very nice work. What are the weights of those formed parts?
HIPS (high impact polystyrene) is around 66lbs a cubic foot.
« Reply #7 on: May 04, 2025, 09:06:58 PM »
The sheet is squeezed between the top and bottom frames. I use HIPS, High Impact Polystyrene for solid parts. PETG clear is what I use for canopies and other parts. Other materials that can be thermoformed is ABS and many types of acrylics, Lexan is a brand name of another clear material. HIPS is by far the easiest and most forgiving material I've found. It's pretty tough, but not as tough as PETG or others but it makes good-looking parts. It sands well, glues to wood with CA with an excellent bound, and paint will stick to it. It's commonly available from plastic suppliers. It is available in black and white, in thickness from .020, .030, .040, .060, .100, and .250. Any thicker than that and it’s not going to pull down.  .250 would be a difficult time getting it to come out. The pump will pull 29 inches Hg of mercury, but I usually set it to 25 inches Hg of mercury. It pumps down to 25 inHg pretty quickly but to get that last 4 inHg doubles the time it takes. The machine has a valve and a port on the side to allow vacuum to be tapped to use for vacuum bagging or other purposes. I have a YouTube channel I used to do but I haven’t posted in a few years. It has safety and operation instructions for this vacuum former. I made it for members of TC Maker to be able to use the machine. I will post a link.
Since I made that video I change a few things. The main change is I removed the solenoid valve and replaced it with a ball valve. That way you can vary the speed that the vacuum is applied. This is necessary because different thicknesses and materials require different pull rates.
On my YouTube channel there is even a video of the first vacuum former I built probably 10 years ago.  I will soon post more on how I design the bucks and how parts compare in weight and strength compared to balsa or other materials use to build stunt planes.
Offline 944_Jim
« Reply #8 on: May 05, 2025, 08:06:45 AM »
Thanks so much for the details!
I hope to build one about the size of a shoe box (I fly 1/2A). Your notes provide enough detail so I can replicate in miniature. I hope to use a freon or propane tank for my vacuum storage.
Given the size I hope to build, this places my heated size no bigger than a large counter top toaster oven.
« Reply #9 on: May 17, 2025, 05:41:53 PM »
Very impressive
« Reply #10 on: May 17, 2025, 07:00:09 PM »
     Those parts look amazing, I would never even try to do anything like that!
     While I know other people who have success, I have had nothing but frustration trying to vacu-form things, or even work with pre-made parts. As you note, the home job systems are generally awful and I don't have the space to make a dedicated machine.
    What always frustrated me when making parts or complete models using vacu-form is that the parts, at least those made from styrene, tended to fail or split along stretch marks or grain lines. Is that just because it's styrene, or is there some other issue?  Some rocket kits back in the late 60's/early 70s were nearly impossible to build as supplied just because every time you tried to cut out, glue, or bend the  vacu-form, it would split or the cut would take off in another direction.
« Reply #11 on: May 21, 2025, 11:47:13 AM »
It took a while for me to get back to this post, but I did get to weighing some of the parts. I really don’t have a way to compare to other similar parts, but others out there probably can compare to past experience from their own builds. I’m posting some pics of the parts on my scale and I will list the weight in OZs and grams.
Cowling: 19.5 grams or .68 oz. This includes a 1/8 thick x 5/32 wide plywood nose ring glued in place.
Lower hatch: 48.5 grams or 1.71 oz. The hatch has a 1/8 plywood frame glue inside it. I could of used light ply or balsa to make the frame lighter but I wanted it to stand up to a lot of punishment. I’m pretty clumsy in the field and don’t want it to break.
The top hatch: 12.5 grams or .44 oz. It has no framework. It screws to the fuselage and will only be opened if I need access to the ECS.
The canopy/turtle deck: 26.9 grams or .94 oz. This is large as canopies go. It’s about 26” long.
The cockpit and pilot: 9.3 grams or .32 oz. It’s been painted and the helmet has a 1/8” wood dowel glue into it so I can turn the head side to side. I still need to print a decal with gauges.
« Reply #12 on: May 21, 2025, 12:46:47 PM »
Another thing to keep in mind, when these parts are painted there is no grain to be filled. It usually only needs a single coat of primer. There is no primer on the pilot/cockpit.
I haven’t had any issues with cracking or grain lines. If you try to use too thin of material it will tend to crease or crack, but for the most part I haven’t had that happen.
