  • July 06, 2025, 10:45:13 PM
Author Topic: Ultra kote  (Read 1471 times)
Offline John KruziK
Ultra kote
« on: December 15, 2009, 08:15:33 PM »
Will ultra kote stick to wood filler, and or spackle? I'm using ultrakote on wings and tail ,dupli color on fuse. Should  fillets be done after covering wings? Thanks John
AMA 874027
Offline Leester
Re: Ultra kote
« Reply #1 on: December 16, 2009, 03:10:11 AM »
I usually put fillets in then cover, but don't put the covering over the fillets. I paint about a 1/4" or so onto the covering, the covering should stick to both you mentioned as long as it's a flat or outside type of curve. This is UltraKote and Krylon.
Leester
ama 830538
Offline Don Curry AMA 267060
Re: Ultra kote
« Reply #2 on: December 16, 2009, 10:58:59 AM »
I use  mostly finishing epoxy and micro balloons as a filler for fillets and Red Devil light Spackle for finishing. It sands really nice and then cut a strip of Ultracoat wide enough to cover the fillet and slightly beyond on both sides and iron it over the fillet with a trim iron. The cover up to the fillet on both the wing and fuse.
Re: Ultra kote
« Reply #3 on: December 16, 2009, 11:05:46 AM »
I normally cover the wing Out of the fuse, then install, make the fillets and paint. This allows the fillets and paint to seal the inboard edge of the covering. I think it makes a more attractive and durable junction personally
Re: Ultra kote
« Reply #4 on: December 17, 2009, 09:18:15 AM »
Definitely what Mark said for me!  Makes the best fuel proof joint IMHO
Will
Offline Michael Boucher
Re: Ultra kote
« Reply #5 on: February 21, 2010, 01:08:26 AM »
Hi Mark, You put fillets on top of a wing covering?  I'm trying to figure out what folks are doing, thanks.
AMA 59633
