  • July 08, 2025, 06:30:33 AM
Author Topic: Trailing edges  (Read 4873 times)
Trailing edges
« on: November 12, 2015, 07:38:58 AM »
In the 1/2A section there was mention of trailing edge warping.  You should have seen the trailing edge on the Vagabond wings after I removed them fro my trusty angle iron.  All I had was the top and bottom sheet on.  I've seen a baby draw a straighter line.   Did not take a picture as I was disgusted.  So the old gray matter kicked in and said no problem.  Grabbed the Windex spray and literally drowned the balsa.  A couple of aluminum bars top and bottom clamped and tape.  Let set for several days and removed them.  Can now use the trailing edge to draw a straight line.   The trailing edge cap strip added and sanded.   Would you believe they are still straight.  Will add pics later of sanded wings with the tips on.   Tom may skin me when he sees what I've done to his design.
Well here are the wings that need some more sanding.   Making template for the fuse.
« Last Edit: November 12, 2015, 03:44:41 PM by john e. holliday »
Re: Trailing edges
« Reply #1 on: November 17, 2015, 02:31:48 PM »
The wing panels are sanded waiting for the flaps.  Got Stab/elevator cut out.  The base fuselage is together.   The bell crank platform is in with the bell crank attached.   SIG 3 inch with 4-40 ball links.
Offline Paul Wood
Re: Trailing edges
« Reply #2 on: November 17, 2015, 04:05:09 PM »
That is exactly what I do and it works great. I used to use ammonia and water, but Windex with ammonia works just as well.
Offline Chancey Chorney
Re: Trailing edges
« Reply #3 on: November 17, 2015, 05:25:20 PM »
Glad to see you got your trailing edge straight. I will take the advice of how you straightened yours and possibly apply it to mine. But I just have to ask one question. Did you use CA on your wing or carpenters glue? I am just asking as I have switched to carpenters glue and think that it may undo the joints, but the other one is together with CA. Thank you.
Offline Ken Burdick
Re: Trailing edges
« Reply #4 on: November 17, 2015, 06:38:11 PM »
yah.
Built a WDZ wing out of 1/32 wood....looked like a prop. Did the same with plain water and it worked fine
Re: Trailing edges
« Reply #5 on: November 17, 2015, 10:50:23 PM »
I use Elmers Glue All in 90% of my building.   Have to have straight flat bars taped and clamp.  Let set for several days if its humid.   Got flaps cut and all hinge joints first coats of dope for cloth hinges.   Haven't told Tom yet, but went with 3/16 for the flaps.
Re: Trailing edges
« Reply #6 on: November 20, 2015, 09:19:35 AM »
Well I did another change from Tom's plans.  Got ready to cut flaps.  He calls for 1/4 inch balsa.   I guess I sanded the trailing edges too much and 1/4 was too thick.  So I grabbed a piece of 3/16 that was laying in the pile.  Sanded and doped all hinge sufaces.  Also cut a stack of cloth hinges.  Used the 1/4 for the stab/elevator.   This is where I'm at on the wings.
Re: Trailing edges
« Reply #7 on: November 25, 2015, 05:11:09 PM »
Well I finally cut the struts today and had to see what it would look like.   Got the old Fox installed yesterday.
Re: Trailing edges
« Reply #8 on: November 25, 2015, 05:16:49 PM »
Forgot to addthis.  Went to hobby shop for the top block.   They had nothing even close.   So out comes the scrap box.  Had piece of 1/2 by 2 and some 1/4 inch.  Width of fuse is 2 1/4 inches.   Sliced up the 1/4 and glued to the 1/2.    Should work as most of the inner area will be removed except for where center strut goes.
Re: Trailing edges
« Reply #9 on: December 01, 2015, 06:46:55 PM »
Worked on tail skid and hooking up bottom wing.    I may make another tail skid with a wheel for paved surfaces.  It is replaceable.  By the way that is the push rod for the flap under the fuselage.   Can't believe it came out right length when I put it in the fuse.
Re: Trailing edges
« Reply #10 on: January 12, 2016, 11:18:20 AM »
Well this is where I'm at on the Vagabond.  Can't believe I'm so slow on this.  Spent time yesterday fitting the muffler.  Also need to work on the nose of it.  Not that many years ago this would have been ready to fly.   Also that new covering from the fabric store is starting to come around.  Takes more dope than regular poly-span.   But you can see where I have put the poly-fil,  not the craftsman as some on here are.  Guess I should weigh what I have, but it feels light to me.
