  • July 07, 2025, 01:12:16 PM
Author Topic: Tanager looking for bird seed  (Read 27380 times)
Offline Chris Fretz
« on: December 20, 2016, 05:43:44 PM »
Hi Fellas! So I finally got around to building a kit. Ive never built a Brodak kit. Ive built plenty of Sterling, Sig, Top Flite, Control Line Classics, Carl Goldberg and Dumas kits but never a Brodak kit.
Anyway Ive been pondering what kind of controls to put in. I like the ball link controls I put in the Nobler from Tom Morris (I hope he gets well soon). I was thinking of going that route. What benefits do you get from those kind of controls as opposed to just the music wire sloppy control?? I Suppose a 4in bellcrank, although I put a 4 in the Nobler an felt it took a lot of wrist movement doing the stunts. On the fence with that too.
What does Tom use for his controls, is that Carbon rod? What does he use to wrap the ends with that he epoxies?
I'm giving a pool table slate with a sheet of drywall on top a try.
Thanks for your thoughts guy!
Chris
Formerly known as #Liner
AMA 1104207
Advanced
Offline Chris Fretz
Re: Tanager looking for bird seed
« Reply #1 on: December 21, 2016, 06:37:26 AM »
Tom Morris uses carbon tubes. He wraps the ends with Kevlar thread. When I don't have his handy, I make my own, but install short pieces of aluminum tubing over each end, each piece being about 1/4 inch long.  H^^
Thanks for the reply! I had Tom make me a set of controls for a Score. After examining, it seems like he used 4-40 all thread from the bellcrank to flap horn.  But the whole length of it feels like all threads inside the carbon tube. Does that sound about right? The flap horn to elevator feels hollow in the middle, how far inside the carbon tube would you epoxy the 4-40 ends?
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #2 on: December 21, 2016, 02:45:44 PM »
In the photos above, the top tube is mine. The lower tube is from Tom Morris. The three ends are Titanium, so I'm told.  As you can see. one end has grooves for the epoxy.  The bottom one is designed to go in the middle of a tube or tubes and can be turned either way for fine adjustment. Same for the middle one, except it fits in one end only.  The top one is a typical end.
The short piece of aluminum tubing and the Kevlar thread serve to keep the tube from shredding.  D>K
Very interesting! I was just going to epoxy a piece of all thread on the ends. Where do you get those ends at, specifically the top one??
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #3 on: December 21, 2016, 03:17:47 PM »
Hi Chris. I assume you are referring to the ball links?  I get those from Tom Morris. If you are referring to the aluminum end caps, I make them with a #7 xacto blade from aluminum tubing, the K&S stuff. I take a section of the carbon tube with me to my local hobby shop and find a tube that just fits over the tube.  D>K
Oh no I mean where can I get that titanium end 4-40 end with the epoxy groves? I got the ball links already from the hobby shop they are dubro an quite expensive for 12 they were $32
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #4 on: December 21, 2016, 03:21:20 PM »
I found some carbon tube at a hobby shop today, I wasn't sure what size to buy so I found one that 4-40 fits inside easily. But I also got one a little smaller that it didn't fit right in. Got them home an saw Tom uses the smaller one I got.
AMA 1104207
Advanced
Offline David Hoover
« Reply #5 on: December 21, 2016, 03:48:14 PM »
Chris,
For push rod materials go to Central Hobbies.
https://www.centralhobbies.com/cat3.php?cat=27&subcat=124
Click on whichever button you're interested in; carbon fibre rods, carbon fibre pushrod sets or titanium ends.  Tom Morris gets his threaded ends from Central Hobbies.
Best, Hoovie
Offline Chris Fretz
« Reply #6 on: December 21, 2016, 08:28:21 PM »
Chris,
Thanks for the heads up on that!
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #7 on: December 21, 2016, 08:40:14 PM »
Looks like I can squeeze this extra bellcrank in that I got from Tom. I think I'll try another floating bellcrank again. Not sure just yet how to hid it on a profile though. Could you double the sides of the 1/4in spar with plywood an drill the 1/8 hole through it? Or does the 1/8 rod need a hardwood as opposed to balsa to go through?
AMA 1104207
Advanced
Online john e. holliday
« Reply #8 on: December 21, 2016, 09:12:35 PM »
Post needs to go thru hardwood or ply plates.
