Building Tips and technical articles. => Building techniques => Topic started by: Tom Dugan on September 17, 2007, 07:50:47 PM
Will soon be covering and painting a Pathfinder profile. I would like to paint the Fuel tank. Any precautions, do's & don'ts, or advice?
Thanks Thomas
Thanks Thomas
Hi Thomas,
First, pressure test the tank! (ask me how I know.) it ain't no fun fixing a leak after a real pretty paint job is applied. ;D
I put a section of Weed Eater line in all the vents. Then just make sure it is clean and use a good metal primer.
Dont forget to scuff it up some with 220 grit to get some tooth on the shiny surface
Curt
Ive already pressure tested the tank. I will use a good metal primer and I thought I would use an automotive type touch up paint in a rattle can.
Thomas
Thomas
Hi Thomas,
I did exactly that with the tank on my Tomahawk. I used the new Duplicolor "Color Cast" (Candy) lacquer. I didn't use a clear coat, and it has been fairly fuel proof. But I *think* it would probably be better with some clear dope or urethane over it.