The material I like to use best is High Impact Polystyrene (HIPS). PETG is good as well. PETG is tougher. It is hard to crack it. Locally it is only available in clear. It doesn’t pull as easily as HIPS. It has a smaller temperature range to get the best results. HIPS isn’t as tough, but it sands easily and is very forgiving with forming. Both materials have a much greater tensile strength than balsa parts. It glues to balsa and ply with CA and has a good bond. I find that most parts can be pulled from 0.030 or 0.020 thick sheets. The hatches and canopy are all pulled from 0.030” stock. The pilot is 0.020. The cowling was actually 0.060. It is a tall part to pull. By the time it is pulled, it’s around .020” thick at the base. It’s more like .035 at the top. It was a challenge to get it right. I started with .040 stock, and it would web badly. Once I got it dialed in, I was able to make multiple cowls. The buck is taller than the finished part. This is because when the part is taller than it is wide the plastic sheet will tend to web in the corners. This is because the sheet stretches when it is first pulled over the buck. When vacuum is applied there is too much excess plastic. As it is pulled tight to the buck the material will fold. If the buck is taller than the finished part the webbed portion can be trimmed off. It was a learning experience to get quality parts. I found a lot of good information on the internet and trial and error. Now I feel I can produce quality parts. I’m working on making them lighter. In a future build I am going to do an all HIPS skin with a laser cut balsa skeleton. The trouble is I have a least 5 designs I want to build that are more conventional construction. I’ve gone on way too long for this post but if anyone wants to know some good points on how to 3d print the bucks I can ramble on that too.
Offline 944_Jim
« Reply #13 on: May 21, 2025, 03:45:03 PM »
Yes, please. I feel like I'm back in school. I'm learning a lot and hope to leverage all of this!
Thanks so much for taking the time to share.
« Reply #14 on: June 01, 2025, 02:57:56 PM »
I can go into some detail on the way I’ve been making my bucks. For it to make sense I will start with a few key points on vacuum former design.
First a couple of terms used in vacuum forming: A buck is the form that the plastic is pulled over to create the part. The platen is the base the part sits on, and the vacuum is drawn or pulled through it.
I mention this because most home built vacuum formers use a platen with multiple holes drilled over the surface of the platen and a box below it to distribute the vacuum across the whole surface. This design has a drawback. The entire volume of air must be evacuated from the box below the platen surface. This wastes a lot of the vacuum you have accumulated before you even start to pull your part. Another disadvantage is, it is set at one size and requires a lot of fabrication to make a platen for each size you want to pull. Being able to use different size sheets is important.
So, what is a better design for the platen? A solid platen with only one hole in the center.  If you look at some of the previous pictures you will see the single hole in the center of the different sized platens. Some of the advantages: Different size plates can be cut from a piece of MDF on a table saw. A hole drilled in the center, fitted with the appropriate fitting to connect to the vacuum source. Plus a gasket around the perimeter is all that's need to make the platen. It is much easier and faster to make. Another is, as I mentioned before, there is no airspace to be evacuated.
 I went into all that because it affects the design of your buck. For it to work, the buck must be lifted off the surface of the platen. One way to do this is to place the buck on top of some washers. Or glue some popsicle sticks to the base of the buck. This will lift the buck off the platen to allow air to be drawn out and the plastic sheet pulled tight over the buck. If you are 3D printing the buck, just add some feet to do the same thing.
I model the entire plane in fusion 360. I use the free version. From there I can make STL files to 3D print. Below are some screen shots of the Gee Bee R3 I’m currently working on and some of the bucks I printed.
« Reply #15 on: June 01, 2025, 04:04:18 PM »
So, for a 3d printed buck to stand up to the heat and pressure it will be subjected to, there needs to be some changes to standard slicer settings. The surface of the buck comes into direct contact with the hot plastic sheet. It is also under high pressure as the plastic is pulled tight over the buck. PLA becomes pliable at temperatures close to that of HIPS and lower than the temperature of PETG. If you use the default of the slicer program the buck will deform in as few as 3 or 4 pulls.  Also, what type of filament you chose makes a difference.
PETG is better at standing up to the heat and pressure as it has a higher melting temp.  It is also harder to print and sand. PLA is much easier to print and to sand the print lines out before it can be used. With the right settings it can be used quite well.
The changes to settings are to increase the number of walls, the number of surface layers and to increase the percentage of infill. I change the number of walls from 2 to 8 or 10. I change the top layers from 5 to 10-15 layers. Infill should be 20-25%. Also, if you look close at the cowl buck pictures, you can see I put in small holes through the buck to get the sheet to pull tight into the square angles. I also hollowed out the buck. This gives you more side walls to stand up to the pressure. The through holes do more than allow the plastic sheet to be pulled tighter into the corners. It also acts like internal columns that stiffen the top surface. With the layers and walls thickened, it is much stiffer, and the buck can dissipate the heat before it deforms.
