  • July 17, 2025, 03:11:53 PM
Author Topic: Tom Morris Bell Crank Set Up  (Read 3980 times)
Offline Phil Goldberg
  • Just completed this PDK Buster 45
« on: March 05, 2017, 06:33:35 PM »
I recently purchased a Tom Morris 3/16" x 4" Bell-crank.  It came with a post, materials for wrapping ends etc.  In the kit there is some silicone tubing and two wheel collars  with set screws.  Can anyone describe the set up for these bell-cranks?  Am I to assume that the collects are for either side of the bell-crank to keep it centered.  Also do I just trim the shaft and epoxy it into place in the bell-crank supports?   Thanks, Phil
« Last Edit: March 08, 2017, 09:10:37 PM by Phil Goldberg »
Re: Tom Morris Bell Crank Set Up
« Reply #1 on: March 05, 2017, 08:32:32 PM »
I've bought some Morris stuff.
He gives you a variety of options to fit your project.
I don't ever use the wheel collars, but rather box the bellcrank into the structure.
« Last Edit: March 06, 2017, 07:27:02 AM by Paul Smith »
« Reply #2 on: March 05, 2017, 09:37:40 PM »
This may help...
« Reply #3 on: March 06, 2017, 09:19:14 AM »
Set up the lap top so I could hear what's being said.   He didn't say anything about grinding a small notch in the wire to set the screws into when you tighten them.  I some times have to add a washer or two to take up any slack between the bell crank and the wheel collars.  I also ditch the tubing and add washers to center the bell crank.  Also after it is installed I put something top and bottom over the ends of the 1/8 inch rod so it can't move vertically.  Lost a good plane as the post slipped out of the ply piece.  Hope this helps. H^^
« Reply #4 on: March 06, 2017, 09:54:34 AM »
Thanks much for all the help.  Perfectly clear now.  Phil
Online Motorman
« Reply #5 on: March 06, 2017, 09:01:57 PM »
blank
« Last Edit: March 06, 2022, 09:13:16 AM by Motorman »
Offline Dave Evar
« Reply #6 on: March 08, 2017, 04:57:03 PM »
Here a couple of pix of my installation in a Brodak Cardinal profile wing.
Top and bottom views.  The 1/6" ply, top and bottom, to position
the 1/8" bellcrank pivot during installationon the ribs before the balsa sheeting,
notched into the two center 1/4" ribs.  (full body fuse)  After sheeting the wing
I put another 1/8" piece on top and bottom after putting the wing in the plane.
Hopefully this helps.
Brooklyn OH
North Coast Control Liners   Find us on Face Book
Bean Hill Fliers, Albion PA Akron Skymasters Control line Association  Gone, but not forgotten.
