  • July 04, 2025, 08:27:09 PM
Author Topic: Vacuum Bagging Molded Balsa  (Read 2773 times)
« on: March 28, 2011, 02:35:31 PM »
I had some molded balsa parts to make that have flat sections.  Ace bandages only put pressure on the curved parts, so I tried vacuum bagging.  I have bagged a bunch of composite parts, using the bag to provide pressure while the epoxy cures.  I hadn't tried it with wet balsa.  I wondered whether the balsa would stay wet or the water would vaporize.  I bagged my fuselage bottom at 20 in. Hg for three days.  I just took it out of the bag.  It's still wet.  I'll give it a couple of days with the Ace.
Re: Vacuum Bagging Molded Balsa
« Reply #1 on: March 28, 2011, 03:37:55 PM »
That simple, build a cylindrical fuselage.
« Reply #2 on: March 28, 2011, 03:40:09 PM »
But really, why not use a combination of ace bandages and weights on a flat surface.
I have some very flat and polished granite scraps. The shipping may kill you though. ;D
« Reply #3 on: March 28, 2011, 03:59:07 PM »
I think you'd have to bring the pressure down enough so that you boiled the water out of the balsa (without crushing it), or use vacuum + heat, or figure out a way to pull a vacuum but get airflow.  None of these seem to be easy to me, although the vacuum + heat method might be doable with little more than the right bag material and a day in the kitchen when SWMBO isn't home.
If you could pull a vacuum and heat it up to 200 degrees F or whatever "wood bending" temperature is, you should get a better "mold", too.
At 20 degrees C (roughly room temperature) the vapor pressure of water is around 2.3kPa -- compare that to atmospheric pressure of about 100kPa.  So at room temperature, to boil off the water in the balsa, you'd need to pull well over 29 inches.  Even then, you'd only be just starting to make things boil, and who knows what water's affinity for wood does to the boiling point?  You may end up squeezing more water out of the poor wood than you do boiling it off.
Bake things at 100C, and the vapor pressure of the water goes up to atmospheric -- so to get the stuff to boil off, you only need to pull a nominal vacuum.  This means either:
  • you can pull whatever you want to get the molding to work, or
  • you'll dry that sucker out so bad it'll turn to dust when you let it cool.
Unfortunately, it looks like you have to get pretty close to 100C to start seeing real effects, because the vapor pressure is a mostly exponential function of temperature.  See:
http://en.wikipedia.org/wiki/Vapour_pressure_of_water
« Reply #4 on: March 28, 2011, 04:53:21 PM »
I have only seen C-grain granite, which didn't bend very well, even when wet.  It doesn't require much filler, though.
« Reply #5 on: March 28, 2011, 08:05:56 PM »
Could you vent your vacuum form to a cavity stuffed with silica gel packets? Alternate idea...there's a beaded product that goes into a plastic dehydration bowl thingy...maybe easier to pack into the form. Any FM or hardware store should have it.  S?P Steve
Edit: Another idea just whacked me in the noggin. You can buy an electric powered doodad that is supposed to keep your boat dry, etc. It's cylindrical, and has a 110v. cord out one end. I have no idea how it works, but I saw it in the Cabela's cattledog. This is more your speed, Howard! Technology that is a puzzlement...perfect!  #^
Here it is, in all its glory. Apparently a convection heater.  Have you considered a controlled air leak, to get some airflow through the length of the molding?
http://www.cabelas.com/product/Golden-Rodreg-Dehumidifier/733530.uts?Ntk=AllProducts&searchPath=%2Fcatalog%2Fsearch.cmd%3Fform_state%3DsearchForm%26N%3D0%26fsch%3Dtrue%26Ntk%3DAllProducts%26Ntt%3Ddehumidifier%26WTz_l%3DHeader%253BSearch-All%2BProducts&Ntt=dehumidifier&WTz_l=Header%3BSearch-All+Products
« Last Edit: March 30, 2011, 08:25:26 PM by Steve Helmick »
Offline Russell Shaffer
« Reply #6 on: March 28, 2011, 08:24:05 PM »
The beaded stuff is sodium chloride, I believe.  Anyhow, it is quite corrosive to metals, but I don't guess it would hurt the balsa too much.
Russell Shaffer
Klamath Falls, Oregon
Offline jose modesto
« Reply #7 on: March 29, 2011, 05:40:59 AM »
Howard i have tried the wet balsa in the vacuum bag with no success. The wet balsa and the mold buck with ace bandages work great on Impact,SV22 and Saturn. The flat parts of fuse hold down perfectly.
Photo#1 Molded balsa shell
photo#2 SV22 fuse
photo#3 wet balsa ace bandage over fuse buck
photo#4 composite wood and carbonfiber SV22 And Impact fuse. NOTE:The two fuselages are molded balsa composite
Jose Modesto
« Reply #8 on: March 29, 2011, 10:20:45 AM »
Not much filling and no warping. It is a little on the heavy side though.
Offline Steve Fitton
« Reply #9 on: March 29, 2011, 11:10:59 AM »
Wonder if there was a way to mill the granite down to shells just some tiny fraction of an inch thick, just to say you have a granite plane....!
« Reply #10 on: March 29, 2011, 01:02:02 PM »
I thought about taking the CAD drawings of my plane and making table tops on the CNC. It would be like having stone age plans of my plane. I will start taking orders now! ;D
If you could get the granite that thin without breaking it would look awesome, at that thickness almost all granite is translucent.
« Reply #11 on: March 29, 2011, 06:01:25 PM »
Howard,  if you are using contest grade balsa,  you don't need to wet the wood.   The atmospheric pressure is enough to form the wood to what ever you are using for a mold pattern.   Just look at what happens to a metal can when the air is pulled out of it.
« Reply #12 on: March 29, 2011, 07:34:08 PM »
What keeps it there when you release the vacuum, though?
Offline Kim Mortimore
« Reply #13 on: March 31, 2011, 06:53:32 PM »
Howard,
Why wouldn't it work simply to add dry pieces of scrap balsa on top of the flat areas for the ace bandage to press against?
Kim Mortimore
Santa Clara, CA
« Reply #14 on: April 03, 2011, 05:55:18 PM »
Three days in the vacuum bag and three days with the Ace did the trick.  Flat parts are still pretty flat.  Next time I'll put silica gel in the bag or use Kim's trick with the bandage.