« Reply #16 on: June 01, 2025, 05:48:10 PM »
When your buck is too long to be printed in one piece you must join multiple sections.  Add dowels in the buck so it will fit perfectly in line and glue it together. As you can see in this picture below, the layer lines must be sanded out. This buck it printed from PETG. It was difficult to sand out the layer lines. I wanted to form it in clear PETG. To do that the buck must be perfectly smooth. Even the smallest scratch or pin hole will show in the clear PETG. If you sand the buck down to 240 it will be fine for HIPS or other solid materials. But for clear you should go down to 400 or even 1000 grit. The trouble is the 3D printed buck might never get that smooth. You can try filling it with wood filer or a body filler like Bondo. It is a time consuming step and sometimes doesn't always work the best. So, a trick I found is to sand it down to about 240. Then pull a HIPS skin of 0.030 over it. Then use CA to glue the skin you just pulled to the buck. Then the skin can be polished as fine as you want. The better you smooth it out the better the glass area of the parts will look. To get a nice tight corner there needs to be vent holes. If you don’t have them, it will have a radius in the corners. The holes should be 1/16” or a little less. If the hole is in the corners, it won’t show in the final part.
One last thing, instead of washers or popsicle sticks you can place a piece of widow screen under your buck. Also, you can use plastic toys and cut out the parts you want to recreate. I found a speed boat toy at a thrift store. I cut out the body and helmet to make bucks out of. If you want to reproduce a buck, you can do it fairly easily. Pull a part from the buck you want to reproduce. Then fill the part with Durham Rock Hard. It’s like Plaster of Paris but tougher. It’s available at most home improvement stores. Once it’s dry you have a copy of the original. You can cut it or modify it if you want.
Next time I will write about webbing and under cuts.
Offline 944_Jim
« Reply #17 on: June 01, 2025, 09:27:35 PM »
Mr. Donald,
Wow! This is good stuff. I never considered the volume UNDER the table as a "void that must be sucked." It makes perfectly good sense that this is wasted volume.
I'm printing these notes for when I build mine.
Could I trouble you with a few direct questions? I figure you may be able to answer most succinctly as you have worked around various issues I am sure to encounter.
I want to make left/right fuselage bucks of the Gee Bee R1 based on the Gen Dubois or Paul del Gatto (at half-size) for 13" or 14" WS, respectively. I want wood tail and wings, with a wood frame, and plastic or molded balsa skins formed over the bucks and then applied to the wood frame. I hope to make only one copy of this model, so buck durability isn't a big issue. I do have access to a 3d router (a BIG one at work, and one sized like the run-of-the-mill 3018 machines at home)
Q1: What software is needed to take the fuselage bulkheads and keels in to develop the digital 3d form to be sliced later?
Q2: Would it be better to create a negative mold to fill with Plaster of Paris or Duram Rock Hard for a less heat sensitive and more durable buck?
Q3: I imagine I could take the digital 3d model and slice it to feed into the 3d router and cut blocks of pine, MDF, or other woods. What do you think about this way to create the bucks?
Lastly, what 3d modeling software can take my digital parts to render a virtual assembled model...and hopefully show conflicts in material occupying space by more than one part?
The first three questions are numbered because they are most important to me right now. The last one isn't since I'm more concerned about roughing out a few parts now
Thanks in advance,
« Reply #18 on: June 02, 2025, 08:48:12 AM »
Thanks in advance,
Your first question is a good one! I use the free version of Fusion 360. It's a great 3D modeling program, but it is complex. If you have drafting experience it will help and 3D modeling experience is even better. It took me 2 years of playing with it to really get good at modeling entire airplanes. I had drafting experience and was a machinist for many years. But it was still a steep learning curve. It is a great source though, you can export STL files to 3D print and it can create the g code to run your 3D router. It will also make files to cut your balsa and plywood parts on a laser. There are a lot of tutorials on line and also some threads on Stunt Hanger. To create the buck you will need to model the bulkheads, Then loft the fuselage between the bulkheads. To get the loft to conform to the outline of the fuselage shape you want you need to create rails. All this probably makes no sense without having it in from of you.
Q2 You could start with a negative mold but to 3D print it would be problematic. Size restrictions of 3D printers as well as finish sanding could be a issue. But I've found it simpler to make the form as a positive buck. it will stand up quite well if you increase the wall thickness.
Q3 If you have access to a 3D router, bucks can be cut from Pine or MDF. MDF makes good forms because it is porous. The sheet will draw down well to small details. It is easy to machine. But you need to take care with them as the material is soft and can be dinged easily. if you mar the surface it will show in your part.
Q4 As I was saying before, The entire plane can be modeled in Fusion 360. I wish we were closer together I would like to help you model this project. There are so many tricks I have learned over time, too many to try to explain on line. There are many advantages to modeling vs 2d design. As you mentioned conflicts or interference of parts. One great thing is the tolerances are so tight. If you have access to a laser cutter you can literally make your own kit.
Another thing to think about is that if you 3D print a buck, a little modification and it goes from a vacuum forming buck to a mold to form balsa skins over. I've done this on a couple planes. It really makes a great form for that. if you model the bulkheads and cut them from your model, the skins formed this way will match perfectly. As you get into working on the model please feel free to contact me. I will try my best to help with any questions.