« Reply #9 on: December 21, 2016, 09:30:29 PM »
Hi Chris. It's really good to see you back at the building table.
Here's how I secured it on my Twister. I carved the end of a square poplar dowel to fit a brass tube that sleeves the top of the screw. The brace is epoxied to the top spar and rib. Also in the photo, is a balsa brace against the rib at the bottom plate, also epoxied to the bottom spar. So those spars take all the forces in that direction from the bellcrank. I think it's pretty tough. I would not bore a hole through a spar.
Arrows point to the two braces and the brass tube sleeving the pivot screw.
Offline Chris Fretz
« Reply #10 on: December 22, 2016, 09:11:47 AM »
Thanks, I figured it probably did.
Hi Rusty! I'm slow going but at least I started building something. Are you building anything right now?
AMA 1104207
Advanced
« Reply #11 on: December 22, 2016, 09:26:51 AM »
I'm building a new wing for my Twister. I busted it in late October. I have been a little down lately, so only a bit of light shop work every week. Winter is always tough on me. Even the South Carolina winter, which you Pennsylvanians might not even notice. But now that the Winter Solstice is behind us, I am counting the weeks till Spring.
Offline Chris Fretz
« Reply #12 on: December 22, 2016, 09:37:08 AM »
Boy when you put it that way I better get moving on this airplane. I don't even know what to cover it in. All I've ever used was monokote. I bought some covering from Tom Morris but I've never used that stuff.
Get moving on that wing Rusty!
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #13 on: December 22, 2016, 09:43:45 AM »
I bought two kits this past summer an both kits have something pretty warped. One has a warped fuselage the other has warped spars an leading edge. I've been cherry picking each kit. What do you guys do about warped items in kits?
AMA 1104207
Advanced
« Reply #14 on: December 22, 2016, 10:18:59 AM »
As far as warps I some times make the piece work depending on the use.  The leading edge should be no problem.  If you got the Poly-Span covering from Tom Morris, check out the finishing procedure by Larry Renger .  I have just covered a wing using the procedure and it sure goes fast.  Two days of piddling in the shop and I have a covered wing that has a shine like I could never get with clear dope.  See the post My Secret Weapon.  It's in the paint and finish section.
Offline Chris Fretz
« Reply #15 on: December 23, 2016, 07:58:23 AM »
Thanks Doc I'll check em out!
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #16 on: December 23, 2016, 08:02:10 AM »
Had a bit of a setback today. Some fur ball danced on the wing ''
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #17 on: December 23, 2016, 03:40:03 PM »
Hows that look fellas? I just plan to cut the 1/8in rod flush and put the sheeting over top it. How long do you think the rubber fuel line will last before deteriorating? Probably longer than the first crash I'll guess.
AMA 1104207
Advanced
« Reply #18 on: December 23, 2016, 05:49:50 PM »
Hope you cut a notch for that set screw.   I lost my Sheeks Spitfire because the set screw came loose.   I put a ply plate top and bottom over the rod so it can't move vertically now.  I also don't like fuel tubing for spacers.  I use flat washers or make play spacers.
Offline Chris Fretz
« Reply #19 on: December 23, 2016, 06:25:09 PM »
Ohhhh thanks for reminding me to notch it for the set screw, I almost forgot!
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #20 on: December 23, 2016, 07:07:49 PM »
Ok Doc I got the flats and used aluminum tubing instead of the fuel line.
« Last Edit: December 23, 2016, 08:06:18 PM by #Liner »
AMA 1104207
Advanced
Online Carl Cisneros
« Reply #21 on: December 23, 2016, 11:15:21 PM »
Chris
Or you could have used a couple wheel collars as well.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Chris Fretz
« Reply #22 on: December 24, 2016, 03:50:46 PM »
Chris
Carl
Does anybody like the fuel tubing  :P. What are you building this winter Carl?
AMA 1104207
Advanced
« Reply #23 on: December 24, 2016, 07:11:53 PM »
Can't really say yet, but the wing is built in 2 halves.
will be powered either by one of the following motors:
OS 60H gold head
OS LA65
K&B 61
ASP 61
haven't decided as yet.
still have to get the wood for the fuz and tail
Carl
had to go under the knife again last month. had a dang hernia I did not even know I had.
