  • June 18, 2025, 04:42:08 AM
Author Topic: Why engineer when you can over-engineer?  (Read 3072 times)
« on: August 13, 2014, 08:01:22 PM »
This is for a "quick and dirty" test pig.  Two machined pieces of aluminum, screwed & glued onto a phenolic bellcrank, with a shaft pressed through the middle.
Is there an over-engineers anonymous?
Re: Why engineer when you can over-engineer?
« Reply #1 on: August 13, 2014, 11:14:16 PM »
Tim,, if there is,, you should know being the president and all,,
of course Randy and Pat might argue I am vice pres ( though I have learned)
« Reply #2 on: August 14, 2014, 09:49:28 AM »
Doesn't look extreme to me.  A thin phenolic bellcrank doesn't have enough bearing surface to last very long.
I would have done the same.
F.C.
« Reply #3 on: August 14, 2014, 03:19:15 PM »
Hey, after losing a plane to a under-engineered bellcrank, I want one I can lift my car with.
« Reply #4 on: August 14, 2014, 03:36:14 PM »
F.C.
I was also trying to achieve a bellcrank that wouldn't rock.
Offline Phil Krankowski
« Reply #5 on: August 14, 2014, 05:58:18 PM »
Elegant actually, definitely not a brick outhouse.
Phil
Offline Steve Fitton
« Reply #6 on: August 25, 2014, 09:38:28 PM »
For a disposable test plane, why not a top flite 3 inch nylon bellcrank?  The one you made looks ready for a Nats plane.
« Reply #7 on: August 25, 2014, 11:42:27 PM »
I wanted a four inch.  I have several 3" ones -- but I wanted 4".
« Reply #8 on: August 26, 2014, 10:35:12 AM »
Well, Tim, I have a grossly over-engineered carbon fiber bellcrank I make. I could send you one of those.
