  • July 03, 2025, 06:34:07 AM
Author Topic: Using Nitrate  (Read 1107 times)
Offline James Mills
Using Nitrate
« on: December 01, 2007, 09:01:01 PM »
I'm thinking about using Nitrate for the base on my next plane.  It's going to be a built up wing, at what point do you switch to butyrate?  I've read one or two articles where they said they used the nitrate to shrink the silkspan.
James
AMA 491167
Re: Using Nitrate
« Reply #1 on: December 02, 2007, 01:56:45 AM »
I use 2-3 coats of nitrate on the wood before silkspan, then for the first 3 coats over the paper. Sticky stuff. Makes a good base for whatever you want to put over it.
Re: Using Nitrate
« Reply #2 on: December 02, 2007, 10:21:47 AM »
I apply nitrate to everything except the open bays.  I use nitrate as the entire substrate and for attaching the covering.  I also use the nitrate to begin the filling process on the solid wood areas.  I use Sig Supercoat (high shrink) clear to shrink the open bays, then go to Sig Lite Coat (low shrink) all over for the rest of the clear.