Control Line RB
« Reply #24 on: December 24, 2016, 09:45:04 PM »
No, not fuel line for that purpose. I think the aluminum will work fine. As I posted in the other thread, I used brass tube for a similar setup.
Rusty
Offline Chris Fretz
« Reply #25 on: December 25, 2016, 07:03:48 AM »
Rusty
I guess only Tom Morris likes it. Rusty are you building your new wing from scratch?
AMA 1104207
Advanced
« Reply #26 on: December 25, 2016, 07:26:48 AM »
I didn't know Tom liked it, and I wouldn't dis anything he endorses.
I started to graft the two halves back together under the tutelage of Bob Zambelli, when a new box showed up at my front door with a Walter Umland label on it. It was a brand new laser cut wing kit! What a guy! Walter is alright. And that was only days after his return from the hospital.
So it's on the glass now. But I have developed such a fiery case of tendonitis in my left arm, it's only partially started while I drag around the house moaning. What a pathetic mess I am.
Merry Christmas, Buddy.
Rusty
Offline Chris Fretz
« Reply #27 on: December 25, 2016, 05:54:42 PM »
Can anyone recommend a fuel tank for this airplane with a LA 46?
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #28 on: December 25, 2016, 06:47:59 PM »
Rusty
That's pretty awesome Rusty! I hope you can get it together an your tendinitis calms down.  Nothing worse than feeling to bad to do things.
Merry Christmas to you guys too!
Chris
AMA 1104207
Advanced
« Reply #29 on: December 25, 2016, 09:46:00 PM »
Thanks Chris. Tell B Merry Christmas and happy New Year too.
Offline Leester
« Reply #30 on: December 26, 2016, 06:54:52 AM »
I've never had a problem with the fuel tube, and it's been on planes of mine for almost 10 years. I would imagine a 5oz tank would work just fine, I like the ATF (All Tubes Forward) style of metal tank.
Leester
ama 830538
Offline Chris Fretz
« Reply #31 on: December 26, 2016, 07:20:37 AM »
Do you use the wheel collars with the fuel line?  What is a all tubes forward tank? I guess I should ask if I should go with a uniflow or not as well.  Ha ha I should probably add that I have yet to be able to get a airplane to run the same right side up an upside down.
AMA 1104207
Advanced
« Reply #32 on: December 26, 2016, 07:24:33 AM »
I don't like the fuel tubing but I like it better than the aluminum tubing. Get some extra wheel collars and glue some flat washers to them if you have to and leave the set screws out except for the collars next to the bellcrank. I have a piece of 1/2" phenolic rod that I cut spacers out of. After the 1/8" music wire is in place hit the ends with a drop of CA glue.
That rib that's right there where the lead outs meet the bellcrank needs more clearance or you're brass tubing will catch.
I think you could do the pattern with a 4.5oz wide wedge uniflow tank.
http://brodak.com/wide-wedge-uniflow-fuel-tank-4.html
Check the length and see if you have room for mounting tabs back and front or if you have to go top and bottom. Set the tank 1/8" above the thrust line to start.
http://brodak.com/fuel/fuel-tank-brackets.html
Offline Leester
« Reply #33 on: December 26, 2016, 10:05:33 AM »
Yes I use wheel collars, everyone has there preference but the fuel tube holds everything nice and tight.
Here's a link to the ATF Tanks  http://brodak.com/a-t-f-medium-wedge-uniflow-fuel-tank-4.html  I use tank mounts like RSM has for profile's.
I didn't see them on RSM's web site but here's a picture, you put in threaded inserts in the fuse were the cut outs are and bolt in 4-40 bolts, use silicone adhesive to attach the tank to the plywood mount and now you can adjust the entire mount. Might be more than you want to do but I like it.
« Last Edit: December 26, 2016, 10:25:17 AM by Leester »
Leester
ama 830538
Offline Chris Fretz
« Reply #34 on: December 26, 2016, 04:26:19 PM »
Why don't you like the aluminum tubing idea? Why would you have move the adjustable leadouts further out than the last full wing rib?
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #35 on: December 26, 2016, 04:28:58 PM »
Thanks for sharing your way, the silicone will hold good enough on its own?
