  • June 17, 2025, 02:15:43 AM
Author Topic: Profile fuselage laminating  (Read 1082 times)
Offline Fred Quedenfeld jr
« on: September 08, 2019, 12:06:59 PM »
So you have your 2 stiff 1/4 inch pieces
and you use epoxy to put them together
How much do you scrap off
Do you thin the epoxy to get it to flow
How do you keep the weight down
thanks
Fred Q
Offline Jim Hoffman
Re: Profile fuselage laminating
« Reply #1 on: September 08, 2019, 12:25:50 PM »
 How much do you scrap off - scrape with a credit card till it is not shiny
Do you thin the epoxy to get it to flow - not required, but heat gun works
How do you keep the weight down - the process described is extremely light
