  • June 18, 2025, 11:04:32 AM
Author Topic: best way to cut spar notches in foam wings?  (Read 2857 times)
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« on: November 02, 2015, 02:49:44 PM »
Have had poor results using a hot wire and templates, the wire sagged.
Sanded it worked well but that was messy and tedious.
Will try a router table next pass.
What is your experience?
Dave Siegler
NE9N extra class
AMA 720731
Offline Curare
Re: best way to cut spar notches in foam wings?
« Reply #1 on: November 02, 2015, 08:11:13 PM »
sounds like not enough tension on your bow.
I have no problems cutting spar slots in foam wings, although I rarely do it.
Greg Kowalski
AUS 36694
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #2 on: November 03, 2015, 03:32:47 PM »
on 33% scale r/c models i use this method: bend a wire to the shape of the chanell, make a side slider along the bend and plug to my soldering gun, then lay the slider on a metal rule and run along the wing, never had an issue, just nee to keep a steady movement to prevent the hot to build up and carve more than needed.
little practice and you will master ir perfectly
Offline Fredvon4
  • Central Texas
« Reply #3 on: November 04, 2015, 05:43:10 AM »
For my combat foam cores, usually no LE sweep, I just put a spacer for height of the Trailing edge to keep the wing panel center line level to the routing table, set my fence for distance back from LE, and rout to the correct depth....LOT of foam dust and it electrostatic sticks to every thing so I do it out side
On some tapered wings with some LE sweep back I prefer to tape both panels together and tape down a strait edge and use a cordless Dremel router atachment
Fred von Gortler IV
Offline Brent Williams
« Reply #4 on: November 04, 2015, 08:22:57 PM »
More wire tension.
Cut the airfoil with a smooth template, no spar slot.
Make a separate spar cutting template that has longer spar guides.   The spar template doesn't necessarily need to look like the airfoil, as its only purpose is to help make a clean cut.
Offline Curare
« Reply #5 on: November 05, 2015, 08:34:25 PM »
Oh yeah, hadn't cosidered that you might be trying to cut the spar slots at the same time as cutting the wing shape, which will give you a big problem.
As brent says, cut the airfoil shape first, then cut your spar slots!
Greg Kowalski
AUS 36694