AMA 1104207
Advanced
Offline Leester
« Reply #36 on: December 26, 2016, 06:03:52 PM »
Just make sure it's Silicone Adhesive !! I sand the back of the tank to give it some tooth to hold onto, also the plywood . Like I said it has worked for me, Your mileage may vary !!
Leester
ama 830538
Offline Chris Fretz
« Reply #37 on: December 26, 2016, 06:22:46 PM »
Would you install a dual line adjustable leadout or a independently adjustable leadout? Of the two kits I have one kit has dual an the other kit has independently.
AMA 1104207
Advanced
« Reply #38 on: December 26, 2016, 07:21:43 PM »
Chris
All my planes with adjustable lead outs use the dual line adjusters.
The new plane will have seperate line adjusters. (that is what I had in my parts box)
The tank mount that Leester had is a good one. (make sure to fuel proof the wood) Or you can solder the end ones on from Bordak. http://brodak.com/fuel/fuel-tank-brackets/adjustable-tank-brackets-end.html
A 4 1/2 oz tank will work fine. The choice is up to you as for the type of tubing location. I like these on profiles: http://brodak.com/fuel/fuel-tank-brackets/adjustable-tank-brackets-end.html
Make sure to lengthen the opening on the outer wing rib for the adjustable lead outs.
Control Line RB
Offline Chris Fretz
« Reply #39 on: December 27, 2016, 04:27:01 AM »
Do you have a picture of how you plum your tank?
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #40 on: December 27, 2016, 04:32:50 AM »
Chris
The dual line looks easier to screw with so I'll try that one.
Do you guys solidly mount the tank once you solder the ends on? Or do you put something to cut down the vibration?
AMA 1104207
Advanced
Offline Leester
« Reply #41 on: December 27, 2016, 07:00:54 AM »
Chris let's do a search on "cloning hawker typhoon" and scroll down and you will see pictures of the mounted tank mount.
Leester
ama 830538
« Reply #42 on: December 27, 2016, 07:45:09 AM »
I think the aluminum tubing is thin and could cut into the plywood.
Bolt your tank hard to the plane just make sure you're not stressing the solder joints of the brass brackets. If you want to glue your tank with caulk to plywood with thin wood around the slots good luck with that, not on my plane.
You want the lead out guide to be as close to the tip as possible so the cables don't work the slot.
Offline Chris Fretz
« Reply #43 on: December 27, 2016, 07:45:55 AM »
That's a cool looking airplane, do you still have it? I didn't see any pictures on how you ran the vent line though.
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #44 on: December 27, 2016, 07:49:56 AM »
I think the aluminum tubing is thin and could cut into the plywood. I mean the center section, rib #2 next to the bellcrank needs more clearance on the brass loops. Bolt your tank hard to the plane just make sure you're not stressing the solder joints of the brass brackets. If you want to glue your tank with caulk to plywood with thin wood around the slots good luck with that, not on my plane.
I'm my Thoughts on a Tanager thread you had mentioned moving the adjustable leadouts out further than the plans mentioned, I was just wondering why.
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #45 on: December 27, 2016, 07:58:18 AM »
Oh I didn't see this the first time I read the reply.
The wing tip is pretty long an I was thinking it could jam up in the small long slot it says to make.
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #46 on: December 27, 2016, 08:33:25 AM »
For the landing gear is a two pice that comes in the kit ok or would I be better off bending a one piece landing gear?
AMA 1104207
Advanced
Offline Leester
« Reply #47 on: December 27, 2016, 08:50:44 AM »
Adhesive Silicone is NOT caulk, do a search and you'll find lots of people use it and the biggest problem is trying to get it apart !! The tank mount is 1/8" ply which I trust more than a solder joint. You don't do anything with the vent after you fill your tank , that tank is an RSM Profile uniflow tank www.rsmdistribution.com
Leester
ama 830538
Offline Leester
« Reply #48 on: December 27, 2016, 09:05:45 AM »
The two piece landing gear is fine.
Leester
ama 830538
Offline Chris Fretz
« Reply #49 on: December 27, 2016, 09:56:58 AM »
Where do you guys get spinners that aren't too crazy in price? I don't have any luck with pro spin spinners they vibrate too bad for me.
AMA 1104207
Advanced
